#1977111 - 02/11/10 08:48 AM Dome light won't turn off
BVBV Offline
2003 Crown Vic Sport
For some reason, my dome light refuses to turn off. I turn the switch until it's straight up, remove the key, and get out of the car. The dome light stays on. I'm afraid I'll run down the battery and the car won't start.
It began this way about a week ago. The first time it happened I slammed all four doors and the light went out.
I slam them now but still the dome light will not go out.
It's cold in Ohio right now, constantly below freezing. I'm thinking there might be a switch on one of the doors blocked by ice. I can't see anything though.
Any help would be greatly appreciated !!!
#1977216 - 02/11/10 12:20 PM Re: Dome light won't turn off [Re: BVBV]
Tracy Offline
Loc: West Bend, WI, USA
I know my car has a battery saver feature that turns the interior lights off after 10-15 minutes. If that is working on your car then I wouldn't worry about the battery. Still worth trying to find the cause of the problem tho.
#1977221 - 02/11/10 12:26 PM Re: Dome light won't turn off [Re: Tracy]
Bangster Offline
Battery Saver will let turn it off after 20/30 minutes (don't have manual or PDF handy to get specifics).
Does your door keypad work correctly? If it isn't a broken door keypad then it is one of the switches for one of the doors indicating it thinks one of the doors is still open.
Do you have auto lamp also? If is on, do the headlights do the same thing, or just the interior light?
00 Grand Marquis LS Premium - 97 Cougar 4.6 Sport - 89 Cougar LS - 63 Falcon 302 - 82 F-150 - 97 Mark VIII LSC - 2017 Escape SE
#1977226 - 02/11/10 12:32 PM Re: Dome light won't turn off [Re: Bangster]
BVBV Offline
Thanks for the quick responses. The keypad does work correctly. I do have autolamp.
Scouring the web,I'm really thinking it's one of the door ajar switches. I'll have to look them more carefully this evening.
Thanks again.
#2255365 - 03/09/11 07:54 PM Re: Dome light won't turn off [Re: BVBV]
Vulcan75094 Offline
Loc: Massachusetts
I solved this problem by WD-40ing the door latches like there was no tomorrow. By the next morning my left rear door opened a bit easier and the dome light worked properly. Just a thought...
2003 Saturn Ion 3 - Cheaper to drive 40K miles/yr than the CVPI but nowhere near as fun... frown
SOLD: 2000 CVPI (Former Massachusetts State Police) - (K&N drop in air filter, bumper tuck, dreaded timing chain/guides job, Yaesu FT-2800, Kenwood CD player and a Sirius Stratus 6).
JUNKED: 1992 Crown Victoria LX - My wife (now ex, thankfully!) sideswiped a tree and wrecked it but my son walked away unharmed.
#2255380 - 03/09/11 08:15 PM Re: Dome light won't turn off [Re: BVBV]
JetSledOnWheels Offline
Loc: St. Paul, MN
holy thread revival
04 CVPI 165k - Daily Driver
01 CVPI with 227 on the clock - Goodbye sweet prince!
99 CVPI 198k - Downgraded to winter beater
#2259597 - 03/15/11 06:17 PM Re: Dome light won't turn off [Re: BVBV]
Vulcan75094 Offline
Loc: Massachusetts
Well somebody had to post an answer here, and I'm somebody.. slug
#2260147 - 03/16/11 01:54 PM Re: Dome light won't turn off [Re: BVBV]
Gaither Offline
Loc: Chattanooga, TN
BVBV
If you haven't solved this one - -
I ran into this and found it was my fault. I had turned the headlights off and accidently pressed on the switch knob without knowing it. Frustrating! After a few minutes of looking, I pushed on the headlight sw "just in case", closed the door and the interior lights went off. Yeah, I felt a bit stupid!
You might try this. If that turns out to be what it is, you don't haveto admit it to anyone!
Gaither
'04 GM GS
'02 CV LX HPP
Moderator:  BigMerc96, Quasar
6 registered (RF_Overlord, Rainyp71, CrownBen, Mailtroll, Towncar281, Sacvics916), 247 Guests and 12 Spiders online.
a_d_a_m 165
dpk 153
BigMerc96 128
WSTRLNG 89
reminc70 78
Ponyguy 75
RF_Overlord 70
Bellwestern80 59
SocalSam 47
