#1842948 - 08/22/09 04:24 PM Radiator drain plug on 98 Marquis?
98marquis46L Offline
Loc: Herrin,Illinois,Williamson Cou...
Hello Fellow Panther fans.Today I started to look for the radiator drain valve/plug on my 1998 Mercury Grand Marquis in the usual place, at the bottom of the radiator. This is the first time I've looked for the drain valve on this car, I could not spotted. I would use a Haynes, but I usually order/burrow them from the library and it takes 3 days to get them. So I thought I post this question.I am getting ready to personnally drain the radiator to make sure it is as clean as possible. Oh yeah if you have any tips, please post them.
1998 Mercury Grand Marquis LS stock.
#1842970 - 08/22/09 04:51 PM Re: Radiator drain plug on 98 Marquis? [Re: 98marquis46L]
BlueFusion Offline
Loc: Dayton, OH
If it's anything like the 99 and 00 panthers I have, it's on the driver side bottom of the radiator. It's a white plastic plug.
My other ride is measured in Mach.
Peace through superior firepower.
2006 Mercury Grand Marquis LS Ultimate [ 62,754 miles TOTALLED - Arizona Beige ]
> Addco Sway Bars || Heinous Rear Control Arms || KYB Gas-A-Just Shocks || Hawk HPS Pads || Centric Premium Rotors
> BOC 93 Octane Tune || 05+ Airbox & 80mm MAF || Steeda Underdrive Pulleys || J-mod to 88grandmarq specs
> CVPI Dual Exhaust || Rear Bumper Tuck || BH1976 Headlight Relay Harness || Ported & Polished Plenum
> 3.55 RAR || Trac-Lok w/ Carbon Fiber clutches || Marauder Spoiler
> Replaced the factory "Premium Audio"
#1842988 - 08/22/09 05:19 PM Re: Radiator drain plug on 98 Marquis? [Re: BlueFusion]
mustang_zulu Offline
I am not
Loc: Garland, TX
X2
#1843048 - 08/22/09 07:40 PM Re: Radiator drain plug on 98 Marquis? [Re: mustang_zulu]
Found it, thank you very much.
7 registered (CVJPMG, DES, 2004_p71, JaxRhapsody, IPreferDIY, 1 invisible), 85 Guests and 97 Spiders online.
NM117 324
EZlivin11 131
BigMerc96 127
Moby_Vic 126
RF_Overlord 124
Chaplian 117
mdnos 96
a_d_a_m 95
Ezbok58a 92
09P71VIC 91
