#1970912 - 02/02/10 04:42 PM Need help on front end parts-MOOG vs RAYBESTOS
k9Gus Offline
Loc: OHIO
I'm finally ready to order all my new front end parts(upper & lower ball joints, tie rods, sway bar links, idler arm, pitman arm). Now my problems is deciding if it's worth the extra $100 to get the Moog parts compared to the Raybestos Professional parts.
Has anyone had any hands-on experience with both brands? I need any extra money I can get, BUT I don't want to replace these parts any time soon either! Is it worth the extra cost to go Moog?
Thanks a lot guys!!
Ryan
1999 P71, 143k on the gauge, 105k on motor, Gatorback Belt,3.55 gears, honeycomb grille, GoRhino push bumper, headlight wiring harness upgrade, Sylvania Silverstar Ultra's, clear corners, Goodyear Eagle RS-A PLUS tires
#1970946 - 02/02/10 05:23 PM Re: Need help on front end parts-MOOG vs RAYBESTOS [Re: k9Gus]
skimms98 Offline
Loc: richmond va
Having sold both in the past, I can tell you the Raybestos is actually Spicer brand in a Raybestos box and I personally would prefer it over anything by Moog. Especially if it's cheaper than Moog through your supplier!
2004 P71 Crown Victoria Arizona Beige/Tan STAP
2003 Zinc Yellow Mustang Cobra 480/505 rwhp & tq
1993 Mustang 5.0 LX coupe HCI Tremec 3550 etc etc
2006 Dodge Magnum RT 5.7L
#1971930 - 02/03/10 11:16 PM Re: Need help on front end parts-MOOG vs RAYBESTOS [Re: skimms98]
k9Gus Offline
Loc: OHIO
Anybody else?
#1972780 - 02/05/10 01:34 AM Re: Need help on front end parts-MOOG vs RAYBESTOS [Re: k9Gus]
Raybo Offline
Loc: Clearwater, Florida
Raybestos suspension parts suck. I bought Raybestos tie rod ends from Rock. I called Rock back and said these parts really suck as the threads were so poorly manu'ed.You threaded it in about an inch and they started stripping.
Rock gave me a full refund and told me to keep em' which meant throw them in the garbage which I did. Went with Moog from there on out.Bought it all from Rock with CVN discount. Rock rocks.
I replaced inner & outer
pittman and centerlink
stab bars and bushings
All Moog and bolted right up.98 CVPI.
This will be your best friend:
http://www.amazon.com/Lisle-41500-Pickle-Fork-Kit/dp/B0002SRG4S
100lb air compressor and impact gun and everything comes off like butta.NO beating with 5 lb hammer.
Sig removed. Read the rules.
#1972973 - 02/05/10 11:47 AM Re: Need help on front end parts-MOOG vs RAYBESTOS [Re: Raybo]
ubervic Offline
Loc: Point of no return
I'm glad to hear that you had a good experience with Moog, as I am about to install some Moog components that I bought after first considering the Raybestos brand.
#1973059 - 02/05/10 02:22 PM Re: Need help on front end parts-MOOG vs RAYBESTOS [Re: ubervic]
WedgeWoodCruisin Offline
Loc: Los Angeles
Glad I saw this I am looking for l/r lower control arms. Lookin at rock auto right now. Was considering Raybestos but will look elsewhere.
Not to hijack but I need the front control arms and bushings right? Or do I need joints? I am very confused.
#1973081 - 02/05/10 03:16 PM Re: Need help on front end parts-MOOG vs RAYBESTOS [Re: ubervic]
larryo340 Offline
Loc: Long Island
If you're not using OEM then the second choice should be Moog \:\)
MOD List for MGM
...Marquis sold frown
#1973104 - 02/05/10 03:42 PM Re: Need help on front end parts-MOOG vs RAYBESTOS [Re: larryo340]
dragoncvpi Offline
Loc: florida
Moog has always been a good bet on any suspension components and the brand I try to get if possible.
