#2026472 - 04/17/10 04:15 PM 91 Crown Vic Wagon Rear Disc Brake Conversion
loscroce Offline
Loc: New York
Wish to convert rear drums on my 1991 crown vic wagon to Disc brakes. Any thoughts on whats the easiest and cheapest way to make a quality conversion. I have the 8.8 rear. Most conversion kits I see online are for 9" rears. Is it easier to just swap out the rear. What other Fords have the same width and would fit. Thanks in advance for any help.
#2026483 - 04/17/10 04:41 PM Re: 91 Crown Vic Wagon Rear Disc Brake Conversion [Re: loscroce]
pantera77 Offline
Loc: Buffalo, NY
92-02 rear's are nearly a direct swap. Just swap out the backing plate. Just need to figure out the parking brake cable and so a little customizing of the brake hoses and lines.
#2026492 - 04/17/10 05:05 PM Re: 91 Crown Vic Wagon Rear Disc Brake Conversion [Re: pantera77]
Cougrrcj Offline
All Panther, all the time!!!
Loc: N.E. Ohio
BZZZZZZZZ! Incorrect! 98-up use the Watts link rear suspension. So anyway, 92-97 will bolt in with no modifications other than e-brake cables and proportioning valve (master cyl).
89 Crown Vic LX - daily driver - 393 stroker/ WR-AOD!!! New Best ET - 13.068 Best MPH - 106.58, Best 60' - 1.86
#2026542 - 04/17/10 06:37 PM Re: 91 Crown Vic Wagon Rear Disc Brake Conversion [Re: Cougrrcj]
pantera77 Offline
Loc: Buffalo, NY
http://www.grandmarq.net/vb/showthread.php?t=34703
#2026631 - 04/17/10 08:55 PM Re: 91 Crown Vic Wagon Rear Disc Brake Conversion [Re: pantera77]
Cougrrcj Offline
Loc: N.E. Ohio
I was ASSuming he was talking about replacing the entire rear end, not just bolting things on...
#2026636 - 04/17/10 09:00 PM Re: 91 Crown Vic Wagon Rear Disc Brake Conversion [Re: Cougrrcj]
interceptor1985 Offline
Loc: OREGON
Also need 16" wheels at minimum to fit over the brakes.
#2026648 - 04/17/10 09:22 PM Re: 91 Crown Vic Wagon Rear Disc Brake Conversion [Re: interceptor1985]
pantera77 Offline
Loc: Buffalo, NY
Oh, I was just assuming he meant just swapping the backing plates. My bad. That's just how'd I'd do it.
Not in the rear.
#2027051 - 04/18/10 01:36 PM Re: 91 Crown Vic Wagon Rear Disc Brake Conversion [Re: pantera77]
88grandmarq Offline
4R70W rebuilder
Loc: North Georgia
Yes..... Rear disc is do-able. NO you do NOT need 16" wheels for rear disc conversion.
92-97 rear disc parts work the best, however up to 02 will still bolt on.
my rear disc parts came off a 91 town car.
You need the rear disc mounting plate from a parts car. Salvage parts will work, but I chose to buy new calipers, rotors, pads, E-brake shoes. you will also need E-brake cables from a rear disc car. Keep in mind town car E-brake cables are different because of the longer wheel base.
its also usefull to cut the fittings off the hard brake lines from the salvage car. I used those to modify the rear brake lines to accept the rear disc hoses.
However another member on GMN discovered front brake hose from a 82-86 vic worked for his rear disc conversion.
read here..... starting with post #306
http://www.grandmarq.net/vb/showthread.php?t=10478&page=16
I rebuild AOD/AODE/4R70W/4R75E Transmissions, check out my Facebook page for my latest project; https://www.facebook.com/pages/North-Georgia-Transmission-Auto-Repair/348414635312478
#2084872 - 07/02/10 01:40 PM Re: 91 Crown Vic Wagon Rear Disc Brake Conversion [Re: 88grandmarq]
loscroce Offline
Loc: New York
Just wanted to thank you guys for all the good info. Hitting the bone yards in my area to try and make this happen. Like everyone else money's the issue. THanks
#2090662 - 07/10/10 08:47 PM Re: 91 Crown Vic Wagon Rear Disc Brake Conversion [Re: pantera77]
cvcs91 Offline
Loc: USA
Pantera...where did you snap the pic of the row of cars at ????
- cvcs91
#2090682 - 07/10/10 10:14 PM Re: 91 Crown Vic Wagon Rear Disc Brake Conversion [Re: cvcs91]
pantera77 Offline
Loc: Buffalo, NY
- cvcs91
STAP
And speaking of this thread, my wagon longs for rear disc. One of these days.....
#2091192 - 07/11/10 07:45 PM Re: 91 Crown Vic Wagon Rear Disc Brake Conversion [Re: pantera77]
turbo2256 Offline
Loc: KY,OH,MICH
Will be changing the rear not shure as to what I will find in the yards. Wound my car to 7200 RPM hit second and blew the carrier almost out of the rear cover. The bearing caps are in dozens of pieces, cover is split in half, expect more dammage upon disassembly. Most likely remove the complete rear and scrap it.
Edited by turbo2256 (07/11/10 07:47 PM)
#2092651 - 07/13/10 07:51 PM Re: 91 Crown Vic Wagon Rear Disc Brake Conversion [Re: turbo2256]
94montigua Offline
Loc: Westland, MI; Lansing, IL
damn..
1988 MGM GS
LS convienience package; InstaClear
2005 F150 Lariat Scab 4x4
1999 Mustang GT Coupe 5 speed
#2093022 - 07/14/10 08:48 AM Re: 91 Crown Vic Wagon Rear Disc Brake Conversion [Re: turbo2256]
88grandmarq Offline
4R70W rebuilder
Loc: North Georgia
what does this have to do with a rear disc brake conversion?
#2093037 - 07/14/10 09:34 AM Re: 91 Crown Vic Wagon Rear Disc Brake Conversion [Re: 88grandmarq]
turbo2256 Offline
Loc: KY,OH,MICH
Guess I will just keep what ever I do to myself.
8 registered (dpk, hischuckness, cmiser91, JDA_09Vic, KevinMLRC, GrandMarq9807), 71 Guests and 11 Spiders online.
a_d_a_m 186
Ezbok58a 158
charlieD 152
BigMerc96 144
Ponyguy 120
dpk 116
White99MGM 102
SocalSam 84
Moby_Vic 76
reminc70 74
