#1917027 - 11/22/09 12:53 PM
Flashing O/D light
AKA_Blackcvpi
There are two Women in my life, and there both named Victoria.
Loc: East Pasadena CA
ok.....i used the search but i didn't find anything that really helped.
So yesterday i was heading to Los Angeles and stopped about 20 miles from my house to have the car washed. After its done i get in and start it up. Right away the OD light starts flashing. It was not doing that before i went to the car wash. So i drove away and went down a side street. I turned the car off then back on.....no more flashing light.
So i get back on the freeway, about 45 miles later it starts flashing again. So i exit the freeway park and turn the car off and restart it. Again the light is not flashing. So i get out and go do what i had to do in Los Angles. Come back mabey 15 min later start the car and still no flashing light.......it never came back on the whole 90 mile drive back to my house on the freeway.
Any Input?
99 CVPI with SAP, Black, Former LA Sheriff demo unit, Heinous rear control arms from ADTR.net, Headlight relay by BH1976 05 Mercury Grand Marquis LS, Silver Birch, Bumper Tuck. Ported Plenum, 06 CVPI intake tube, Heinous Rear Arms, all from ADTR.net. Howard Stern for President!
#1917034 - 11/22/09 01:05 PM
Re: Flashing O/D light
[Re: AKA_Blackcvpi]
frankthefordman
Loc: grandview
the od light is like the check eng light if you pull codes it may show a trans code then post code
96 gm swaping parts for my 96 pi for the best of both worlds comfort and perfomance
#1917036 - 11/22/09 01:07 PM
[Re: AKA_Blackcvpi]
Colt45
less is moreİ
Loc: Moses Lake, Wa
Flashing OD is transmission fault. Since it happens as soon as you start it up, Im a betting it is electrical related. Did you wash under the hood too?
Edited by Colt45 (11/22/09 01:07 PM)
-Colton No longer Pant(her)-lessİ 2004 Ford Crown Victoria LX <- link dead due to script kiddie. Will rebuild in time..
#1917037 - 11/22/09 01:08 PM
[Re: frankthefordman]
AKA_Blackcvpi
How do i pull the code.......i had a scanguage II hooked up when it was flashing......i tried to pull the codes with it but it said zero codes were found.
#1917040 - 11/22/09 01:10 PM
[Re: AKA_Blackcvpi]
AKA_Blackcvpi
no under hood wash, I am not a big fan of that....but im sure they did the under body spray as it went down the wash line at the car wash. I kinda was thinking maybe some water got into one of the connections or something. By the way the transmission shifts perfect all the time......flashing or not.
Edited by AKA_Blackcvpi (11/22/09 01:12 PM) Edit Reason: spelling
#1917044 - 11/22/09 01:13 PM
[Re: AKA_Blackcvpi]
Colt45
less is moreİ
Loc: Moses Lake, Wa
It may not have set a code yet? I dont know.
#1917051 - 11/22/09 01:18 PM
[Re: Colt45]
AKA_Blackcvpi
I'll drive it some more today and see what happens, if anyone else has any idea's......post away!!
#1917052 - 11/22/09 01:22 PM
[Re: AKA_Blackcvpi]
frankthefordman
Loc: grandview
it may be the scanner some codes dont come up for after market scaners but i think colt is right prob elc prob and maybe conector to the range selector on the side no the trans
#1917058 - 11/22/09 01:32 PM
Colt45
less is moreİ
Loc: Moses Lake, Wa
Yeah, you might try unplugging the elctrical connectors and blowing them out with air. Repack them with dielectric grease and see what happens.
#1917060 - 11/22/09 01:34 PM
AKA_Blackcvpi
it may be the scanner some codes dont come up for after market scaners but i think colt is right prob elc prob and maybe conector to the range selector on the side no the trans Range selector.....that's the sensor that tells the transmission what gear to go in right? what side of the transmission is that on?
#1917065 - 11/22/09 01:37 PM
[Re: AKA_Blackcvpi]
frankthefordman
Loc: grandview
its on the drivers side were the shifter linkage is on the trans may want to let it cool as it is next to the exhaust pipe dont want to burn your self
#1917068 - 11/22/09 01:38 PM
AKA_Blackcvpi
OK.......thanks guys. I'm gonna go check it out right now. I'll let you know what i find.
#1917098 - 11/22/09 02:14 PM
[Re: AKA_Blackcvpi]
AKA_Rizzo
Loc: Romulus,MI
I had a flashing OD light after some really heavy rains.
After I had a trans shop pull the code I was told it was a "Tran fluid high temp" code. But the guy and I quickly agreed that was crap as my fluid was not hot because I lived close.
Turns out the temp sensor which is on the passenger side of the trans is pushed up from the VB side during assembly.
So I unplugged the connector to it, CRC non residue contact cleaner, let it dry. This removed some green from the pins.
Dielectric greased the OD part of the connection and plugged it back in.
OD flash gone.
#1917161 - 11/22/09 04:23 PM
[Re: AKA_Rizzo]
AKA_Blackcvpi
So when i went to start the car to move it so i can get underneath it and the O/D light starts flashing right away. I had not driven the car since yesterday. I move the car, turn off the engine and restart it......lite is gone.
So i cleaned and greased the gear range selector and the trans temp sensor. The grease in the temp sensor was almost all dried out. Cleaning the terminals on the trans sensor it's self is pretty challenging. The range selector looked OK. Took it for a 6 mile test drive on the freeway and streets in stop and go traffic. So far so good no flashy...lol. Hopefully its gone for good.
Thank you to all who contributed .
Matt.....AKA_Blackcvpi
#1917169 - 11/22/09 04:38 PM
[Re: AKA_Blackcvpi]
Colt45
less is moreİ
Loc: Moses Lake, Wa
What you probably did was the OSS sensor, not the trans temperature sensor which is inside the transmission. :P Glad it appears to be working!
Edited by Colt45 (11/22/09 04:38 PM)
Moderator: Liquid, JohnG, dRock96Marquis
The Tire Decision Guide
