#1978408 - 02/12/10 06:15 PM 99 Vic Won't shift out of Park...
chico_mustangs Offline
Loc: NorCal
I just picked up a Keyless 99 Vic. I bought it and it was in Neutral, I had a key made for it, shifted it into Park and now it won't shift out. The new key turns perfectly in both the doors and ignition so I am assuming its the shift release or something of that nature. Any idea if their is a way of either testing it or bypassing the lock so that I can move it? I don't mind bypassing it, I would actually prefer to do it that way. Any help is greatly appreciated!
Thanks!!!
Way to many P71 Vic's
526whp 01 GT Mustang and counting...
#1978417 - 02/12/10 06:25 PM Re: 99 Vic Won't shift out of Park... [Re: chico_mustangs]
ford05 Offline
Loc: New Jersey
Break switch. I had to replace mine about 1-2 mins ago. Car would start fine and everything but it didn't wanna shift out of parking. Do this, have some apply the brakes while u stand behind the car and and check to c if your break lights work. If they don't work then its a big possibility that your nuetral break switch is bad.
(BOC tune for 93 octane/3.73 gears/shift points for j-mod and Marauder MAF sensor) sunroof,ported & polished factory DBW TB and Plenum, 1" TB spacer and 1/2" plenum spacer, rear cat delet with 14" magnaflow mufflers and 3.5" rolled edge tips, custom gauges from Scott Hrbacek at www.customgaugefaces.com, LED interior bulbs, reverse and brake light bulbs, custom SPORT decal for 3rd brake light with led bulb, JLT cone filter, 06 p71 intake tube, 5% tints, 09 200amp alternator, Marauder front and rear swaybar and moog links, turn signal mod, glowshift rpm and volt gauge, motive cross and drilled front/rear rotors with ceramic pads, steeda underdrive pullys, crystal clear headlights and corners and complete interior changed from light flint to dark charcoal/midnight black with a very loud sound system
coming mods:
2.5" exhaust waiting to be installed
#1978603 - 02/12/10 10:28 PM Re: 99 Vic Won't shift out of Park... [Re: ford05]
Bangster Online   content
You can also bypass the brake interlock by putting the key in the run position (but don't start it), put your foot on the brake (just so it doesn't go anywhere), and shift to neutral and start it there. I wouldn't suggest that long term.
Also if your brake lights DO work, try forcing (quite a bit, but not enough to break anything) the wheel to the left and to the right, they can bind however if I remember right that makes it so you can turn the key at all.
00 Grand Marquis LS Premium - 97 Cougar 4.6 Sport - 89 Cougar LS - 63 Falcon 302 - 82 F-150 - 97 Mark VIII LSC - 2017 Escape SE
#1978732 - 02/13/10 02:09 AM Re: 99 Vic Won't shift out of Park... [Re: Bangster]
GunnyRappP71 Offline
Loc: Boise Idaho
i would look into if your car has the Tremco ignition interlock device... it is designed to do just what your talking about... cops leave the keys in the car with it running... the "bad guy" jumps on and tries to drive off in the car but it wont shift from park unless you press the button on the floor... which is hidden... it looks like a blood cuff pressure pump bulb kinda, should be new the left side kick panel under the flooring... or take it to the dealer where you got it and ask if it is on there, or try contacting Tremco themselves and ask them where it is normally located in your year CVPI....
i added the tremco as an anti theft and helps with the insurance.
Edited by GunnyRappP71 (02/13/10 02:09 AM)
GySgt. Rapponotti, M.T.
1st MarDiv 1st FAST Co.
2003 (x2) Military Police CVPI's, Preditor Tune, 255GPH Pump, 42Lbs Inj., BBK throttle bodies, 150 Nos DRY Kit, Steeda Underdrive's, Glass Packs, PB400 Push Bars,(Concealed) Unitrol TM-4 Siren, Dynamax 100W Speaker(Concealed), Pursuit Lights (Concealed), Federal Signal Wig-Wag (courtesy of Rescue Tyler), Sat. Radio, GPS, double limo tint all the way around..... Planning on: STS rear Turbo Kit or Supercharger running 6 - 8 PSI, HID/Projector Light Conv., Custom Paint, and too much more to list....
#1978927 - 02/13/10 12:56 PM Re: 99 Vic Won't shift out of Park... [Re: chico_mustangs]
ford05 Offline
Loc: New Jersey
coming mods:
#1979262 - 02/13/10 08:55 PM Re: 99 Vic Won't shift out of Park... [Re: ford05]
bgm2006 Offline
Have u looked at the pin in the steering collum??
#1979529 - 02/14/10 02:45 AM Re: 99 Vic Won't shift out of Park... [Re: bgm2006]
Loc: NorCal
My brake lights don't work... I started looking under the dash and noticed a wire that had at one point gone to a switch or something of that nature off of the brake light switch. I reconnected the wire but still don't have any brake lights. I am going to go through all of the fuses tomorrow and look around a bit more under there. I ended up unplugging the shift lock solenoid to be able to get it into gear. I mainly was just trying to get it out of the way, now I've got to try and repair it now.
#1980726 - 02/15/10 12:54 PM Re: 99 Vic Won't shift out of Park... [Re: chico_mustangs]
Loc: Boise Idaho
let us know what you found....
#1980727 - 02/15/10 12:56 PM Re: 99 Vic Won't shift out of Park... [Re: GunnyRappP71]
Nomad8326 Offline
Loc: Ohio
BOO Switch.
#1984295 - 02/20/10 02:52 PM Re: 99 Vic Won't shift out of Park... [Re: Nomad8326]
Loc: Boise Idaho
BOO Switch ? ? ? ? sorry dont know that one yet.... LOL
#1984483 - 02/20/10 09:05 PM Re: 99 Vic Won't shift out of Park... [Re: GunnyRappP71]
luv-my-2002-p71 Offline
Loc: New York
BOO = Break On, Off (that's what the OP's problem is)
#2244480 - 02/22/11 10:47 PM Re: 99 Vic Won't shift out of Park... [Re: chico_mustangs]
eazy06 Offline
Loc: Maryland, US, Landover
what's the break on, off switch and where is it located?
'99 CVPI 106,000 miles, new paint (black sapphire metallic blue) 20% tint front and back, 8000k hid's, pioneer head unit, two 12" kicker cvr's, magnaflow exhaust with back cats removed
#2244483 - 02/22/11 10:50 PM Re: 99 Vic Won't shift out of Park... [Re: chico_mustangs]
bmwallace Offline
Loc: Michigan
its right above the brake pedal pretty much, if you follow the pedal under the dash, you cant miss it, looks like a little relay there. (is on my 93 GM anyways.)
1993 Grand Marquis
196k runs like crap, as of now!
trying to work out ignition timing problems.
#2244521 - 02/22/11 11:35 PM Re: 99 Vic Won't shift out of Park... [Re: chico_mustangs]
eazy06 Offline
are you talking about the black connector right there mounted onto the pedal as you move up the brake pedal? If so, I think that's the "brake light switch." Or is that the same thing we're talking about, just another name for it?
Edited by eazy06 (02/22/11 11:43 PM)
5 registered (reminc70, Bellwestern80, bobb, Bangster, 1 invisible), 196 Guests and 6 Spiders online.
Ezbok58a 160
a_d_a_m 147
charlieD 147
BigMerc96 137
Ponyguy 119
dpk 119
White99MGM 100
reminc70 80
SocalSam 71
Chaplian 65
