#1859421 - 09/13/09 12:24 PM Loud humming noise in the mornings
WARII Offline
Loc: St.Louis
When I get in my car in the mornings and start it I hear a loud humming noise. I have heard this noise on and off for years but nothing ever consistant. Now this happens everytime I start the car in the mornings. I dont hear it when I get out of work that I can recall. When it happens I usually just hit the gas and a quick tap of the pedal and its gone.
This morning I decided to try some investigation and popped the hood to track it down and it seems to be comming from the air box. I put my hand on the box and it was vibrating consistanly with the hum(it may not be comming from there) Has anyone ever had this problem or suggestions on what to check?
2000 G.M. 75k 1966 Galaxie 69k
#1859422 - 09/13/09 12:29 PM Re: Loud humming noise in the mornings [Re: WARII]
Rizzo Offline
J-MOD Master
Loc: Romulus,MI
Could this be the strangest IAC failure ever ?
Guys reporting hearing a tuba like sound from the pipes, When mine died. It just died.
The Jmod video is done! LINK!
#1859432 - 09/13/09 12:41 PM Re: Loud humming noise in the mornings [Re: WARII]
unixdude Offline
Loc: NJ
This sounds very familiar, but I've never tried to track it down. It's very interesting that mine is also a 2000 MY, but a CVPI instead (not that it really makes a difference between a MGM and CVPI).
Please post a follow up if/when you figure out the source.
#1859463 - 09/13/09 01:23 PM Re: Loud humming noise in the mornings [Re: unixdude]
BlueFusion Offline
Loc: Dayton, OH
When my IAC was dying, it made that tuba noise. It was very loud coming down the air intake tubes. When I took off the tube for the IAC from the main air intake tube, the sound came directly out of that smaller tube. After I replaced the IAC, the noise went away.
My other ride is measured in Mach.
Peace through superior firepower.
2006 Mercury Grand Marquis LS Ultimate [ 62,754 miles TOTALLED - Arizona Beige ]
> Addco Sway Bars || Heinous Rear Control Arms || KYB Gas-A-Just Shocks || Hawk HPS Pads || Centric Premium Rotors
> BOC 93 Octane Tune || 05+ Airbox & 80mm MAF || Steeda Underdrive Pulleys || J-mod to 88grandmarq specs
> CVPI Dual Exhaust || Rear Bumper Tuck || BH1976 Headlight Relay Harness || Ported & Polished Plenum
> 3.55 RAR || Trac-Lok w/ Carbon Fiber clutches || Marauder Spoiler
> Replaced the factory "Premium Audio"
#1859467 - 09/13/09 01:32 PM Re: Loud humming noise in the mornings [Re: BlueFusion]
IZ1111 Offline
Loc: Houston, TX
Yup the Idle Air Control valve is sticking. Replacing the IAC is a sure fix.
1992 Crown Victoria LX 150K AOD 3.08gears
-A/C delete (w/ condenser & accumulator), -CVPI Aluminum Driveshaft, -Cold Air Intake, -Electric Fan, -'96+ Intake System, -180� Thermostat, -NGK Iridium Spark Plugs, -FlowMaster 40 muffler, -UnderDrive Pulleys (excluding WP pulley), -Battery in Trunk
SOLD!!!!
#1859530 - 09/13/09 02:50 PM Re: Loud humming noise in the mornings [Re: IZ1111]
WARII Offline
Loc: St.Louis
Ill try to change this out in the next xouple of days
#1859685 - 09/13/09 08:30 PM Re: Loud humming noise in the mornings [Re: WARII]
gord_bolton Offline
Loc: Saskatoon, Saskatchewan
Do you have the air ride on the rear axle?
If so then the compressor will kick in to level the car after you
put your weight in it.
The compressor sits right under the air box.
#1859986 - 09/14/09 09:04 AM Re: Loud humming noise in the mornings [Re: gord_bolton]
WARII Offline
Loc: St.Louis
no it doesnt
#1859992 - 09/14/09 09:34 AM Re: Loud humming noise in the mornings [Re: Rizzo]
larryo340 Offline
Loc: Long Island
From my experience the humming noise was common on the '92 thru '95 or '96 I think. The later ones just seem to let the engine die at idle.
So you you're right on both ways \:D
MOD List for MGM
...Marquis sold frown
#1862523 - 09/17/09 01:23 PM Re: Loud humming noise in the mornings [Re: larryo340]
WARII Offline
Loc: St.Louis
Thanks guys...The car died on me this morning when I started it up. Good thing I grabbed one at the junk yartd the other day....It started humming everytime I started it yesterday. So it was the IAC
#1863008 - 09/18/09 01:02 AM Re: Loud humming noise in the mornings [Re: WARII]
1Fastvic Offline
Loc: Florida USA
mine does it every so often but yes its the IACV u can take it off and clean it with like carb cleaner and itll do it rarley like mine.
____________________old vic____________________________
1FastVic- 2001 P71, magnaflow custom exhaust, trick flow plenum, 75mm throttle body, Jmod, B&M Electronic Shift Improver, Gutted Cats.
Coming Soon: 3.73, drilled and slotted rotors, marauder intake, new head gaskets and oil pan gasket.
#1863114 - 09/18/09 08:06 AM Re: Loud humming noise in the mornings [Re: WARII]
Big_Bad_Joe Offline
Loc: Rochester NY
a used IAC?
wow... that's like used air in the tires... see how long that one lasts...
here is a tip... when it starts making noise and stalling out get a replacement... the replacement IAC on my 2000 lasted longer than the original
Underdrives from ADTR.net
Given to DG in Ohio
#1863482 - 09/18/09 04:40 PM Re: Loud humming noise in the mornings [Re: Big_Bad_Joe]
1Fastvic Offline
Loc: Florida USA
yea obviously thats the correct way to do it.
mine just makes that loud humming noise like once every like 2 months and i just turn the car off and restart and it wont do it again for like a few months.
so im not overly concern with mine
Moby_Vic 173
a_d_a_m 141
BigMerc96 135
White99MGM 107
EZlivin11 103
Chaplian 101
charlieD 96
SocalSam 83
RF_Overlord 80
2468 80
