#1961831 - 01/21/10 09:50 PM neutral safety switch
cfrank Offline
Loc: North Florida
Where is the wiring for the neutral safety switch located? I need to tie into it for a remote start system?
2000 Ford Crown Victoria P71 - Ex jacksonville,Fl PD unit# 160
Check out my ebay items!
#1962030 - 01/22/10 07:49 AM Re: neutral safety switch [Re: cfrank]
Bangster Offline
I didn't hook up anything to the neutral safety switch, and I know that all the testing I did to verify its proper function it wouldn't start unless in park or neutral.
00 Grand Marquis LS Premium - 97 Cougar 4.6 Sport - 89 Cougar LS - 63 Falcon 302 - 82 F-150 - 97 Mark VIII LSC - 2017 Escape SE
#1962039 - 01/22/10 08:06 AM Re: neutral safety switch [Re: Bangster]
cfrank Offline
Loc: North Florida
Okay, I thought that the neutral safety switch may have been a required input for the system to work.
#1962065 - 01/22/10 09:06 AM Re: neutral safety switch [Re: cfrank]
Michigansquadcar Offline
Loc: Southeast michigan
Nope, its already tied into the ignition switch. With a remote start you are just using the ignition switch circuit to start the car. If the car is NOT in park or neutral, the car will not start.
#1962495 - 01/22/10 07:49 PM Re: neutral safety switch [Re: Michigansquadcar]
cfrank Offline
Loc: North Florida
I just looked over the install manual that came with the system and it says: "This wire will test with ground with the gear selector either in PARK or NEUTRAL. This will prevent the vehicle from accidentally being started while in a drive gear. This input MUST rest at ground in order for the remote start system to operate."
It sounds like it is required to be tied in, Or could i save the trouble and just hook that wire to ground?
5 registered (pushrods, Bellwestern80, RF_Overlord, Rainyp71, CrownBen), 242 Guests and 9 Spiders online.
a_d_a_m 165
dpk 153
BigMerc96 128
WSTRLNG 89
reminc70 78
Ponyguy 75
RF_Overlord 70
Bellwestern80 59
SocalSam 47
