Page 1 of 1 1
#1969451 - 01/31/10 05:35 PM Newer Motor.....
LEGACY_X Offline
Ok so my 99 CVPI is getting old with 230,xxx on the clock im in the market to find a newer motor to breath some life back into the car.
Any one know where I could find a decent deal in the KY, OH, IN area that I could go to the seller and swap motors there as I cant afford the shipping and dont have the means to swap it myself.
Any help would be appretiated
'05 CVPI
63,xxx miles and in excellent condition
#1969453 - 01/31/10 05:39 PM Re: Newer Motor..... [Re: LEGACY_X]
Ethan Offline
Loc: Agoura Hills, California (SoCa...
I'd say that unless your motor has a specific problem, just keep it.
2003 Police Interceptor
2004 Engine, 3.27 Open, Custom Cold Air, R1Concepts Slotted Rotors with Hawk HPS Pads, KYB Gas-A-Justs, Glasspacks, and 17" Mustang GT Wheels.
164,*** Miles
#1969456 - 01/31/10 05:42 PM Re: Newer Motor..... [Re: Ethan]
LEGACY_X Offline
well it has a misfire in cylinder 4 that is eityher a burnt cylinder or an imjector it leaks antifrezze pretty bad havnt found the leak yet and my father in law (was a mechanic for about 20 years) says it sounds like it needs about $600 worth of other work...
'05 CVPI
#1969482 - 01/31/10 06:55 PM Re: Newer Motor..... [Re: LEGACY_X]
martz0r Offline
Loc: SW FL
check out
http://www.car-part.com
Has engines from places all over the US. Just sort by distance.
'03 P71 w/ 137k on body ~ newer trans, and motor from an '04 ~ Former Fort Worth, TX PD Unit
Steeda Underdrives | Steeda TB Spacer | J-Mod | Mach 1 Lip | Slotted rotors | 5k HIDs | GT wheels | Explorer OHC | etc. etc.
4.6L 2v - 3.27s w/ Trac Lock
#1969688 - 01/31/10 10:28 PM Re: Newer Motor..... [Re: LEGACY_X]
Big_Bad_Joe Offline
Loc: Rochester NY
sounds like its just a crack intake manifold. Commmon failure on pre 2001 vics
if your father is a mechanic you can fix it fairly cheaply. If the motor is otherwise fine then just do that for now
Underdrives from ADTR.net
2000 HPP RESURECTION finished 6/6/10 now somewhere in Blacksburg.... borla exhaust ... if you hear it honk
#1969696 - 01/31/10 10:32 PM Re: Newer Motor..... [Re: Big_Bad_Joe]
Georges93LX Offline
Loc: Owensboro, Ky.
Where are you located in Ky?
93 Crown Victoria LX. 533RWHP/621RWTQ. Eng:1999 5.4L Lightning engine. Drivetrain: 6-speed (T-56), FRPP 3.73 gears w/posi-trac. 2001 LX Sport leather interior with Contour SVT console, Marauder cluster. 18X9 Bullitt deep dished wheels. 255/45/18 Riken Raptor tires. Black '03 Marauder 300a Build date 6/4/02 #501 of 7839. If I gave a crap about gas mileage I would own a bicycle.
#1969702 - 01/31/10 10:37 PM Re: Newer Motor..... [Re: Georges93LX]
LEGACY_X Offline
Im in Cold Spring just south of newport. Why??
'05 CVPI
#1969711 - 01/31/10 10:46 PM Re: Newer Motor..... [Re: LEGACY_X]
Georges93LX Offline
Loc: Owensboro, Ky.
There's a parts yard just east of you that has some real reasonable prices. I can't think of their name right now but I'll work on it tomorrow.
#1969744 - 01/31/10 11:27 PM Re: Newer Motor..... [Re: Georges93LX]
Georges93LX Offline
Loc: Owensboro, Ky.
here ya go:
Stricker Auto Parts
Street: 4955 Benton Road
Batavia, oh 45103-1203
Phone: (513) 732-1152
#1970014 - 02/01/10 12:55 PM Re: Newer Motor..... [Re: Georges93LX]
LEGACY_X Offline
OK so went to get new tires put on today and had them run diagnostics on my engine,....
The leak is for my manifold gasket with they wanna charge me 500 for can this be done on my own???
And my misfire is probly my evap sensor which they said a common fix was a new wire harness gotta be an easier cheaper way??
help please???
'05 CVPI
#1970037 - 02/01/10 01:26 PM Re: Newer Motor..... [Re: LEGACY_X]
Michigansquadcar Offline
Loc: Southeast michigan
help please???
Sounds like you may have a leak at the heater hose connector on the back of the intake. Repair would consist of replacing the intake with a new manifold. Dorman makes a kit along with Ford. I would guess you have coolant leaking into #4 plug well causing your misfire.
#1970086 - 02/01/10 03:05 PM Re: Newer Motor..... [Re: Michigansquadcar]
Georges93LX Offline
Loc: Owensboro, Ky.
All will depend on how much you have to spend and how much down time you can live with. To do the job yourself would be the cheapest way to go. If you can't do it yourself I would have the engine replaced with the amount of miles and known problems it already has. The $500 going into repair work should go into a new engine.
#1972984 - 02/05/10 12:07 PM Re: Newer Motor..... [Re: Georges93LX]
Kaervak Offline
Loc: Kentucky
http://www.pullapart.com
They have a location in Louisville. I know they have 2 Whales on the lot right now. A LX and a P71
Page 1 of 1 1
Moderator:  Liquid, JohnG, dRock96Marquis
Hop to:
Google Search!
Google
Tire Rack!
The Tire Decision Guide
37 registered (silvercv2002, 124neta, 73vwTodd, stalag, abelouso, 98VicP71, 6 invisible) and 99 anonymous users online.
Amazon!
September
Su M Tu W Th F Sa
1 2 3 4
5 6 7 8 9 10 11
12 13 14 15 16 17 18
19 20 21 22 23 24 25
26 27 28 29 30
