#1875797 - 10/05/09 04:56 AM Engine shut off while driving
Spacediver Offline
Loc: bay area, ca
So I was pulling onto the freeway today when out of no where the car stops pulling, feels like it's coasting, oil pressure was at zero and I had no power steering. My speedo was springing all over the place as I coasted to a stop. I'm sitting on the side of the freeway, radio still playing, AC blowing like normal but my engine was completely off. I turned the ignition to the off position, waited a moment and then tried starting her back up. She started up like nothing was wrong and drove completely normal the rest of the way to work. I didn't even get a check engine light.
It sounds to me like an ignition problem but I have no idea where to start. Any help?
She has 96k miles and a relatively new alternator.
Jesse
Edited by Spacediver (10/05/09 04:57 AM)
'03 P71
20% tint
#1875839 - 10/05/09 07:45 AM Re: Engine shut off while driving [Re: Spacediver]
Blue95 Offline
Loc: Past the Horizon
Check the connection at the crankshaft sensor, it's located on lower pass side of the front timing cover, right next to the ac compressor. If the sensor or connection is bad, the car will not run.
Same thing for the cam sensor, it's located right behind the power steering reservoir, upper front right of timing cover.
Also check the connector for the main engine harness, located right in front of the power brake booster. May be a good idea to disconnect the 3 connectors there and reconnect using a little dilectric grease.
1995 P71-SOLD
2002 HPP-SOLD
#1876381 - 10/05/09 07:39 PM Re: Engine shut off while driving [Re: Blue95]
Spacediver Offline
Loc: bay area, ca
Thanks Blue95, that sounds like great advice, I'll do that!
'03 P71
20% tint
#1876409 - 10/05/09 08:15 PM Re: Engine shut off while driving [Re: Spacediver]
Colt45 Offline
less is more´┐Ż
Loc: Moses Lake, Wa
The car will run without a cam sensor, it will not run without a crank sensor. I was going to say if it does not start, watch the "Check Engine" light. When you crank it should go out, if it does not, the PCM is not getting crank signal.
-Colton
2002 Ford Crown Vic PI, 178k "Highwayman" (Ex-Kootenai County, ID Unit #42)
#1876467 - 10/05/09 09:25 PM Re: Engine shut off while driving [Re: Colt45]
Orionsax7 Offline
Loc: Ft. Worth, TX
Agreed...if you have extended cranking before it does turn on, suspect cam sensor/wiring
-Alex H. 2000 Crown Vic LX HPP w/ 3.55 open, stock dual exhaust
Changes= PI Intake, MZT/93 BOC, Jmod, headlight wiring upgrade, flashing side markers
Soon=Underdrives
Ford Master Tech, Specialize in A/C and Electrical
#1876549 - 10/05/09 10:59 PM Re: Engine shut off while driving [Re: Orionsax7]
Dentman Offline
Loc: North East
Had the same thing happen to me once on the interstate while driving my old 87 S-10 P/Up . It never happened again over the course of the the 3 years I owned it. This happened in mid summer on a hot Atlanta day , wrote it off to possible vapor lock.
#1876923 - 10/06/09 01:12 PM Re: Engine shut off while driving [Re: Dentman]
Kinger87 Offline
Loc: Gladstone MI
this happened to me when i was driving up Pikes peak in CO, like 3 or 4 times. im positive that was vapor lock, cause I wasnt the only one stalled out on the way up.. lol.
2003 Grand marquis all stock
#2633729 - 11/30/12 09:13 PM Re: Engine shut off while driving [Re: Spacediver]
trinityautomhnj Offline
Loc: MOUNT HOLLY , NEW JERSEY
I AM HAVING THE SAME PROBLEM, ONLY GETTING WORSE...... CAR SHUT DOWN ONCE & WOULD NOT START, HAD TO HAVE IT TOWED TO LOCKSMITH TO HAVE KEYS RE-PROGRAMMED. KEEPS SHUTTING OFF. I HAVE REPLACED FUEL PUMP, FPDM
#2634028 - 12/01/12 07:08 PM Re: Engine shut off while driving [Re: Spacediver]
My car did this but the CEL and Alt light would not come on with the key on before starting. It took from 5 seconds to weeks for the CEL to come back and the engine would start. When the engine was cutting out the Speedo would drop the come back up when the engine kicked on and off
#2634039 - 12/01/12 07:54 PM Re: Engine shut off while driving [Re: Chevyguy]
Mine sometimes stalls & restarts, but lately, if you drive about 3-5 miles, it shuts off, the speedo needle bounces like crazy, and pats light flashes rapidly, you cannot hear the fuel pump clunk, then afer a few seconds, she will restart & run. last time it shut off and did not re-start, I came back 8 hrs later, it would not start, got spare 2 keys, fired right up, reprogrammed 1st key, and ran. tommorow I hope to pull inner fenders & check wiring harness, & maybe connections @ dash cluster. Hoping to find broken / burnt, or green snot growing. this thing is driving me crazy. I did have the fuel pump replaced, it has been pinging, I figured 280,000 miles it might be due
#2634091 - 12/01/12 10:30 PM Re: Engine shut off while driving [Re: Spacediver]
Trinity what year car do you have?? My symptoms are just like yours. I thought my PATS was bad too as the light flashed when the engine was cutting in/out.
I swapped in a 04 P-71 PCM to my 04 P-74. This disabled the PATS but I had to ground the wire leading from the starter relay. See the $100 MZT writeup for this info. I swapped in the 04 P-71 80 MM MAF and the famous Zip tube. Worked good for 3 weeks then started dying again. The PCM had about 300K on it I suspect the pre-existing short finally burned up the replacement PCM, still don't really know for sure. I have a thread here and it links to all the others
http://www.crownvic.net/ubbthreads/ubbthreads.php?ubb=showflat&Number=2630571#Post2630571
#2634269 - 12/02/12 06:37 AM Re: Engine shut off while driving [Re: Chevyguy]
my car is a 2003 LX HPP, I have had it since 2004 bought with 25,000 miles. I did have a chip installed right after I bought it. I was wondering if the chip or connections are bad
#2634270 - 12/02/12 07:20 AM Re: Engine shut off while driving [Re: Spacediver]
Yup sounds like 03-04 owners have had this problem.
Biggest thing to look for is the Check engine light. If the engine stalls it the CEL and ALT lights should illuminate and the speedo should still work. If the PCM shuts down all you get is the TRAC light coming on and the speedo jumps down to zero. If the speedo jumps about the PCM is shutting down/turning on rapidly. A few times that happened to me and the engine kept running, first time was back in October on the way to the CT 5 guys meet.
#2634283 - 12/02/12 09:54 AM Re: Engine shut off while driving [Re: Chevyguy]
I have an analog dash, I have had windstars with speedo & tach needle going bezerk, they seem to have a problem on the back of the dash cluster, where plug connects.
#2634459 - 12/02/12 05:52 PM Re: Engine shut off while driving [Re: trinityautomhnj]
Pulled the inner fenders today, examined the wiring harness for chaffing, found nothing. pulled the cluster, looked OK
to be continued.............
9 registered (Bangster, Fordiesel69, 1990CrownVic, LSE_Dave, mrjon1985, 1 invisible), 46 Guests and 79 Spiders online.
NM117 324
RF_Overlord 129
EZlivin11 126
Moby_Vic 126
BigMerc96 124
Chaplian 115
mdnos 97
Ezbok58a 94
a_d_a_m 92
Ponyguy 91
