#1947334 - 01/03/10 10:52 AM "Ford" Emblem on steering wheel.
Braxton Offline
Loc: Port Saint Lucie
Is this removable/replaceable? Mine seems to be caved in, as if someone pushed on it too hard...
04 CVPI, 119xxx MILES
#1947335 - 01/03/10 10:56 AM Re: "Ford" Emblem on steering wheel. [Re: Braxton]
MadMax04 Offline
Not allowed to buy and sell on CVN
Loc: Wisconsin
As far as I know they aren't "interchangable". I think they are put in with some adhesive. Mines kind of the same way, like its pushed in in the middle.
2004 CVPI
So many mods to install in spring. So many.
#1947337 - 01/03/10 10:57 AM Re: "Ford" Emblem on steering wheel. [Re: MadMax04]
SHAP357 Offline
Loc: Hartford, CT
They are just clipped in. Replacements can be found on ebay.
1997 CVPI - ex. VA State Police
2006 CVPI - ex. US NAVY NCIS
Trunk Tray/Engine Covers//Tremcos- PM for details
#1947358 - 01/03/10 11:39 AM Re: "Ford" Emblem on steering wheel. [Re: SHAP357]
martz0r Offline
Loc: Punta Gorda, FL
Replaced mine. Had to disconnect the horn because it is now stuck so be careful not to push too hard when installing a new one.
'07 Durango HEMI Limited 4x4
#1947385 - 01/03/10 12:34 PM Re: "Ford" Emblem on steering wheel. [Re: martz0r]
WSTRLNG Offline
Loc: Plymouth, New Hampshire, USA
Victor WeSTeRLiNG
2005 Crown Vic LX 47K (Former Granny Car).**2006 Mustang Bullitt wheels and Hankook Ventus ST 255/50/17 tires. - **F/R Cross-drilled/slotted rotors. **2010 3.55 TracLok rear. **SCT iTSX adjusted speedometer.
**Removed airbag warning labels from the sun visors. - **Bumper tuck. - **Class III trailer hitch. - **Front/Rear OEM Mudflaps - **Flip-key mod. - **Custom subwoofer under rear shelf. - **Trunk torsion bar delete for struts.
#1947602 - 01/03/10 06:57 PM Re: "Ford" Emblem on steering wheel. [Re: WSTRLNG]
bobb Offline
I am pretty sure that [the inward curve]is the way it is supposed to be and is not damaged.I thought the same thing till I noticed the middle was actually flush with the horn pad on my 2003 cvpi.Anyone else ???
#1947648 - 01/03/10 08:06 PM Re: "Ford" Emblem on steering wheel. [Re: bobb]
WSTRLNG Offline
No. The logo is supposed to have a cupped shape.
The oval indentation in the airbag cover has a "+" raised inside it. There are 2 slots on top and 3 slots on the bottom for the metal badge to crimp into. What I did to make sure I didn't "F" it up was to "slightly" bend inward the bottom of the tabs. I then placed the new badge over the slots and used the bottom of my palm to push it in while wiggling it to try to make the tabs bend inward.
When I was looking at how I was going to remove the badge, I had no idea how it was held in so I ended up taking the ENTIRE thing apart (horn, airbag charge, airbag) just to find a lexan plastic behind the cover with melted stubs holding it on to the airbag cover. Behind was the 2 contacts for the horn switch. Needless to say, I was very P/O'd to find I did all that for nothing. Especially when I was VERY careful when disconnecting the airbag wires (didn't want ANY static shock). Always had it pointing sideways from me.
BTW, the airbag charge appears to be nothing more that just a steel housing with what looks like thick "brillo pad". It buts up to the airbag itself. Never unbundled the airbag. It just kept it's bundled shape and I carefully put it back into the cover.
So, I just used a knife and pried the old badge off and said "Oh $#it!, that was it".
Sorry to hear about your horn getting stuck. Looks like one of the tabs didn't bend in right. Did you not bend the tips in first to help them push in easier? If you can remove it without damage, you should try to re-insert it.
Edited by WSTRLNG (01/03/10 08:21 PM)
Victor WeSTeRLiNG
#1948018 - 01/04/10 11:36 AM Re: "Ford" Emblem on steering wheel. [Re: WSTRLNG]
bobb Offline
My point is.The original poster complained of a caved in emblem/logo.Mine is curved in.Yours is cupped in.Different descriptions,same thing.Normal as far as I can tell.
#1948231 - 01/04/10 05:48 PM Re: "Ford" Emblem on steering wheel. [Re: bobb]
WSTRLNG Offline
It's supposed to be cupped outward, like any other Ford badge on the outside of the car.
If you like your curved/cupped in then fine, but if you were to order an new one, you would see the difference.
Victor WeSTeRLiNG
Moderator:  BigMerc96, Quasar
1 registered (merk44z), 230 Guests and 15 Spiders online.
a_d_a_m 167
dpk 155
BigMerc96 128
Moby_Vic 114
WSTRLNG 85
reminc70 78
Ponyguy 75
RF_Overlord 65
Bellwestern80 58
SocalSam 48
Osu
Osu
