#2066156 - 06/09/10 05:52 PM Transmission slipping in overdrive
spicyfishstick Offline
Loc: Arkansas
My transmission has a constant slip during slow acceleration while I have it in overdrive. I just recently seafoamed the car the same way AKA_Rizzo did it on a youtube video. Before then, I only noticed a slight slip every once in a while. Could this just be a simple fix with a "no slip transmission fluid", or a much bigger problem?
Only you have the ability to define what happiness is.
1999 Ford Crown Victoria Police Interceptor - 134k miles
#2066175 - 06/09/10 06:26 PM Re: Transmission slipping in overdrive [Re: spicyfishstick]
XxScooby Offline
Loc: Charleston,SC
How long has it been since you changed your fluid, these cars are known for the fluid to break down and cause problems. Mine was doin it and a simple fluid change helped
Casey
1999 Crown Victoria Police Interceptor 143,xxx, new headlight assembly, 20% window tint all around, flowmaster delta 40's with 3" marauder style tips. and some ghetto autozone hubcaps smile
#2066214 - 06/09/10 07:12 PM Re: Transmission slipping in overdrive [Re: XxScooby]
Loc: Arkansas
well i just recently bought it, so i don't know what has been done to it up to this point. I haven't changed any fluids in it. Which fluids specifically?
#2066225 - 06/09/10 07:34 PM Re: Transmission slipping in overdrive [Re: spicyfishstick]
SPM Offline
Loc: Wisconsin
The transmission fluid. That's usually the first thing to check when the transmission isn't behaving properly. Pull the transmission dipstick (located at the back of the engine) to inspect the fluid; it should be a healthy red color and should not smell burned. If it's brownish and/or smells burned, there are problems brewing internal to the transmission that a fluid change may not correct.
To check transmission fluid level, it must be up to normal operating temperature. Take the car for a 10-minute drive, and when you get where you're going, leave the engine running and shift through all the gears allowing each gear to fully engage. After this, put it into Park and then pull the dipstick to check the fluid level.
It's a bit more involved than checking the engine oil. ;\)
2000 CVPI, 220K miles, new engine at 96K miles
Outside: Trim rings, center caps, honeycomb grille, bumper tuck
Inside: Dark mode disabled, Ultimate Console, 35% window tint
Underneath: Raybestos Advanced Technology police front pads, Raybestos Professional Grade front rotors, KYB Gas-A-Just shocks (front and rear), Moog chassis parts (idler arm, pitman arm, tie rods, front sway bar bushings), U-haul transmission pan, General Altimax HP V-rated tires, oil cooler deleted
Most recent: KYB Gas-A-Just shocks in the rear (old units came right out, no sawzall needed!!)
#2066236 - 06/09/10 07:41 PM Re: Transmission slipping in overdrive [Re: SPM]
XxScooby Offline
Loc: Charleston,SC
Good info spm
Casey
#2067051 - 06/10/10 04:43 PM Re: Transmission slipping in overdrive [Re: XxScooby]
Loc: Arkansas
it definitely is a lot more involved. It took me forever just to find the dipstick lol. The fluid is for sure red, not brown...and there was no burning smell that i picked up on. The level of fluid was near the bottom of the hatched area. Would a low fluid level cause the slipping?
#2067098 - 06/10/10 05:44 PM Re: Transmission slipping in overdrive [Re: spicyfishstick]
Loc: Arkansas
i might also add some other things about the transmission, to add more symptoms:
- strong jerk when shifting into reverse
- very noticeable jerk on 1-2 shift, and mild jerk on 2-3 shift, when accelerating strongly
#2067115 - 06/10/10 06:02 PM Re: Transmission slipping in overdrive [Re: spicyfishstick]
XxScooby Offline
Loc: Charleston,SC
Low fluid can cause your symptoms I believe
Casey
21 registered (CVPI_GT, beermoney, birdafly, 01GRANDMARQUIS, Bangster, 2006grandmrq), 79 Guests and 81 Spiders online.
KayTar 568
CNGInterceptor 400
sm41 367
Moby_Vic 285
BlackVic_P71 274
Ezbok58a 274
BigMerc96 269
Superhobo 249
ajdereicup 235
Black_Sunshine 220
