#1984862 - 02/21/10 03:37 PM EATC Outside Temperature Inaccurate?
Cokedoctor Offline
Loc: Pembroke/Akron, NY
I've been noticing for the past week or so, my EATC display has been consistently reading 10 degrees WARMER than it really is outside. Anybody have any suggestions on what might be wrong? Yes, I've checked it with a normal thermometer to make sure. It's definitely displaying the wrong temperature.
-Justin
'03 P74 LXS - Black - SOLD
'04 P74 LXS - Silver Birch Metallic
'95 Dodge Neon ACR NYG Coupe - 2.4L Swapped
'86 Mitsubishi Starion ESi-R - Restoring
'15 Dodge Challenger R/T - Sublime Green
#1984959 - 02/21/10 06:31 PM Re: EATC Outside Temperature Inaccurate? [Re: Cokedoctor]
kyle91LTDcv Offline
Loc: Jersey Shore, PA
doesnt it get its reading from the IAT (intake air temp)? its located under the hood in the MAF assembly i believe. Temperatures under the hood are consistently 10+ degrees warmer that the actual outside temp. (unless youre going really fast. lol)
2003 mercury grand marquis gs convenience: spruce green metallic w/ black pin stripe. 90K miles. scangauge II installed. blacked out grille (via plastidip) w/chrome surround ***Traded for a 2012 Mazda 6 V6 *motor blew*(warranty problem)***
Current vehicle, 2014 VW Jetta TSI
#1985008 - 02/21/10 07:40 PM Re: EATC Outside Temperature Inaccurate? [Re: kyle91LTDcv]
Cokedoctor Offline
I don't think your correct on that. If that was the case, everybody would be getting false readings. Besides, even on a cold start up, it's still off 10 degrees right from the start. It doesn't gradually go off calibration as the motor warms up.
Help \:\(
-Justin
#1985146 - 02/21/10 11:12 PM Re: EATC Outside Temperature Inaccurate? [Re: Cokedoctor]
enslow Offline
Loc: Vancouver
EATC gets its temperature from a sensor under the header panel near the crash sensors. There are two of them, one for the EATC, and one to get ambient temperature for the transmission I think.
A higher than normal temperature suggests to me the sensor is not reading correctly (coated with dirt?) or the circuit is shorting somewhere. Lower than normal temperature readings suggest an open circuit.
My first approach would be to remove the sensors and give them a good cleaning. Road grease and muck would act as an insulator and not allow the outside air to 'cool' the sensor properly, hence it will read high.
If that doesn't work, try each of the following:
1. pull the cluster fuse (#5?) for 30 seconds with the key in 'run', then replace the fuse and check temperature.
2. Disconnect sensor, key to run, pull fuse for 30 seconds then replace. Leave sensor unplugged. If T is -40F, electronic cluster and wiring to the cluster are good. If not, you will have to pull the cluster and check wiring. I found bad solder joints in mine.
3. If #2 = -40F, check resistance of sensor. Should be 33-47 kohms.
Testing the MAF
Digital Cluster Repair
Stalag's Coolant Write-up
'92 Grand Marquis, M75
#1985156 - 02/21/10 11:19 PM Re: EATC Outside Temperature Inaccurate? [Re: enslow]
enslow Offline
Loc: Vancouver
FYI,
the cluster usually remembers the previous temperature, unless the ambient temperature is cooler (I think). If you stop the car when it is 65F, then restart the car when it is 70F, I think it will read 65F and gradually climb to 70F. If the temperature drops instead (to 60F), it will read 60F. Again, I think that's how it works.
Testing the MAF
#1985173 - 02/21/10 11:35 PM Re: EATC Outside Temperature Inaccurate? [Re: enslow]
BlueFusion Offline
Loc: Dayton, OH
There should only be one sensor on the Whale bodies. It is located infront of the transmission cooler. I had mine take a dump on me a few months ago. Was reading 70 to 80 degrees when it was 10-20 outside which made the EATC engage A/C when heater should be on which can be overridden by setting the temp to it's max (90) and controlling fan speed manually.
