#2012289 - 03/28/10 03:02 PM How to replace radiator?
coqui5 Offline
Loc: Connecticut
Hey guys is me again, anybody has a link to replace a radiator for my 95 CV 4.6
#2012556 - 03/28/10 09:46 PM Re: How to replace radiator? [Re: coqui5]
bcbsr Offline
Loc: Houston,Texas
drain fluid from radiator petcock- drivers side bottom
remove plastic cover on core support
undo transmission lines,upper and lower radiator hoses
remove the bolts that hold on your fan shroud top L & R.lift and move forward towards engine ,no need to remove
remove the L & R radiator hold down brackets and the radiator should lift straight up to remove.
This is just from memory, I don't have a link.Hope this helps.
bcbsr
2001 Crown Victoria
#2012601 - 03/28/10 10:49 PM Re: How to replace radiator? [Re: bcbsr]
coqui5 Offline
Loc: Connecticut
Thanks bcbsr for your help.
#2012662 - 03/29/10 12:25 AM Re: How to replace radiator? [Re: coqui5]
TheShadow Offline
Loc: SoCal High Desert
You will have to separate the radiator from the AC condenser.
Remove the two bolts on either upper side holding them together. Battery removal makes this a lot easier, BTW.
Then there are two clips on the condenser that slide into hooks on the radiator tanks. You have to lift both up as a unit, disengage the bottom pins of the radiator from their rubber mounts, then drop the radiator down to clear the hooks. Note that the rad/condender assembly needs to be tilted back towards the engine to clear the top of the radiator support. A flat pry bar helps here.
When reinstalling, make sure both clips are in their hooks at the bottom, and that both pins are in their mounts. Otherwise, you'll rub the AC lines and end up losing the lines and refrigerant.
NM117 335
Moby_Vic 147
BigMerc96 121
Ezbok58a 116
Chaplian 116
RF_Overlord 115
EZlivin11 115
a_d_a_m 96
mdnos 96
Ponyguy 93
