#1820640 - 07/23/09 12:58 PM turn signal flasher location?
torino_69 Offline
Loc: No. Mass.
Hey guys, i was wondering where the turn signal flasher is located on a 99 grand marquis. The hazard lights are working, and i can hear the flasher for that clicking, but none of the turn signals work, and no clicking noise from the flasher with left/right turn signals on so im assuming it just needs a new flasher...but where is it?
And the facts are that this country doesn't have the ability or the capacity to deliver electric vehicles on a mass scale - not to mention that we'll have to pay consumers to drive them - and we won't be able to until closer to 2020 at the earliest, despite the wildly bullish predictions by the Obama administration. - Johan de Nysschen, President of Audi America
#1820693 - 07/23/09 01:45 PM Re: turn signal flasher location? [Re: BigNSlow]
torino_69 Offline
Loc: No. Mass.
So basically ford wasnt kidding when they said its a $450 part? shi-t.
#1820701 - 07/23/09 01:52 PM Re: turn signal flasher location? [Re: torino_69]
CVPI06 Offline
Loc: Kentucky, Louisville
ouch, so I guess that basicially means the idea I had for replaceing the turn signal flasher onthe vic with one that is from an 18 wheeler (semi) is out of the question?
I want to have the slow long flash that most semis have when they use there turn signals...any suggestions of how I might be able to achieve that if I cant replace just the turn signal flasher?
#1820718 - 07/23/09 02:03 PM Re: turn signal flasher location? [Re: CVPI06]
torino_69 Offline
Loc: No. Mass.
18 wheeler flashers are very different, even from standard car flashers. They are more like a car's starter solenoid than anything. at least the older one's anyways. the 2000+newer trucks have gotten a little more modern and use a flasher like this
http://www.empirechromeshop.com/p-3501-3...ed-flasher.aspx
You could probably wire one into an older car if you wanted, but i dunno in detail how this newer flasher system works on these cars.
Edited by 70torino429 (07/23/09 02:18 PM)
#1820759 - 07/23/09 02:30 PM Re: turn signal flasher location? [Re: torino_69]
CVPI06 Offline
im mostly wanting to simulate the long hold in the "on" (when the turn lamp is lit up) that the semis usually seem to have, they tend to make a CLICK on for 2 seconds or so, CLICK, off for 2 seconds or so, so on so fourth type pattern...
Not sure if i'm explaining it well enough and with out a physical semi to turn on and record what I am talking about its kinda hard to describe in words...
#1820877 - 07/23/09 03:29 PM Re: turn signal flasher location? [Re: BigNSlow]
torino_69 Offline
Loc: No. Mass.
You could try doing the LCM bypass. linky... First I would make sure that the LCM is indeed bad though and it's not something simple like a fuse.
hmm, ill have to take a closer look at it here in a few, i just assumed the flasher was something simple i could change out like the old style ones. Going to check fuses now.
#1820902 - 07/23/09 03:45 PM Re: turn signal flasher location? [Re: torino_69]
torino_69 Offline
Loc: No. Mass.
Is there a linky somewhere i can see what all the fuses are for? like what position 1 fuse controls, position 2 etc. The fuse layout i suppose you would call it.
Edited by 70torino429 (07/23/09 03:46 PM)
#1820991 - 07/23/09 05:25 PM Re: turn signal flasher location? [Re: torino_69]
DavidsAwesome Offline
Loc: High Desert, Cali
http://www.motorcraftservice.com/pubs/content/~WOTCRO/~MUS~LEN/41/96croog1e.pdf
The oldest manual ford has is this 1996 cv owners manual. Would it be the same maybe?
2001 Ford Crown Victoria Police Interceptor
Former Buena Park Police cruiser
http://s219.photobucket.com/albums/cc140/davidsawesome/Ford/
#1820995 - 07/23/09 05:27 PM Re: turn signal flasher location? [Re: DavidsAwesome]
torino_69 Offline
Loc: No. Mass.
I dunno.
i did find it in the little owners manual though. 'twas fuse #5. Put in a new 15Amp fuse, and its good to go. Thanks guys.
Edited by 70torino429 (07/23/09 05:28 PM)
Moderator:  BigMerc96, Quasar
10 registered (124neta, bspurloc, 09mnsp, bembry, Htowns, 1 invisible), 68 Guests and 14 Spiders online.
a_d_a_m 193
Ezbok58a 156
charlieD 153
BigMerc96 138
dpk 120
Ponyguy 119
White99MGM 101
SocalSam 81
Moby_Vic 74
reminc70 74
