So I finally got around to installing the 2001-04 ford focus fog
lights in my 2000 vic.
Certifit has a great price on these at 12 bucks a pop
I found a great way to mount them, these fog lights don't come with any brackets. Here's what you will need...
1. backstrap (3 to 4 strips)
2. zip ties
3. hot glue and hot glue gun
4. self taping screws
5. washers (depending on the size of the head on the screws you
might not need them)
6. power drill with an angle adapter
7. screw fastner
8. pan head screws
Here you see the backstrap, pan head screws, and screw fastner.
If you notice I grinded the side of the fastner. This is optional, but it makes it alot easier to line up with the hole on the light.
mount the backstrap using the pan head screw and fastner to the fog light.
on the other side use another piece of bacstrap with a zip tie, and tie it to the little nipple.
Use the hot glue to seal it off, that way the zip tie wont slip off. Make sure you get glue in all the little gaps
Here is what you should end up with...
Line up the fog light to your taste, and use the self tapping screws to mount it to the crash bracket. This is when you will need an angle driver adapter on your drill.
and the final product...
I think they look clean and stock, Im happy with the end result.
Next week I will get the HID's for them. I hope this helps those looking to do this mod, I know a couple of yall were wondering about witch fogs fit our cars.
Peace!
