#1958493 - 01/17/10 09:16 AM Antifreeze on the spark plugs
TwistedMetalP71 Offline
Loc: New Jersey
I had a misfire on cylinder 5 and 6 so I got new spark plugs and coil on plugs. When I pulled out the coil on plug for cylinder #5 I looked down the little hole where the spark plug sits and I saw theres all this antifreeze in there. I couldn't even see the spark plug.
Does anyone have any idea where this leak is coming from? How is the antifreeze getting in there? I unplugged the battery and changed out the spark plugs and coil on plugs. But when I drove a couple miles the check engine light came back on again because of all the fluid that gets in the spark plug hole.
I also noticed that my car has a plastic intake. I think I read on here that those plastic intakes are known to give problems should I replace it with a metal intake?
1999 Crown Victoria P71
#1958537 - 01/17/10 10:41 AM Re: Antifreeze on the spark plugs [Re: TwistedMetalP71]
Big_Bad_Joe Offline
Loc: Rochester NY
i dont know how but you have been here two years and missed all the intake failure posts... your intake is shot
the antifreeze will screw up that new coil also... stop driving and you need to replace the intake. Just do a search.. tons of information
Underdrives from ADTR.net
#1958538 - 01/17/10 10:41 AM Re: Antifreeze on the spark plugs [Re: TwistedMetalP71]
Bangster Offline
If it is #5 and #6, then it can be the plastic crossover is cracked around the thermostat, the classic plastic cracked across the front failure, leaking from the thermostat housing/neck.
Yes, the all plastic intake has more than a few common failures, and many of them are fixed with the revised intake with the aluminum crossover. My 97 Cougar suffered two ruptured plastic coolant crossovers, and my 2000 GM the rear heater nipple was weeping.
There are aftermarket replacements, but they have quite a few negatives against them, I instead bought a used take off one for my 2000 Grand Marquis for 50 bucks, and I put a PI intake on my 97 Cougar.
1974 Honda cb400
#1958732 - 01/17/10 03:35 PM Re: Antifreeze on the spark plugs [Re: Bangster]
Chase3203 Offline
Loc: South Florida
Sounds like what was happening to me. The intake manifold was leaking and there were stress cracks on the thermostat housing.
2000 Crown Victoria Police Interceptor -
Future Mods: MagnaFlow Direct-Fit Catalytic Converters
Exhaust/Mufflers (Undecided)
#1965295 - 01/26/10 01:21 PM Re: Antifreeze on the spark plugs [Re: Chase3203]
JJackP71 Offline
Loc: Eastern Minnesota, US
cracked manifold I would guess, had the same problem. If you buy a new one make sure it has a metal housing and crossover.
2000 P71 150K (Former Wyoming Highway Patrol car with glasspack exhaust)
#1965296 - 01/26/10 01:22 PM Re: Antifreeze on the spark plugs [Re: JJackP71]
Fordiesel69 Offline
Loc: Erie, PA
VERY common problem. You need to replace the manifold. I recommend the OEM, but if you must by the dorman, they also work well.
Edited by Fordiesel69 (01/26/10 01:23 PM)
-99' Crown Vic Police Interceptor (SAP), 3.55 Trac-Loc(DK), Cloth Interior, Black Honeycomb Grill, Black PI Trunk Bezel, Silverstars, 155K
-00' Crown Vic Police Interceptor (SAP), 3.55 (R2), Cloth Interior, Black PI Trunk Bezel, 03+ Full Wheel Covers, Silverstars, 109K
-96' Lincoln Town Car - Executive Series, 3.08's, White w/ blue leather interior, 155K
-99' Lincoln Town Car - Signature Series, 3.08's, Silver Frost Metallic, 94K
#1965301 - 01/26/10 01:29 PM Re: Antifreeze on the spark plugs [Re: Fordiesel69]
Ask_The_Shack Offline
Loc: Long Island, NY
Yup you got the classic manifold crack.
Good luck bro.
Your path is clear, your duty awaits....
The Blue Falcon
Car pics located here
Fog light pics located here
Find out how to paint your grille here
#1965308 - 01/26/10 01:37 PM Re: Antifreeze on the spark plugs [Re: Ask_The_Shack]
99_03PantherS Offline
Loc: NW side Chicago
Good luck, ive done this at least 5 times. even twice when i was 15.
Jason G. Replaced 1st intake manifold at 15. haha
'03 Marquis: 67K,15.31 @ 91.19, MZT 93 octane tune, P&P Aviator T/B, duals with rear cats missing, 3.27 Trac loc 31 spline rear, sway bars, tints, badgeless grille..blahblah various exterior mods *NEW* Steeda pulleys and Towncar rims
'08 F-450
#1965318 - 01/26/10 01:50 PM Re: Antifreeze on the spark plugs [Re: 99_03PantherS]
Fordiesel69 Offline
Loc: Erie, PA
And on a CV/GM it is very easy. Not so on a town car.
26 registered (09mnsp, cgh0187, BigMerc96, Black_Sunshine, 3 invisible), 89 Guests and 63 Spiders online.
KayTar 587
CNGInterceptor 394
sm41 355
Black_Sunshine 288
BlackVic_P71 284
Ezbok58a 249
ajdereicup 246
Moby_Vic 243
BigMerc96 226
Superhobo 212