In the case of mine, it was a bad sensor. I tried cleaning the terminals and applying some dielectric grease to keep moisture out but had no change. I got a replacement at NAPA for $16 and works well. My only complaint is it reads 2*F than actual ambient temp consistently. Not a huge deal, so I just know to compensate for that.
My other ride is measured in Mach.
Peace through superior firepower.
2006 Mercury Grand Marquis LS Ultimate [ 62,754 miles TOTALLED - Arizona Beige ]
> Addco Sway Bars || Heinous Rear Control Arms || KYB Gas-A-Just Shocks || Hawk HPS Pads || Centric Premium Rotors
> BOC 93 Octane Tune || 05+ Airbox & 80mm MAF || Steeda Underdrive Pulleys || J-mod to 88grandmarq specs
> CVPI Dual Exhaust || Rear Bumper Tuck || BH1976 Headlight Relay Harness || Ported & Polished Plenum
> 3.55 RAR || Trac-Lok w/ Carbon Fiber clutches || Marauder Spoiler
> Replaced the factory "Premium Audio"
#1985308 - 02/22/10 08:04 AM Re: EATC Outside Temperature Inaccurate? [Re: BlueFusion]
Blue95 Offline
Loc: Past the Horizon
^^+1, when the temp sensor started failing I was getting strange outside temp readings and the A/C started doing weird stuff. Didn't even mess with the old one, got a new one and all was good.
1995 P71-SOLD
2002 HPP-SOLD
#1985360 - 02/22/10 10:11 AM Re: EATC Outside Temperature Inaccurate? [Re: Blue95]
Cokedoctor Offline
Hmmm...lots of good info in here. I will definitely try all of the above suggestions and see if it helps anything. Does anybody have a picture of where this sensor is located?
-Justin
#1985369 - 02/22/10 10:23 AM Re: EATC Outside Temperature Inaccurate? [Re: Cokedoctor]
larryo340 Offline
Loc: Long Island
External Temperature Display
When the ignition is first turned ON, the external temperature displayed will be the last temperature read before the ignition was turned OFF. If the last temperature read is below 2C (35F), the EATC module will prevent A/C operation.
The external temperature display will update when the vehicle has been driven above 40 kph (25 mph) for greater than 30 seconds. Once the EATC module updates the external temperature, the EATC module will allow normal A/C operation.
On my '98 the ambient temperature sensor is by the red arrow, it should be very similiar in yours.
MOD List for MGM
...Marquis sold frown
#2929736 - 11/16/15 10:12 PM Re: EATC Outside Temperature Inaccurate? [Re: Cokedoctor]
OldsVistaCruiser Offline
Loc: near Hershey, PA
My '93 Grand Marquis LS now has random outside temperature readings. I switched the plugs on the two identical sensors on the passenger side right behind the header panel. I can start the car and it will sometimes have an accurate reading (not always). Tonight, it read 61 degrees when I started, which was about accurate. It quickly dropped to a reading of 28 degrees. Any ideas?
Thanks,
Bill S.
near Hershey, PA
#2929957 - 11/18/15 01:12 AM Re: EATC Outside Temperature Inaccurate? [Re: OldsVistaCruiser]
PHoganDive Offline
Loc: Mass, USA
Thanks,
Bill S.
near Hershey, PA
The temp sensor uses a thermistor, which is a resistor that changes resistance as its temperature changes. If any of the connections in the wiring are not good, the circuit will read the changing resistance of the bad electrical connection as a changing temperature. Look for loose/corroded connections in the wiring.
Moderator:  BigMerc96, Quasar
2 registered (Tenevic_P71, Timber_Wolf), 48 Guests and 90 Spiders online.
a_d_a_m 228
BigMerc96 139
EZlivin11 105
Chaplian 99
dpk 97
Ezbok58a 97
RF_Overlord 94
JeffBoudah 87
Ponyguy 84
Moby_Vic 82
