#1966970 - 01/28/10 02:00 PM Change water pump
famcrown Offline
Loc: ct
anyone know how hard or what steps or what tools are needed to change a waterpump on a 1990 crown vic station wagon
coolant is leaking in my car but nothing is dripping and when car is idling, nothing drips or sprays as i went under the car and above and saw nothing. there is coolant around waterpump area behind fan and on sides and undersides of engine casing so i will go with the waterpump?
#1967101 - 01/28/10 04:49 PM Re: Change water pump [Re: famcrown]
Check carefully where the manifold and block meet. They seem to like leaking there as well.
Any water staining around the weep hole in the bottom of the water pump snout?
Alex.
#1968348 - 01/30/10 02:09 AM Re: Change water pump [Re: GM_Guy]
andymac0035 Offline
Loc: Grafton, NH
I agree, check to make sure it's not the intake manifold gaskets before you try changing the waterpump.
I changed the one in my 91' this past summer. There's a lot to it because of everything that's in your way. I took pics that I can post up if you'd like to see what your in for.
Pre-soak all the bolts a lot and be very careful with the waterpump bolts(you reeeeally don't want to snap one). They are all different lengths and need to be kept in order.
1991 Crown Victoria LX
P-74 5.0/AOD
#1968361 - 01/30/10 03:19 AM Re: Change water pump [Re: andymac0035]
TheBlunderbuss Offline
Loc: CHAMPAIGN, IL
Someone did a write-up on their removal.
02/88 LTD Crown Victoria - 860 miles (hehe)
Don't forget that Throttle valve cable clip update!
#1968594 - 01/30/10 03:15 PM Re: Change water pump [Re: andymac0035]
pantera77 Offline
Loc: Buffalo, NY
Yea, they also like to be very corroded and snap off in the block.
#1969280 - 01/31/10 01:25 PM Re: Change water pump [Re: pantera77]
Loc: CHAMPAIGN, IL
Yes.
Also, the studs that hold the power steering pump bracket need to have two wrenches on them - One on the movable nut and one on the nut permanently affixed to the rod.
If you don't, the whole rod will come out and crack the bracket.
This is not good. Try finding another one of those from a non-junkyard source, I dare you!
#1969399 - 01/31/10 04:03 PM Re: Change water pump [Re: TheBlunderbuss]
famcrown Offline
Loc: ct
anyone know how long it would take an experienced mechanic with tools to fix this. i don't want to get ripped off if i decide to take it to a mechanic.
#1969434 - 01/31/10 05:07 PM Re: Change water pump [Re: TheBlunderbuss]
andymac0035 Offline
Loc: Grafton, NH
Yes.
Well, I guess I got lucky, I didn't even know about that going into changing mine. Although I probably would have stopped if I saw the nut taking the stud with it as I turned it (I hope). But I sprayed stuff down days in advance before starting the job.
Here are some pics I took during the job. This gives an idea of just how many things are tied in with the waterpump
Here you can see I have the waterpump bolts laid out in order.
New pump in place
P-74 5.0/AOD
#1969550 - 01/31/10 08:34 PM Re: Change water pump [Re: andymac0035]
famcrown Offline
Loc: ct
thanx this is very helpful.
#1969933 - 02/01/10 10:12 AM Re: Change water pump [Re: famcrown]
Jeff2 Offline
Loc: Cincinnati, Ohio
When my water pump died, it was very obvious because coolant started shooting out of the weep hole on the bottom when I shut off the engine at a rest stop. When it was running, it wasn't leaking much and temperature was normal.
1991 Crown Victoria LX (sold) - Had something like 160k miles on the original 302W and AOD trans. The odometer gears broke at a bit over 100k miles, so miles were calculated by gallons of gas times prior average MPG.
#1970049 - 02/01/10 01:57 PM Re: Change water pump [Re: Jeff2]
famcrown Offline
Loc: ct
do i have to take off the radiator, fan, ac compress, and other stuff attached or what are the main things that have to be removed to get to the water pump also where is the weap hole
Edited by famcrown (02/01/10 02:08 PM)
#1970133 - 02/01/10 04:29 PM Re: Change water pump [Re: famcrown]
Weephole is on the bottom of the waterpump snout.
You need to remove the fan clutch, fan shroud, unbolt the brackets for the a/c and lay it to the side, undo the power steering and alternator brackets and lay them to the side. Then you have full access.
Alex.
#1970298 - 02/01/10 08:05 PM Re: Change water pump [Re: GM_Guy]
mikei1983 Offline
Loc: Copperas Cove, TX
There is a good amount of work involved, but it isn't that bad. I took mine off in about an hour (or less) taking my time. At the same time mine had a lot of grease and grime built uo around it!
Finally getting my short block put together!!!
JE 4.030 Flat Tops w/ Seal Pro file fit rings (and stickers!) $475.00 Brand New
1991 302 'roller motor.. Needs freshening, but runs $150.00
#1970520 - 02/02/10 01:51 AM Re: Change water pump [Re: mikei1983]
Loc: CHAMPAIGN, IL
Ahem writeup. Ahem.
#1970547 - 02/02/10 02:53 AM Re: Change water pump [Re: TheBlunderbuss]
andymac0035 Offline
Loc: Grafton, NH
Ahem writeup. Ahem.
Perhaps this will help.
how-to linky
P-74 5.0/AOD
5 registered (RapidRoy, Rainyp71, White99MGM, 2 invisible), 65 Guests and 13 Spiders online.
a_d_a_m 193
Ezbok58a 161
charlieD 145
BigMerc96 142
Ponyguy 119
dpk 113
White99MGM 102
SocalSam 85
Moby_Vic 81
reminc70 70
