#1952607 - 01/10/10 11:40 AM **Color Codes for Radio Wiring**
brodyman Offline
Loc: Orlando, FL
I am installing a new head unit in my car and i ran into some issues. Whenever i turn off the car the presets and the clock get reset. Through some research i realized that it has something to do with the constant 12v wire. So now I'm thinking that the wiring harness i bought isn't connecting that constant 12v wire, which is yellow, to the existing wiring in the car. So my plan is to bypass the harness and hook directy to the existing car wire.The problem is none of the car wires are the same color as the new radio wires, does anyone know what each colored wire on the existing car wiring is for? I have a 2005 Mercury Grand Marquis
2005 Grand Marquis-Black, "Cat"-less exhaust, flowmaster 50 series, Marauder chrome tips, 15% Tint all around,50% on windshield,K&N Drop in Filter,Marauder Corners,Black Grille,Police Caps,Sony Headunit, Autotek MX "Mean Machine" 15", Alpine M-1000 pro-grade amplifier, ported box, 65K miles
#1952652 - 01/10/10 12:44 PM Re: **Color Codes for Radio Wiring** [Re: brodyman]
GearGuy2001 Offline
Loc: South Beloit,IL
There should be a yellow wire on your factory harness for Constant 12v
I know with my 97 there is 2 harnesses so check both of them (one is speakers and other is power)
According to this Link
http://www.modifiedlife.com/2002-mercury-grand-marquis-car-stereo-wiring-schematic/
The constant 12v in a 2002 is Violet/Light Blue, you can confirm this with a multimeter.
97 Mercury Grand Marquis LS
Performance: Magnaflow Mufflers, 180* Thermostat, 22C Spark Plugs, Zip Tube, Marauder Airbox, XCal 2 w/ 93 Octane Tune, FRPP Spark Plug Wires, JMod, 70mm TB with P&P Plenum
Appearance:Alpine CDA-9856, American Bass SQ780, Image Dynamics CTX65CS, Dynamat Xtreme, Marauder Exhaust Tips, Autometer Tach on A-Pillar Mount, 2 RD Audio Alphamax 15s in 9.1 Cubes @ 35Hz, Team Cactus Sounds 5kw
#1952670 - 01/10/10 01:02 PM Re: **Color Codes for Radio Wiring** [Re: GearGuy2001]
brodyman Offline
Loc: Orlando, FL
yeah i'm going to go and try that and see how it works. my car only has a single harness...
#1952877 - 01/10/10 06:15 PM Re: **Color Codes for Radio Wiring** [Re: brodyman]
brodyman Offline
Loc: Orlando, FL
multimeter shows no wire is hot when the car is off. i'm wondering if the old unit was using flash memory to keep the time and presets.
I am just going to run a wire to the cigarrette lighter
#1952925 - 01/10/10 07:05 PM Re: **Color Codes for Radio Wiring** [Re: brodyman]
TechnoWeenie Offline
Loc: The perimeter
check for blown fuses.
#1952978 - 01/10/10 08:04 PM Re: **Color Codes for Radio Wiring** [Re: TechnoWeenie]
Fhajad Offline
Loc: Shelbyville, IN
Don't piggy back off the cig lighter! That's a TERRIBLE idea and only gonna lead to problems!
Run dedicated lines if you have to, NEVER piggy pack one power hog off another.
Jeeps have fun, too!
Pardon my dust while I take into the trails for now. wink
#1953096 - 01/10/10 09:45 PM Re: **Color Codes for Radio Wiring** [Re: Fhajad]
brodyman Offline
Loc: Orlando, FL
like what could happen? isn't the cig lighter a 12V which is also the same amount of the dedicated yellow constant wire, also the cig lighter is on constantly even without the car being on? and what do you mean dedicated lines? Also none of the fuses are blown
#1953139 - 01/10/10 10:31 PM Re: **Color Codes for Radio Wiring** [Re: brodyman]
larryo340 Offline
Loc: Long Island
I'm assuming that you have the standard radio, and here is the schematic and pinout for the connector.
