#1814644 - 07/16/09 02:42 PM Refrigerant oil?
thephnx39 Offline
Loc: Texas
What are some refrigerant oil brands that I can use to lubricate O-rings?
2006 MERCURY GRAND MARQUIS LS
#1814758 - 07/16/09 04:24 PM Re: Refrigerant oil? [Re: BigNSlow]
JWhittaker Offline
Loc: Seekonk, Ma
I have a question relating to this area as well, what color are those "leak detector fluids" do they look sorta like antifreeze? My ac worked beautiful till tues I noticed some green fluid on the ground checked coolant level first a ok.. Now I took another look at why the ac comp. wasn't turning on, I put a jumper wire on the plug that goes to accum. walla ac comp. turns on...Now upon inspection of the accum. there is a whole bunch of that green fluid on the insulation that goes around accum. an it dripped onto the chassis explaining my leak on the ground... Looks like a new accumulator, would be in order.. Thoughts difficult job? Have people done this job/ needed an accum? Thanks
2002 CV LX Sport
Speed Bleeders installed with the new brakes!10/07-brakes 85K at the time
http://www.flickr.com/photos/25029145@N06/2382004080/
#1814947 - 07/16/09 08:51 PM Re: Refrigerant oil? [Re: BigNSlow]
JWhittaker Offline
Loc: Seekonk, Ma
Ok bluemobile you answered my question I was concerned bout those connections where the accum. hooks up to the hoses.. I'm assuming there are O rings in there.. Hopefully the charging is the similar to a residential house, thats what I do for a living when the economy picks back up that is.. I have a vac pump and stuff so shouldn't be any trouble. I will let you know
2002 CV LX Sport
#1815124 - 07/17/09 01:07 AM Re: Refrigerant oil? [Re: JWhittaker]
2vmodular Offline
Loc: New England
here's a webpage that i constructed about adding refrigerant to a 2000 crown vic using 12oz service cans
http://www.p71interceptor.com/actuneup/r134arefill
#1815549 - 07/17/09 04:11 PM Re: Refrigerant oil? [Re: 2vmodular]
JWhittaker Offline
Loc: Seekonk, Ma
Excellent write up thanks
2002 CV LX Sport
#1817305 - 07/19/09 10:56 PM Re: Refrigerant oil? [Re: BigNSlow]
thephnx39 Offline
Loc: Texas
Do I use the pag-46 oil the same way i would use r134a freon, by connecting it to a pump gauge and pumping the oil into the liquid line?
#2311329 - 06/08/11 09:28 PM Re: Refrigerant oil? [Re: thephnx39]
JetSledOnWheels Offline
Loc: St. Paul, MN
old thread i know but phnx, to answer your question you asked 2 years ago, it depends on what type of container you got your oil in. a regular bottle with a cap will either need to be put in the accumulator before installing (not preferred) or forced in the suction line by a siphon pump lookin thing. if you got the can you can tap with your hose set its just the same as adding refrigerant.
the low pressure side aka the suction side is not in fact drawing a vacuum or sucking anything in. you'll still need a pressurized can to put anything in there.
04 CVPI 165k - Daily Driver
01 CVPI with 227 on the clock - Goodbye sweet prince!
99 CVPI 198k - Downgraded to winter beater
10 registered (gearmaker, Flashburn, DES, Car_54, garndreadz, 1 invisible), 58 Guests and 81 Spiders online.
Moby_Vic 194
a_d_a_m 159
BigMerc96 136
Chaplian 113
EZlivin11 111
White99MGM 106
charlieD 96
DudeAbides 92
RF_Overlord 84
SocalSam 79
