#1981369 - 02/16/10 03:59 AM wheel bearing torque specs
fychelio Offline
Loc: california, usa
anyone have the torque specs on the front wheel bearing for a 2001 crown vic?
2000 Crown Victoria LX (100k miles)
#1981371 - 02/16/10 04:25 AM Re: wheel bearing torque specs [Re: fychelio]
Rizzo Offline
J-MOD Master
Loc: Romulus,MI
221 ft lbs.
And I knew it off the top of my head... No cheating
\:D
The Jmod video is done! LINK!
#1981437 - 02/16/10 09:11 AM Re: wheel bearing torque specs [Re: Rizzo]
larryo340 Offline
Loc: Long Island
 Originally Posted By: AKA_Rizzo
221 ft lbs.
\:D
I for one am very proud of you
MOD List for MGM
...Marquis sold frown
#1981468 - 02/16/10 10:14 AM Re: wheel bearing torque specs [Re: larryo340]
SCHALLZ Offline
Loc: La Crosse WI, USA
rizzo are you doing wheel bearings in school right now ??? nice work
#1981677 - 02/16/10 04:25 PM Re: wheel bearing torque specs [Re: SCHALLZ]
Rizzo Offline
J-MOD Master
Loc: Romulus,MI
Nope.. I learn more thru teaching ..
I thought I needed one.... Then I helped a member learn how to do his after taking mine apart.
I'm cracking the book for the A6.
#1982293 - 02/17/10 03:49 PM Re: wheel bearing torque specs [Re: larryo340]
fychelio Offline
lol thanks for the reply, my torque bar only goes to 150ft pounds, i just gave it a couple nudges over a little.. good idea or no?
#1982901 - 02/18/10 02:26 PM Re: wheel bearing torque specs [Re: fychelio]
vicfan_00 Offline
Loc: Quad Cities,IL
No it needs to be exact. I replaced one a few months ago and it wasnt exact. the bearing lasted for a few months and then started clicking again. Although Im still driving on it I have a new one to replace it as soon as it gets above freezing.
Better to rent a torque wrench than to do it all over again.
http://www.supermotors.net/17311
2000 CVPI 118K miles (6/2013). Steeda UDs,EMP Water Pump,Ported Plenum,FRPP 70MM TB,PI Intake,
PI cams,180 stat,NGK TR6IX Iridiums,3500 stall converter from Darrin,Dual Trans Coolers,
J-Mod,MMX Driveshaft,3.55 with T-lok,Full Magnaflow Exhaust,Marauder Cluster,
Console with floor shift. 14.9 with no tune.SOLD 11/14
Living vicariously through brothers 93 and 03
Currently in the garage- 2011 edge, 62 t-bird.
Moderator:  BigMerc96, Liquid
10 registered (124neta, bspurloc, 09mnsp, bembry, Htowns, 1 invisible), 68 Guests and 14 Spiders online.
a_d_a_m 193
Ezbok58a 156
charlieD 153
BigMerc96 138
dpk 120
Ponyguy 119
White99MGM 101
SocalSam 81
Moby_Vic 74
reminc70 74
