#2009235 - 03/24/10 02:33 PM Which Fuse for the fuel pump?
h00r Offline
Loc: Minneapolis, MN
Which fuse is for the fuel pump? I need to take it out to change my fuel filter.
--- 2006 Crown Vic Lx 61k - Dark Torator Red ---
|-BOC TUNE from Lonnie 92 octane-|-05 CVPI 80mm MAF-|-Marauder Wheels(winter)-|-LED Taillights-|-Body color surround HoneyComb grille-|-MagnaFlows with 3" Rolled-|-NightShades reverse and tails-|-Blackout Headligt Mod-|-Marauder Corners-|-Pioneer Double DIN-|-38% side Tint-|-15% rear tint-|SONY 800 to 4xInfinity Kappas-|-Kicker kx1200.1 to Kicker L715-|-220amp Alt-|-2nd Battery in Trunk-|-
--- 1985 Buick Rivera 95k - Midnight Blue --- SOLD
|-E&G Classics, Rolls Royce Style Grille-|-NOS '79 Disc Hubcaps-|-20% side tint-|-3% rear tint-|
#2009242 - 03/24/10 02:41 PM Re: Which Fuse for the fuel pump? [Re: h00r]
98VicP71 Offline
13.97@99MPH
Loc: ATL
no you don't...
don't really need to do anything but make sure the key is not in the ignition..
However if you really insist you could always just disconnet the battery or disconnect the inertia switch in the trunk for the pump.
#2009317 - 03/24/10 04:24 PM Re: Which Fuse for the fuel pump? [Re: 98VicP71]
99_03PantherS Offline
Loc: NW side Chicago
just take off the fuel cap and disconnect the battery cable. you will be good to go
Jason G.
'81 Mark VI 2 door
'88 Towncar Cartier
#2009701 - 03/25/10 12:18 AM Re: Which Fuse for the fuel pump? [Re: 99_03PantherS]
Tracy Offline
Loc: West Bend, WI, USA
What's taking the fuel cap off have to do with changing the fuel filter?? Does it release the pressure out of the tank or what??
#2009817 - 03/25/10 07:24 AM Re: Which Fuse for the fuel pump? [Re: Tracy]
98VicP71 Offline
13.97@99MPH
Loc: ATL
you don't have to take the cap off. it wont do anything..
the fuel filter is in-line. no tank pressure is going to get past the fuel pump.
Yes there will be residual pressure on the line from the pump but it wont turn on unless the key is on so you can just disconnect the lines and replace the fuel filter..
You will leak a little fuel but it is what is in the lines and filter already. Just have a rag near by so you can use to catch the fuel when you pull the lines.
#2009971 - 03/25/10 12:09 PM Re: Which Fuse for the fuel pump? [Re: h00r]
scooter Offline
Loc: SE Wisconsin
Hi,
Best thing to do is check your owner's manual. It will show which one is for the fuel pump. Mine is the engine compartment power distribution fuse box and it is a off-white color and is square.
No manual? Try here:-
http://www.hillerford.com/research/owner-manuals.html
Ford's directions (for 2003) is disconnect battery cable and to remove the fuel pump relay and turn the engine over until it stops running and continue for about 5 seconds thereafter.
Be careful not to ignite the gasoline, don't cause a spark, don't do it while smoking your pipe or cigs, etc., etc., while doing it. Be prepared for fuel spray possibly and fuel spillage(almost certain).
You will have to retrain the fuel trim/idle since the battery cable was disconnected. See manual for that as well.
I would do that procedure regardless, however especially if I just drove the car.
At least now (on my '03) the connectors are easy to slide off (don't need to remove them)and you don't need to replace them with the old hairpin clips. Remember to put a thin film of clean 5w20 oil on both ends of the fuel filter. I just took some off my dipstick and rubbed it on the filter ends.
You have now saved about $80 especially if you got the filter at a good price.
Hope that helps, unless you did it already.
Best wishes..Scott (Hi from West Bend)
2014 Ford Fusion SE 2.0L Turbo
Previously Owned: 2003 Crown Victoria LX w/Handling Package (RAR 3.27)88,000 miles
Scangauge onboard
Amateur radio operator
Repairs: Transmission Rebuild;Fuel pump;Hood lift supports;A/C Accumulator & recharge;LF window regulator;LF window motor;LF door lock actuator;LF master window switch;Blower control module;Rust on door bottoms w/POR-15;Air Suspension compressor. Email me if I can help you with any questions on these repairs.
NM117 334
Moby_Vic 146
BigMerc96 120
EZlivin11 120
Chaplian 118
RF_Overlord 115
Ezbok58a 112
a_d_a_m 100
mdnos 96
Ponyguy 93
