Page 1 of 1 1
#1829359 - 08/03/09 11:22 PM Parts and supply check list for PI swap.........
mustang_zulu Offline
I am not
Loc: Garland, TX
ok, im doing the PI intake and PI cam swap on my car soon. I got the cams, the intake (as soon as someone get his A$$ home!!! LOL), PI intake gaskets,PI coolant tube, PI coolant nipple.... what else?? be as specific as you want. also there is a tool (i was told) that i need to get so i can install the cams without taking off my timing chain cover??? i got cash to buy some things so this is the time for me to aquire the goodies i will need. i wont be doing the swap for like a month.... but i got the main stuff now its just time for the little things... post away :):):) thanks guys :):)
1998 CVHPP P74, 114k Orginal Miles, Handling & Performance Package/ Elec Instrumentation/4 Wheel ABS Disk Breaks/ Traction Control/ Premium Sound Sys w/ 6 Disk CD Changer/ Auto Climate Control/ Leather Package/Garmin GPS/Speed Sensitive Steering/Dual Exhaust W/ Flow Master Delta 40's/ CAI/ P71 PCM, P&P Inc. plenum & 75mm TB/ PI Intake & Cams/ 24 lb Injectors/ Steeda UD's
#1829554 - 08/04/09 09:36 AM Re: Parts and supply check list for PI swap......... [Re: mustang_zulu]
mblazakep Offline
Search Police
I think you may need the new-style alternator bracket.
#1829563 - 08/04/09 10:03 AM Re: Parts and supply check list for PI swap......... [Re: mblazakep]
98VicP71 Offline
223 RWHP/ 257 RWTQ
Loc: ATL
That list looks right to me. You can re-use your stock Alt Bracket but you will need to drill two new holes in it. Very easy to do.
I beleive you can get the tool online somewhere I just can't recall where.
"Today is the tomorrow that you worried about yesterday!"
01 CVPI, (Count Blackula)155k mi, 3:73w/T-Lok w/Carbon Clutch upgrade, Typhoon intake, BBK 75MM TB, ADTR P&P plenum, Steeda 1/4" Spacer, HiTech Stage II Cams, MZT w/Dyno Tune 93, 22c plugs, 180* T-Stat, TRE 255LPH Fuel Pump, Custom 2.5" Madrel exhuast w/single spun cats, Magnaflow mufflers, Blacked out rear, JMOD, Steeda Underdrives, Scanguage II, Custom Gauges, and 35% tint all around. (11/07/09) 14.88@90.036MPH 4180#'s R/T .032
#1829716 - 08/04/09 02:33 PM Re: Parts and supply check list for PI swap......... [Re: 98VicP71]
I am not
Loc: Garland, TX
yea the Alt bracket i already drilled when i had to replace my leaking orginal intake with the alum crossover one. i wish i had the $$$ then to do the PI stuff, but u know how it is when money is tight. what im looking for is this tool i was told about. it makes it possible so i can change the cams without removing the timing chain cover.
#1829755 - 08/04/09 03:29 PM Re: Parts and supply check list for PI swap......... [Re: mustang_zulu]
Bangster Offline
Ford (Rotunda) has a couple versions of the timing chain holding tool, Anderson Ford made/makes one, and I have seen others on eBay. I personally have the old and new Rotunda ones, I haven't done the cam swap yet, I am too lazy and I never seem to find the time.
1974 Honda cb400
#1829970 - 08/04/09 07:45 PM Re: Parts and supply check list for PI swap......... [Re: Bangster]
I am not
Loc: Garland, TX
got any links of places i can get one? perhaps find one here local? maybe i will try to google timing chain holding tool...
#1830020 - 08/04/09 09:20 PM Re: Parts and supply check list for PI swap......... [Re: mustang_zulu]
Spartan Offline
Loc: Bozeman, MT
Might as well get a thermostat and put that in at the same time.
I would pull the cover, I am a perfectionist and need to know those timing marks are lined up. Besides, you can check out the condition of your guides and the tensioners. Only an extra hour.
I won't even go into degreeing cams, but the last PI cams I installed one side was 4 Deg. retarded from the other one. More power and efficiency to be had degreeing.
1998 P71 - Aluminum 2V, T45 5speed, 3.73 gears, some minor suspension mods.
"If man made it, it can be improved; if God made it, it doesn't need to be."