MOD List for MGM
...Marquis sold frown
#1953327 - 01/11/10 05:37 AM Re: **Color Codes for Radio Wiring** [Re: brodyman]
Tracy Offline
Loc: West Bend, WI, USA
I'd match up the colored wires on your connector with the correct wires on the charts larry posted.
You say the yellow wire is the 12v constant, match that up with the correct pin on the connector pinout chart that larry posted and that should solve your problem. Do the same for all the wires on your connector to verify that each wire is going to the correct spot.
May be a dumb question, but are you sure you have the correct aftermarket connector for your year of car??
Most aftermarket connectors have the wires and pins in the right spots to match up with the specific vehicle(s) listed for that connector and head units have wiring diagrams with the wire color, so install is pretty easy.
I'd double check to be sure you have the correct connector for your car and year. A good place to buy aftermarket stereo connectors is http://www.scosche.com even http://www.crutchfield.com
Also check to be sure you have the correct 12v constant wire from your stereo connected to the harness. Sounds dumb, but maybe that simple.
if you still have issues, send me a PM with detailed information on the wire colors and functions from the harness and the head unit and I will try to help you. Also if you have it the manufacturer of the connector and part #, just so i can verify for myself that you have the correct one, not that I give you wrong info and damage something.
Edited by Tracy (01/11/10 05:40 AM)
#1953609 - 01/11/10 02:48 PM Re: **Color Codes for Radio Wiring** [Re: Tracy]
brodyman Offline
Loc: Orlando, FL
I'm thinking the wiring harness is junk, its from walmart. Its not vehicle specific, basically fits all the ford models or what not. I'm going to try and see if i can get the 12v Constant hooked up because that seems to be the only problem.
Edited by brodyman (01/11/10 02:49 PM)
#1953632 - 01/11/10 03:22 PM Re: **Color Codes for Radio Wiring** [Re: brodyman]
brodyman Offline
Loc: Orlando, FL
so i just bypassed the wiring harness and took the yellow wire that is for the constant 12v and put it directly on the purple wire which is for the 12v constant( according to larry's schematic) and.....nothing. At this point the only way i am getting the radio to turn on is if i attach the yellow constant to the red wire( which is power onyl when the car is on) i am super confused
#1953635 - 01/11/10 03:25 PM Re: **Color Codes for Radio Wiring** [Re: brodyman]
larryo340 Offline
Loc: Long Island
Did you put a test light onto that violet factory wire to confirm +12V ?
MOD List for MGM
#1953636 - 01/11/10 03:25 PM Re: **Color Codes for Radio Wiring** [Re: brodyman]
Tracy Offline
If the yellow wire on your harness isn't connected to the 12v constant on your head unit, nothing will happen. Try connecting the 12v constant from your head unit to the 12v constant wire of the car's harness, that should solve your problem.
#1953650 - 01/11/10 03:38 PM Re: **Color Codes for Radio Wiring** [Re: Tracy]
brodyman Offline
Loc: Orlando, FL
Thats exactly what i did, bypass the harness i bought straight to the cars wiring harness and nothing happened
#1953652 - 01/11/10 03:40 PM Re: **Color Codes for Radio Wiring** [Re: larryo340]
brodyman Offline
Loc: Orlando, FL
i did not test the wire once i cut it, but yesterday when i had a voltmeter that i borrowed from a friend no wires were showing hot when the car was off
Moderator:  BigMerc96, Quasar
6 registered (McVic, Interim, cvpi_mark, Y_K, 07LandYacht, Ezbok58a), 35 Guests and 77 Spiders online.
a_d_a_m 213
BigMerc96 148
EZlivin11 105
Chaplian 102
RF_Overlord 99
Moby_Vic 95
dpk 93
charlieD 90
Ponyguy 84
