Page 4 of 11 < 1 2 3 4 5 6 10 11 >
#1982197 - 02/17/10 12:12 PM Re: edelbrock intake [Re: RiceBurnt6]
 Originally Posted By: Stallone_2010
I wonder how this would fair on a engine with just bolt on and MZT, no cams or headers \:D That tq increase alone is worth it.
Physics dictates that it will loose plenum volume without the cams, and exhaust mods needed to realize that nice 50 HP gain. You can still see a torque dip on the dyno due to the shorter runner setup. With Quickvics setup however this is small beans and the lack of the nose over seen with the tuned runner PI intake is a big win.
#1982236 - 02/17/10 01:30 PM Re: edelbrock intake [Re: Vincent]
Quickvic30 Offline
Just watchin
Loc: Minneapolis, MN
 Originally Posted By: Vincent
Are you set up to hold your gears all the way to 6250? Are you going to have to change your shift points to take full advantage of this? I figured you would have lost more mid-range, 50HP is pretty damn good no matter where it is.
Yeah the engine is set up for plenty more rpm than 6200 rpm, I was thinking of more like 6500-6700 shift points and 7000 rev limiter. Yes I will need a retune for this, good thing I have a dyno at my fingertips and a good friend as a grade A+ tunner \:\)
I also plan on getting this and hookin my zex wet kit to this plate
http://cgi.ebay.com/ebaymotors/NITROUS-P...=item45f0ff090f
#1982237 - 02/17/10 01:31 PM Re: edelbrock intake [Re: Chevyguy]
turbo2256 Offline
Loc: KY,OH,MICH
I dont under stand this very clearly. Would realy like to know how smaller cams would reduce a plenum volume. The plenum volume is a fixed volume. Unless one was to fill it in or grind it out.
#1982239 - 02/17/10 01:35 PM Re: edelbrock intake [Re: turbo2256]
turbo2256 Offline
Loc: KY,OH,MICH
Quick
I dont know what the pressure rating on the black hose you used to connect the ends of the fuel rails. It looks like standard fuel line from Autoze or such. I recomend using NAPA's red hose. Its max working pressure is like 250 PSI. I have used it and trust it a lot more on EFI fuel lines.
#1982243 - 02/17/10 01:45 PM Re: edelbrock intake [Re: turbo2256]
Quickvic30 Offline
Just watchin
 Originally Posted By: turbo2256
Quick
I justed used this EFI hose for mock up, once i get it on the car I will use oem type hard plastic line, we have the kit at my work so that makes things a lot easier \:\) Or I could use the napa hose with the air craft style clamps \:\)
#1982321 - 02/17/10 04:46 PM Re: edelbrock intake [Re: Quickvic30]
turbo2256 Offline
Loc: KY,OH,MICH
 Originally Posted By: Quickvic30
[quote=turbo2256]Quick
I tried to use the nylon EFI stuff. It worked ok on fittings I could remove from the car. It didnt work fo s##t on the lines attached to the frame due to inaccessability and odd angles. Gave up and used the red hose and regular hose clamps with no issues.
#1982360 - 02/17/10 05:59 PM Re: edelbrock intake [Re: turbo2256]
Quickvic30 Offline
Just watchin
I might just do that then and the red color might jazz up the engine bay a little \:D
#1982367 - 02/17/10 06:20 PM Re: edelbrock intake [Re: Quickvic30]
9psicvpi Offline
Loc: Orlando FL
NICE!!!
"Chuck Norris built my stock longblock. It runs on the tears of small children and makes 10,000 hp. He said it's his 'street version' "
#2012820 - 03/29/10 09:47 AM Re: edelbrock intake [Re: 9psicvpi]
98VicP71 Offline
13.97@99MPH
Loc: ATL
So any updates? You get it installed yet? Have you done or had to do any other mods to the intake? What about the upper plenum?
#2012903 - 03/29/10 11:33 AM Re: edelbrock intake [Re: 98VicP71]
hotrodjcc Offline
Loc: DFW, TX
Russ, did you still need an 03/04 cobra TB?
98 cv lx. -sold
2003 Cobra: cold air, catback,2.8in pulley, O/R upr x pipe,Accufab TB/Plenum and hurst shifter only. #5983
2014 Jeep Cherokee 5.7
2008 F-250 King Ranch 6.4 Spartan and deleted
http://www.facebook.com/home.php?#/profile.php?id=576101863&ref=profile
#2012979 - 03/29/10 12:49 PM Re: edelbrock intake [Re: hotrodjcc]
panthermuscle Offline
Loc: Knoxville, TN
So what would the results be on a Mostly stock car, or a car with all the boltons? Or is this a mod for those with more serious work already done?
2001 CVPI-, 02 Bullitt wheels, 2.5" full exhaust,custom xpipe, rear cat delete,flowmaster 40s, out the back to 3 inch rolled tips,tinted tails, Black leather seats from a Mercedes, explorer center console in progress,And....??
#2012983 - 03/29/10 12:53 PM Re: edelbrock intake [Re: panthermuscle]
98VicP71 Offline
13.97@99MPH
Loc: ATL
More serious work done..
until you start swapping cams or up the compression or go with some sort of forced induction SC/Turbo/N2O the stock PI intake should be plenty good.
I don't really even need my typhoon intake fully yet but with my future goals I will need something better than stock PI.
#2013071 - 03/29/10 02:08 PM Re: edelbrock intake [Re: hotrodjcc]
Quickvic30 Offline
Just watchin
No updates yet, I will be purchasing the MMR adapter plate for the plenum to carb opening this weekend and hopefully install it next week or sat. I'll keep you guys posted forsure \:\)
No thanks james, I'm just going to use my accufab set-up for the time being.
#2013185 - 03/29/10 04:57 PM Re: edelbrock intake [Re: Quickvic30]
hotrodjcc Offline
Loc: DFW, TX
I bought a Dragon TB so taking the stock one off
98 cv lx. -sold
#2013363 - 03/29/10 09:18 PM Re: edelbrock intake [Re: Quickvic30]
Big_Bad_Joe Offline
Loc: Rochester NY
nice work russ
use some russell lines... they will look real nice and we never have had issues making tons of fuel lines with them
that intake works just fine....
still better low end torque than stock and avery very usable torque and power range....
love it
i say it will really shine with new heads and some headers
Underdrives from ADTR.net
Given to DG in Ohio
Moderator:  BigMerc96, KayTar, Liquid
1 registered (WSTRLNG), 27 Guests and 89 Spiders online.
a_d_a_m 192
dpk 153
BigMerc96 129
Moby_Vic 106
WSTRLNG 85
reminc70 83
Ponyguy 78
RF_Overlord 61
Bellwestern80 57
LSE_Dave 57
