Page 1 of 3 123>
#1916992 - 11/22/09 11:59 AM 2004 Exhaust manifold leak .
AKA_Rizzo Online   content
Loc: Romulus,MI
I have to actually get under the car to see exactly whats going on here, But a friends 2004 has a drivers side exhaust leak.
He's been quoted $1200 for a new head and one new manifold... I think that stinks.
What are the visible signs of a cracked head ?
If I want to drill,tap and rebolt his manifold what should I know about this before doing it ?
To help spot the leak areas I want to run some Seafoam thru his car and watch for where the smoke comes from.
Anymore ideas or thoughts on this ?
J-mods completed : 9
Jmodded 2002 P71. Headlight relay upgrade by BH1976 . Super 44's w/ turn downs,Welded by Interceptor09
What I did during my summer vacation. Signature by Ventana 13mm Socket Travel Photos
#1916998 - 11/22/09 12:13 PM Re: 2004 Exhaust manifold leak . [Re: AKA_Rizzo]
Michigansquadcar Offline
Loc: Southeast michigan
Its a REAL bear of a job. What happens is the exhaust manifold studs break off. Occasionally they will break leaving the surface of the stud sticking out of the head (leaving something to grip onto), BUT most of the time they break flush or underneath the surface of the head.
There may not be room to get a drill in there on a Crown Vic. My current project is a V10 F250 with 4 studs broken on both heads. They are broken below the surface of the head. I tried to drill x1 hole and use an extractor to get it out. After breaking the extractor I had the truck towed to a local shop for them to deal with it. This is the first project I "Gave Up" on in years.
Anyways, good luck
http://www.ford-trucks.com/forums/859392-broken-exhaust-studs-time-to-get-at-it-info.html
#1917002 - 11/22/09 12:19 PM Re: 2004 Exhaust manifold leak . [Re: AKA_Rizzo]
larryo340 Offline
Loc: Long Island
I think that if the car is running fine with the exception of the exhaust leak I would doubt that the cylinder head is cracked. My moneys on the manifold being the only problem, and if I'm right that shop knows that the manifold bolts to the head really suck on a 4.6 and break just went with the "easy" job.
I would take a look first, and not use Seafoam just yet. Use a small mechanics mirror to see under and around the manifold.
HPP wheels and Yokohama Advan S4's for summer/Steelies and Winterforce for winter/F&R drilled and slotted rotors/added OEM dual exhaust/OEM Marauder tips/ OEM Marauder spoiler/'03+ rear lights/'06+ rear trunk panel/Color matched belt moulding/LED CHMSL/'03+ headrests custom redone to match my seats/50% tint/ '02 OEM head unit/Alpine speakers 6X9 rear,5X7 front/Alpine V-power 4 channel amp/Sirius powered sub/Sirius Sportster 4 w/inside windshield mounted antenna/Silverstar Ultras/OEM Daytime Running Light module/Self installed heated mirrors/'03+ ashtray w/powerpoint/Self installed Ford remote start w/keyless entry/Scott Hrbacek custom White Face gauges with SMD LED lighting/PlasticDip black painted grill/Tossed open rear w/2.73's and put in rebuilt trac-loc w/3.27's
#1917011 - 11/22/09 12:37 PM Re: 2004 Exhaust manifold leak . [Re: larryo340]
Loc: Romulus,MI
Thanks guys, I'll look into both the bolt procedure and the "Mechanics want the easy way out" theory, which I firmly buy into.
A cracked head ? C'mon really ..
If it's of any use to this, When he bought the car it came with 3 cats. Two cats on this side and one on the other ..
I have no idea
#1917018 - 11/22/09 12:44 PM Re: 2004 Exhaust manifold leak . [Re: AKA_Rizzo]
I doubt the head is cracked. I would guess they quoted a new head due to broken exhaust manifold studs in the head.
