#1876862 - 10/06/09 11:44 AM Gas pump keep shutting off when filling up.
gt89mustang Offline
Loc: NJ
I have an 05 crown vic with 14k miles on it. The last 2-3 times I went to fill up the gas pump kept shutting off like the tank was full. The last time was the worst when It would barely go 1/4 of a gallon at times before clicking off. This was also at 2 different gas stations and 3 different pumps so Im pretty sure its my car.
Any ideas? Could the vent line be clogged or something in the filler line be hung up? I did a visual check but theres not much to see.
'05 Crown Vic sport
#1876941 - 10/06/09 01:32 PM Re: Gas pump keep shutting off when filling up. [Re: gt89mustang]
SCHALLZ Offline
Loc: La Crosse WI, USA
i would say vent line
#1876949 - 10/06/09 01:39 PM Re: Gas pump keep shutting off when filling up. [Re: SCHALLZ]
galaxy500 Offline
Loc: upstate NY
I've got same car ( 05CV w 6k miles) with same problem.
Mine sat for nearly 3 years beforee I got it with 2400 miles so I thought that was the problem.
First tank filled normally, since then it's been start/ stop.
We ccould both use some guidance on fixing this.
#1876951 - 10/06/09 01:45 PM Re: Gas pump keep shutting off when filling up. [Re: galaxy500]
Rizzo Offline
J-MOD Master
Loc: Romulus,MI
"Laptop" under trunk.
Remove lines and clear with compressed air.
You want to clear the lines running thru it, Not to and from it if you know what I mean.
The Jmod video is done! LINK!
#1876969 - 10/06/09 02:09 PM Re: Gas pump keep shutting off when filling up. [Re: Rizzo]
Mileaway Offline
Loc: Sacto. Calif.
check emission cannister black box under the trunk
check the hoses [2]and if necessary - the solenoid inside the box
may be just a clogged hose
#1877156 - 10/06/09 06:26 PM Re: Gas pump keep shutting off when filling up. [Re: Mileaway]
gord_bolton Offline
Loc: Saskatoon, Saskatchewan
Sand in the solonoid attached to lines and black box under trunk.
Blow out the line to nowhere and the solonoid with compressed air.
#1914104 - 11/18/09 03:55 PM Re: Gas pump keep shutting off when filling up. [Re: gord_bolton]
galaxy500 Offline
Loc: upstate NY
Need to get to this job before th 4eground gets too cold.
Do you mean the black box attached to the bottom of the gas tank?
Or do I need to look under the trunk liner?
Help appreciated.
#1914106 - 11/18/09 03:56 PM Re: Gas pump keep shutting off when filling up. [Re: gord_bolton]
galaxy500 Offline
Loc: upstate NY
Need to get to this job before the ground gets too cold.
Help appreciated.
#1914125 - 11/18/09 04:25 PM Re: Gas pump keep shutting off when filling up. [Re: galaxy500]
Rizzo Offline
J-MOD Master
Loc: Romulus,MI
Under the trunk.
#1914246 - 11/18/09 07:26 PM Re: Gas pump keep shutting off when filling up. [Re: Rizzo]
galaxy500 Offline
Loc: upstate NY
You mean not on the bottom of the gas tank?
Under the trunk liner?
#1914369 - 11/18/09 09:43 PM Re: Gas pump keep shutting off when filling up. [Re: galaxy500]
Codyy Offline
Fearless Leader
Loc: Up North Eh
#1914402 - 11/18/09 10:15 PM Re: Gas pump keep shutting off when filling up. [Re: Codyy]
Rizzo Offline
J-MOD Master
Loc: Romulus,MI
YEah man... Thats the bottom of the trunk, thats not the gas tank .. \:D
#1914703 - 11/19/09 07:43 AM Re: Gas pump keep shutting off when filling up. [Re: Rizzo]
galaxy500 Offline
Loc: upstate NY
Thanks.
One of the reasons I'm not a mechanic
#1914746 - 11/19/09 10:12 AM Re: Gas pump keep shutting off when filling up. [Re: galaxy500]
Rizzo Offline
J-MOD Master
Loc: Romulus,MI
Well learn ya man \:D
#1914754 - 11/19/09 10:31 AM Re: Gas pump keep shutting off when filling up. [Re: Rizzo]
johnb Offline
Loc: Fl. U.S.A.
Had the very same problem with my 05 CV sport. After putting the pump nozzle all the way in, lift it up about 2-3 inches. Don't know why but the tank fills normally this way.
JB
11 registered (pintobean, KayTar, Nick_03_p71, hischuckness, Ltd4all, HarrisonCreek, 1 invisible), 77 Guests and 14 Spiders online.
a_d_a_m 189
Ezbok58a 165
BigMerc96 147
charlieD 146
Ponyguy 118
dpk 115
White99MGM 104
SocalSam 86
Moby_Vic 82
reminc70 70
