#1891344 - 10/23/09 06:08 PM thermostat housing won't seal!!!!!!
mentalheaded Offline
Loc: Silver lake.....WA
I replaced my thermostat 180 and also got a new thermostat housing and o ring.i put it all back toghter and it leaking out between the manifold and housing have taken it apart numerous time and it won't seal any suggestions.Composite manifold and i don't think it cracked?????????
2000 CVPI Former Seattle PD Supivisors 72000 Miles
J-Mod,Zip tube,R-1 rotors and performance friction pad's,Track-lok c kit clutches 3.73 gears,hole sawed air box,Instaled Henious control arm's 7/30/2010!
#1891348 - 10/23/09 06:11 PM Re: thermostat housing won't seal!!!!!! [Re: mentalheaded]
Colt45 Offline
less is more�
Loc: Moses Lake, WA
Take a closer look. Are you sure it is not cracked?
-Colton
2003 Ford Crown Vic PI, 103k "Th-wacker"
#1891438 - 10/23/09 08:48 PM Re: thermostat housing won't seal!!!!!! [Re: Colt45]
LTDteether Offline
When I took my thermostat out, I could see that the support had receded further into the housing and would no longer support the thermostat flange to provide a seal. It was easy to see that it was cockeyed when I was looking for the problem. I would bet you have the same problem. Mine got worse when I took it off and tried to seal it again. At first, it sealed itself when it got warm.
There is no fix to this problem, that I was able to conjure up, except a new manifold. Leaks tend to develop around the bolts too. I am sorry I don't have better news.
'99 GM GS HPP.
#1891488 - 10/23/09 09:55 PM Re: thermostat housing won't seal!!!!!! [Re: mentalheaded]
gord_bolton Offline
Loc: Saskatoon, Saskatchewan
Is the new thermostat housing the same as the old one?
You put the new O ring on top of the thermostat?
#1891573 - 10/23/09 11:10 PM Re: thermostat housing won't seal!!!!!! [Re: mentalheaded]
larryo340 Offline
Loc: Long Island
That happened to another members car that turned out to be a small crack in the thermostat area of the intake. Once the thermostat housing was tightened it would start to leak. It was hard to spot with the thermostat out, but it was the cause of the leak.
MOD List for MGM
...Marquis sold frown
#1891772 - 10/24/09 07:17 AM Re: thermostat housing won't seal!!!!!! [Re: larryo340]
98P73_IRAQ Offline
install a thicker O ring and make a gasket for the tstat hosing and put a very little RTV layer both sides if you found a crack.
#1891777 - 10/24/09 08:26 AM Re: thermostat housing won't seal!!!!!! [Re: 98P73_IRAQ]
Dentman Offline
Loc: North East
This happened to a coworkers Vic , we used a fair amount of RTV sealent and it's now roughly 6 months latter and he's still rolling leak free. Without doubt he's on borrowed time though , but it him back up and running when money was tight.
#1893525 - 10/26/09 09:10 PM Re: thermostat housing won't seal!!!!!! [Re: Dentman]
LTDteether Offline
A thicker oring will probably just push the t-stat support into the manifold even more.
'99 GM GS HPP.
#1893740 - 10/27/09 01:55 AM Re: thermostat housing won't seal!!!!!! [Re: LTDteether]
I appreciate all the help money is tight no work around here!I was planing on a pi manifold swap now it will be sooner than later.
#1893746 - 10/27/09 02:13 AM Re: thermostat housing won't seal!!!!!! [Re: mentalheaded]
Colt45 Offline
less is more�
Loc: Moses Lake, WA
I hear you there.
-Colton
#1896806 - 10/30/09 01:25 PM Re: thermostat housing won't seal!!!!!! [Re: Colt45]
chipdog4 Offline
Loc: SouthWest Indiana
I had that problem with mine and my younger brothers Grand Marqs.
The new o-ring was a smaller overall diameter, by a very small amount. Re-used the old o-ring with no problems.
Dad runs an auto parts store and has since found a different supplier to get those o-rings.
Changed the antifreeze in our van w/ 5.4 and the new o-ring sealed it good.
99 LSE clone
#1896854 - 10/30/09 02:17 PM Re: thermostat housing won't seal!!!!!! [Re: chipdog4]
Brad_Johnson Offline
Loc: Lubbock, TX
Easy solution - use an OEM o-ring.
Brad
2002 LX Sport (P74) in Silver Frost Metallic.
Mods: Edelbrock IAS shocks. Michelin MXV4 235/55/17. 700w Crossfire OFIS (Old Fart Irritation System). Airbox horn removed. Headlight relay kit. J-Mod, finally - Yay!
...and officially DOA as of 12/21/2009 due to an elderly driver who thought red lights were just an amusing suggestion.
#1898551 - 11/02/09 12:33 AM Re: thermostat housing won't seal!!!!!! [Re: Brad_Johnson]
delzy Offline
Loc: Billings, MT - The Last, Best ...
Watch for a miss when it leaks from there it gets down the number 5 or 6 plug and corrodes the spring connection at the end of the COP.
My fleet at it's max.
#1917967 - 11/23/09 05:06 PM Re: thermostat housing won't seal!!!!!! [Re: LTDteether]
P71_Vic Offline
Loc: Burke County, North Carolina
Nice ride Colt
x3,..this is one of those times when I wished the goose neck (water inlet) had a flange around the entire surface so a man could use an O-ring AND a gasket if needed. But mine turned out to be a cracked intake.
A dozen people other than myself never saw the crack, but it was there, and very apparent when my crossover shot its wad.
_________________________________________________________
Long View, NC P.D. Decommissioned in Dec. '08-Purchased in January, '09 with 71,200 miles,
3:55 gears, K&N, FlowMasters, Stainless tips, Dorman intake,
Paint, Tuck, Kenwood head unit, Front end tuner mesh, Accel Super Coils cool
#1918126 - 11/23/09 08:43 PM Re: thermostat housing won't seal!!!!!! [Re: P71_Vic]
And this is why you DO NOT change the thermostat on a all Nylon intake unless it is massivley failing.
2004 Crown Vic LX SOLD!!
2 registered (RipWixomAssembly, Swirlsound), 104 Guests and 12 Spiders online.
Traffic22 15
