#2122548 - 08/22/10 11:58 PM vehicle lean to one side....
tackleberry Offline
Loc: Las Vegas
what would cause your vehicle to lean towards one side? i noticed my car kinda leans lower on the right/passenger side. sometimes its more noticable than others. tires are all newer and not flat, etc.
#2122924 - 08/23/10 01:44 PM Re: vehicle lean to one side.... [Re: tackleberry]
BigMerc96 Online   confused
Springs can sometimes wear unevenly and sag more on one side than the other. My car sits a little lower on the back drivers side than on the pass side. Could also be a broken spring, good idea to check to be sure its not. Also if you have air suspension(i see '03 P71 in your sig, so I'm assuming you don't), one side could leak more than the other.
My car has adjustable ride height, based on how much gas is in the tank . If the tank is full the back sits low, if its empty, it sits high. I'm thinking I need springs sometime soon.
1998 Mercury Grand Marquis LS HPP ~92k miles, not entirely stock.
1997 Town Car Cartier ~143k miles, 70mm TB, Ported Plenum, Gutted Airbox, Mechanical Fan Delete, Contour E-fan Retrofit, Dual exhaust with Magnaflows, rear cat delete, MSD Ignition, KYB Gas-A-Justs, Marauder/HPP rear sway bar, P71 front bar, air ride reinstated, Blinker Mod, Projector retrofit, Caddy 4-note horn retrofit, Wood rim steering wheel retrofit, natural weight reduction.. Smashed 1/13/13....I fixt it..
#2123030 - 08/23/10 03:30 PM Re: vehicle lean to one side.... [Re: BigMerc96]
tackleberry Offline
Loc: Las Vegas
i do notice that when im driving, if i force the car to lean to the drivers side hard, it dont seem as uneven. i dont hear anything creaking or snapping etc like something is actually broken.
#2123048 - 08/23/10 03:47 PM Re: vehicle lean to one side.... [Re: tackleberry]
Mileaway Offline
Loc: Sacto. Calif.
just in your driveway or anywhere?
My driveway/carport is uneven but not all that much to the naked eye however it does make it appear that the right front is lower.
I could use new front springs after 150 thou but I believe it's actaully fairly even from left to right
#2123295 - 08/23/10 08:28 PM Re: vehicle lean to one side.... [Re: tackleberry]
Steve83 Offline
Well, it can't lean to BOTH sides!
#2123550 - 08/24/10 01:16 AM Re: vehicle lean to one side.... [Re: Steve83]
tackleberry Offline
Loc: Las Vegas
no its anywhere. and steve, goofball, leaning to both sides so to say would be EVEN lol.
#2123717 - 08/24/10 11:18 AM Re: vehicle lean to one side.... [Re: tackleberry]
Steve83 Offline
So then why did you say "to one side", goofball? \:D
#2123913 - 08/24/10 03:39 PM Re: vehicle lean to one side.... [Re: Steve83]
tackleberry Offline
Loc: Las Vegas
because it is leaning lower on one side!
#2135780 - 09/09/10 01:11 AM Re: vehicle lean to one side.... [Re: tackleberry]
ferg Offline
Loc: SE Michigan
If a swaybar endlink is broken or badly bent it could make it lean a little (to one side)...
Jeremy
2006 P71 (current), white, Purchased 02/28/2011 w/73k miles. Bumper tuck, 5% tint all around, code alarm/remote start, cruise wheel, MGM carpet, rampage center console, flowmaster 40's dumped at the axle. 118k and counting....
2004 P71, TOTALED: 01/11/2011 w/60k miles. Bumper tuck turned into bumper wedgie!
1985 Mazda RX7 GSL (toy) LT1/T56 Swap in Progress.
2015 Town & Country Touring (family truckster)
2009 Charger Pursuit (4-925)
#2135801 - 09/09/10 01:54 AM Re: vehicle lean to one side.... [Re: ferg]
heavyhitter03 Offline
Loc: Viera florida, united states
bad shocks can make it lean also
2003 CVPI,X5 axel,
pioneer AVHP-3200BT head unit and pioneer interiors.
20% tint all around
rear bumper tuck mod
Glock 23 in the seat pouch under my ballz smile
#2137251 - 09/11/10 01:43 AM Re: vehicle lean to one side.... [Re: heavyhitter03]
Steve83 Offline
Only if the shock tube is crushed, pinning its piston, or if the shaft is bent.
Moderator:  BigMerc96, Liquid
4 registered (Mikkee, BigMerc96, 95beaterCV, NACEOD), 309 Guests and 17 Spiders online.
a_d_a_m 182
dpk 157
BigMerc96 129
Moby_Vic 104
WSTRLNG 83
reminc70 78
Ponyguy 78
RF_Overlord 64
Bellwestern80 56
LSE_Dave 51
