#2117137 - 08/16/10 09:08 AM Power Trunk Release
Summit Offline
Loc: VA
Oddball thing happened yesterday. The trunk release went nuts. Working fine then suddenly, stopped working. I push the interior release and the fob and I can hear the rely working but the latch does not open. Here's the kicker - With the car running and in park and the trunk closed, I put it in drive and the trunk releases! If it is in drive and I have someone close it and put it in park, it releases again. Finally, I had to pull the power to the release, which killed the trunk light and the light above the license plate. No other electrical problems. Any insight into this?
2002 CV Sport. 80mm MAF w/Maruader intake. Blue Oval Chip Tune.
#2117179 - 08/16/10 10:22 AM Re: Power Trunk Release [Re: Summit]
SgtTaz Offline
Loc: Chicago, IL
Double check all your fuses. I had it happen similar before and another fuse was blown causing the issue. This was on a CVPI without an alarm or key-less entry. Put your car information in your signature for future reference. If your using an after market alarm this could be another factor and a different (cause)problem as well.
#2117180 - 08/16/10 10:22 AM Re: Power Trunk Release [Re: Summit]
gDMJoe Offline
Loc: Timbuk3, MI
Eenie meenie chili beanie, the spirits are about to speak! ...
And the year, make, and model of your vehicle is ?
HINT/TIP: Put your vehicle information in your sig' -OR- provide it in your posting(s).
*Telepathic or Karnak we're not.
-click the Vic-
#2117641 - 08/16/10 08:23 PM Re: Power Trunk Release [Re: gDMJoe]
Summit Offline
Loc: VA
Any other ideas on this? When I push the trunk release button or the fob, I here a relay engaging (or so that's what I think it is) by the lower right drivers door. Everything else works fine. Windows, door locks, parking brake release, light timers - all work fine.
#2117651 - 08/16/10 08:32 PM Re: Power Trunk Release [Re: Summit]
TheDriver959 Offline
Loc: Oshawa, ON
Certainly a strange problem. Check your fuses and relays. Check the wiring also. Something might be interfering and the fuses simply aren't catching it.
2004 Ford Crown Victoria Police Interceptor
LX Sport Console & Floor Shifter, Gentex Electrochromic Mirror w/compass, Marauder Cluster, Speed Control w/leather wheel, LED turn signals, HID headlights (projectors coming), EATC (DIY, in progress), Marauder corners, Rewired DRL, Rewired turn signals, Maraudered headlights, Grille Mounted Driving Lights, Bullitt Wheels, Pirelli Tires and a Custom Ram Air System. More to come!
#2117912 - 08/17/10 02:22 AM Re: Power Trunk Release [Re: TheDriver959]
SgtTaz Offline
Loc: Chicago, IL
So your hearing the actuator? If your hearing the noise and it's not popping the release itself might have broke. open your trunk and try the fob see if the actuator is in fact working. If it is the connection might have broke and needs replacement.
#2118474 - 08/17/10 06:59 PM Re: Power Trunk Release [Re: SgtTaz]
Summit Offline
Loc: VA
I'll check the connections all around again. Still the odd thing is that when I close the trunk and put the car in drive the trunk pops open! If I close it while still in drive and shift to park it pops open again. Weird.
#2118548 - 08/17/10 08:35 PM Re: Power Trunk Release [Re: Summit]
Sounds like a short somewhere. When you put it in reverse, dose it pop then?
1998 Mercury Grand Marquis LS HPP ~92k miles, not entirely stock.
1997 Town Car Cartier ~143k miles, 70mm TB, Ported Plenum, Gutted Airbox, Mechanical Fan Delete, Contour E-fan Retrofit, Dual exhaust with Magnaflows, rear cat delete, MSD Ignition, KYB Gas-A-Justs, Marauder/HPP rear sway bar, P71 front bar, air ride reinstated, Blinker Mod, Projector retrofit, Caddy 4-note horn retrofit, Wood rim steering wheel retrofit, natural weight reduction.. Smashed 1/13/13....I fixt it..
#2119090 - 08/18/10 02:01 PM Re: Power Trunk Release [Re: BigMerc96]
Summit Offline
Loc: VA
Need to check that one - would it make a difference if it did not pop open?
#2119242 - 08/18/10 04:48 PM Re: Power Trunk Release [Re: Summit]
I'm not 100% sure, but I'm pretty sure the trunk release is grounded to the trunk lid, therefore when the reverse lights come on, it could pop the trunk if the ground is bad or there is a short(like the feed for the lights shorting to the trunk lid). The reverse lights flash whenever you change into drive from park (or the other way around)since you go past reverse.
Either way, if it doesn't pop, there is probably still a short somewhere.
#2151079 - 09/30/10 03:31 PM Re: Power Trunk Release [Re: BigMerc96]
Summit Offline
Loc: VA
Still having trouble here. No matter what gear I put it in, as soon as I do it the trunk pop open. Think it could be the accuator for the power door locks? When I push the trunk lock button on the side of the door, I can hear it working but the truck does not open until I put it in gear.
#2398238 - 10/30/11 07:16 PM Re: Power Trunk Release [Re: Summit]
orlandobob2 Offline
Loc: fl
i got the exact thing happening on an 02 LX sport
Moderator:  BigMerc96, Quasar
5 registered (RapidRoy, Rainyp71, White99MGM, 2 invisible), 65 Guests and 13 Spiders online.
a_d_a_m 193
Ezbok58a 161
charlieD 145
BigMerc96 142
Ponyguy 119
dpk 113
White99MGM 102
SocalSam 85
Moby_Vic 81
reminc70 70