#1917033 - 11/22/09 01:04 PM Re: 2004 Exhaust manifold leak . [Re: Michigansquadcar]
Colt45 Offline
less is moreİ
Loc: Moses Lake, Wa
Let me guess, it was the rear cat that was missing? Im about to get my driver rear cat replaced by Ford because it is rattling. They already did the passenger for rattling. They had a bad run of rear catalysts in 2004.
Edited by Colt45 (11/22/09 01:06 PM)
-Colton
No longer Pant(her)-lessİ
2004 Ford Crown Victoria LX <- link dead due to script kiddie. Will rebuild in time..
#1917046 - 11/22/09 01:16 PM Re: 2004 Exhaust manifold leak . [Re: Colt45]
frankthefordman Offline
Loc: grandview
i have never evere seen a cracked head on a 4.6l well the one thay shot thou the floor with a shot gun
but the studs do brake alot sometimes if you have a 90deg drill and rev drill bits thay will turn right out other wise you will need to drill out not fun on cv
and cold ford had a bad run on cats for most of the cv and gm cars the is a tsb for rattle and just so every one knows cats are coverd for 8yrs and 80k mi on all cars
96 gm swaping parts for my 96 pi for the best of both worlds comfort and perfomance
#1917055 - 11/22/09 01:30 PM Re: 2004 Exhaust manifold leak . [Re: frankthefordman]
Colt45 Offline
less is moreİ
Loc: Moses Lake, Wa
Yeah. Do you know how long it typically takes to get a cat or something like that after it is ordered? They ordered it Thursday.
-Colton
#1917059 - 11/22/09 01:34 PM Re: 2004 Exhaust manifold leak . [Re: Colt45]
Loc: grandview
well most of the time it is the next day but sometimes up to a week or so when i was at ford 3 to 5 days were i worked in trycites but you never know
#1917069 - 11/22/09 01:38 PM Re: 2004 Exhaust manifold leak . [Re: frankthefordman]
Colt45 Offline
less is moreİ
Loc: Moses Lake, Wa
Bleh. I need it done Monday. Going on a 2000 mile trip.
-Colton
#1917070 - 11/22/09 01:42 PM Re: 2004 Exhaust manifold leak . [Re: Colt45]
Loc: Romulus,MI
I don't think he has any desire to replace the missing cat but he does want the system to be balanced. ;\)
#1917071 - 11/22/09 01:42 PM Re: 2004 Exhaust manifold leak . [Re: AKA_Rizzo]
Colt45 Offline
less is moreİ
Loc: Moses Lake, Wa
Hehehe. Only reason Im replacing is because it is free. Otherwise it would be gone.
-Colton
#1917074 - 11/22/09 01:46 PM Re: 2004 Exhaust manifold leak . [Re: AKA_Rizzo]
Loc: grandview
you can always call on monday and see if it is in and if thay have time to do it on monday
i would say if he wants it balanced then the other one need to find a way off the car
it would cost less that way
but if he lives were thay may do a sniffer test it may not pass
#1917075 - 11/22/09 01:51 PM Re: 2004 Exhaust manifold leak . [Re: frankthefordman]
Loc: Romulus,MI
No sniff in Mich ! .....igan ..
#1917082 - 11/22/09 01:58 PM Re: 2004 Exhaust manifold leak . [Re: AKA_Rizzo]
gord_bolton Offline
Loc: Saskatoon, Saskatchewan
The stick welder is your best friend.
Stick the stick to the stud and turn it out.
Page 1 of 3 123>
Moderator:  Liquid, JohnG, dRock96Marquis
Hop to:
Google Search!
Google
Tire Rack!
The Tire Decision Guide
8 registered (Land_Shark, AKA_Rizzo, Jimsss, jimh874, whitela3, Big_D_00p71) and 64 anonymous users online.
Amazon!
September
Su M Tu W Th F Sa
1 2 3 4
5 6 7 8 9 10 11
12 13 14 15 16 17 18
19 20 21 22 23 24 25
26 27 28 29 30