#1830086 - 08/04/09 11:14 PM Re: Parts and supply check list for PI swap......... [Re: Spartan]
tmarks Offline
Loc: Leesport, PA
thats a pretty accurate list. you will need a new o ring for your water pump too. you need different cam gear bolts and washers for the PI cams. they are different from PI to nPI. i got them directly from ford for a few bucks each. be careful when removing the cam gears from the cam not to lose the washer or you will nullify the whole point of not ripping the cover off because the washer WILL fall down. dont forget the rtv as well, and valve cover gaskets if you are picky. you can get away with reusing them, but i dont like to.
i just did the swap two weeks ago. i bought the anderson tool (google it) and didnt even touch it. i used a c clamp and a pair of vise grips to hold everything in place. it worked very well. i recommend having a second person present to help, i did it on my own and it was a little bit of a pain. you will also want some engine assembly lube to use when putting the cams in.
check this link out.. http://www.stangnet.com/mustang-forums/661774-npi-pi-cam-manifold-swap-how.html its for a mustang but it the same basic thing.
like i said, i just did this a few weeks ago on my 96. it took me about 4 hours all told start to finish. itll prob take most people a little longer but its not that terrible of a job. good luck and enjoy!!
Edited by tmarks (08/04/09 11:15 PM)
1996 Mercury Grand Marquis GS
PI intake, PI cams, Marauder AirBox, 80mm MAF, 04 PI Ziptube, J-Mod, BOC tune
#1830233 - 08/05/09 07:35 AM Re: Parts and supply check list for PI swap......... [Re: tmarks]
98VicP71 Offline
223 RWHP/ 257 RWTQ
Loc: ATL
you will hate to hear this but honestly if you are going to do a cam swap on your 98 with 100k+ Mi then it would probably be a good idea to go ahead and remove the timing cover and replace your guides and tensioners as well as chains. That is what I did and I am glad I did cause one of my chains was starting to eat through a guide.
#1831000 - 08/06/09 12:39 AM Re: Parts and supply check list for PI swap......... [Re: 98VicP71]
I am not
Loc: Garland, TX
i thought if i used PI intake gaskets i didn't have to use RTV on the gaskets???
also how do i tell if my cams are PI cams?? all i see is patient numbers on the cams....
#1831004 - 08/06/09 12:52 AM Re: Parts and supply check list for PI swap......... [Re: mustang_zulu]
Spartan Offline
Loc: Bozeman, MT
A dab of RTV on the pass front and drivers rear in between the coolant and intake port. Just a dab on the head, then carefully lay the gasket on top. You will see where if you trial fit the gasket first.
Post the numbers, or enter PI cams and the # on Google.
#1832320 - 08/07/09 05:28 PM Re: Parts and supply check list for PI swap......... [Re: Spartan]
unixdude Offline
Loc: NJ
Here's another thing that you might want to consider, while you have easy access:
Fuel Injector Service Kit (all the way at the bottom)
http://rjminjectiontech.com/?p=27
and instructions on how to clean 'em:
http://fordfuelinjection.com/?p=82
I just did the intake swap over the last couple of weekends (I work slow and had to stop every other minute to wipe the sweat out of my eyes). If you are going to use the PI gaskets, like Spartan said, you'll need RTV in the locations posted. I drew a thin line of RTV around the entire coolant passage, spread it out, then set the gasket (after removing the location tabs). I didn't put any RTV between the gasket and the intake. That was last weekend. I have almost everything back together, but have not yet filled the cooling system. I'll have at least a week of cure time.
I don't see it on your list, but you might want to replace the heater core hoses. Unless yours are brand new, I would change 'em out while doing the swap.
Page 1 of 1 1
Moderator:  Liquid, JohnG, dRock96Marquis
Hop to:
Google Search!
Google
Tire Rack!
The Tire Decision Guide
40 registered (flyboy, Chase3203, bkauto1, GR40_LSC, AKA_Blackcvpi, 98Gdmarq, 7 invisible) and 39 anonymous users online.
Amazon!
February
Su M Tu W Th F Sa
1 2 3 4 5 6
7 8 9 10 11 12 13
14 15 16 17 18 19 20
21 22 23 24 25 26 27
28