Gone but not forgotten
#1973381 - 02/06/10 12:20 AM Re: Need help on front end parts-MOOG vs RAYBESTOS [Re: dragoncvpi]
k9Gus Offline
Loc: OHIO
Thanks a lot guys! Better safe than sorry...I'll go with the Moog parts. I guess an extra $100 is cheap insurance. I don't want to do this job twice! Thanks for the heads-up on the fork kit Raybo. Anything to help get the job done easier is more than welcome. I don't exactly have an ideal place to do the work. I'll let you guys know how everything goes.
Are there any other front end parts I should replace while I've got it tore apart? This is my first time doin front end work. Any tips or advice are highly appreciated.
Rockauto is a lifesaver!
Thanks again everybody!
#1973394 - 02/06/10 12:52 AM Re: Need help on front end parts-MOOG vs RAYBESTOS [Re: WedgeWoodCruisin]
Raybo Offline
Hi,
I was lucky and did not have to do the control arms or
bushings.But have lurked on alot of posts here about them and there pretty straight forward.
I did not need ball j's either which is a whole other deal.
Good Luck!!!!
#1973415 - 02/06/10 01:52 AM Re: Need help on front end parts-MOOG vs RAYBESTOS [Re: Raybo]
SgtTaz Offline
Loc: Chicago, IL
Moog FTW!
#1973673 - 02/06/10 03:38 PM Re: Need help on front end parts-MOOG vs RAYBESTOS [Re: SgtTaz]
02CVSport Offline
Loc: Salem, Oregon
I'd recommend Moog over Raybestos or Autozone anything. I just had upper/lower control arm bushings replaced (Energy Suspension brand), and Moog upper/lower ball joints and Moog sway bar endlinks installed...bought all from RockAuto...and the front end feels brand new and considerably more stable.
Good luck.
02 Crown Vic LX Sport, silverfrost ext, graphite gray leather int w/factory center console, all power options, 35% window tint, smoked headlights/clear corners, Mach 1 chin spoiler, 17" OEM rims on 235/55 Toyos, 1" drop in front with +30% spring rate, RAS, Bilstein HD shocks, Megs tips, MM sub, Kicker 10" sub and 300 watt mono amp, 3.73 trac-lok, 240k miles
#1973957 - 02/06/10 10:38 PM Re: Need help on front end parts-MOOG vs RAYBESTOS [Re: 02CVSport]
fireandice9008 Offline
Loc: Southport, NC
Moog=
'nuff said.
2000 P71, Boiling Spring Lakes NC Car 5 **SOLD** and still floating around somewhere...
2004 Mercury Marauder, Silver Birch #51 of 997. Built to be blown but still (for now) N/A!!
2007 P71, Albemarle County, VA Car 52.
#1976316 - 02/10/10 11:35 AM Re: Need help on front end parts-MOOG vs RAYBESTOS [Re: fireandice9008]
afgcfan Offline
Loc: Skokie, Illinois
i replaced everything in my front end with Moog, from the whole tie rod assembly, pitman & idler arm, to all bushings and ball joints. i wouldnt go for anything else because i just dont trust em. got mine from rockauto with the discount, and if u buy in bulk the discount really helps. you cant go wrong with moog, unless you get motorcraft. spending a little now will go a long way!
#2858946 - 09/04/14 05:29 PM Re: Need help on front end parts-MOOG vs RAYBESTOS [Re: k9Gus]
SocalSam Offline
Loc: SFV, Calif.
Bump! Don't want to add another thread with my near identical question...
I had Moog front endlinks installed in my 04, they came with the blue boots which are poly (thermopastic??) and worked wonders. Now, I want to do my 08 with Moog but my mechanic tells me the part number is different for the 08. The supplier could not confirm the 08 Moog endlink was poly and not rubber.
You guys have a part number for Moog endlinks for an 08 CVPI? Are the bushings poly?
Originally Posted By EZlivin11
I drove it like a rental car...WOOHOO!
Moderator:  BigMerc96, Liquid
2 registered (Tenevic_P71, Timber_Wolf), 48 Guests and 90 Spiders online.
a_d_a_m 228
BigMerc96 139
EZlivin11 105
Chaplian 99
dpk 97
Ezbok58a 97
RF_Overlord 94
JeffBoudah 87
Ponyguy 84
Moby_Vic 82
