Page 7 of 9 < 1 2 3 4 5 6 7 8 9 >
#2368366 - 09/09/11 01:37 PM Re: Ford focus fog light install...with pics [Re: CrownVicBoyz]
capt512 Offline
Loc: KC, MO
Anybody consider making the brackets (welding them up right, etc) and selling them to members (I'm sure there would be interest). I'm sure I can make brackets bending them like the others, just would like them to be a little more OEMish if possible. If not I'll just bend some brackets.
2001 CVPI - Ex-Kansas Turnpike Authority (Sold)
2000 CVPI - Ex-Kansas Turnpike Authority
2003 Marauder (300A)
2006 CVPI - Ex-NJ Airport Police 55k Miles
#2369407 - 09/11/11 05:10 AM Re: Ford focus fog light install...with pics [Re: CrownVicBoyz]
95CrownVictoriaP74 Offline
Loc: Dixie County, Florida
Very nice work!
2004 Ford Crown Victoria LX
2016 Volkswagen Jetta SEL Hybrid
2017 Volkswagen Jetta GLI
(Previous vehicles: 1995 Crown Victoria LX HPP, 1997 Crown Victoria Police Interceptor, 2000 Crown Victoria HPP, 2010 Volkswagen Jetta 2.0T, & 2003 Lincoln Town Car Signature)
#2385377 - 10/08/11 03:07 PM Re: Ford focus fog light install...with pics [Re: 95CrownVictoriaP74]
cragantler1 Offline
Loc: Fla. Cracker in South Conway
I've got my housings ordered, just have to bend the spare scrap aluminum I have and order the bulbs,relay and switch.
Hope to have this done before it gets too cold.
Very excited about this mod...
2004 Arizona Beige P-73, gone but never forgotten
2004 P-73,113k+
Performance & Handling:
P-71 H-pipe with Flowmaster 50s/Rear Meow delete/ADTR P&P plenum/70mm TB/Marauder swaybars/MZT/BOC tune/J-Mod/ 2006 P-71 rear coils/Gatorback belt/2005 17" Mustang GT Premium rims with Pirellis/ FRPP 3.55's / FRPP Trak-Lok
best time, pre-gear change: 15.4 @ 91.6mph
Appearance:
Honeycomb color matched grille/lower grille mesh mod/S-55 tail/reverse lights mod/bumper tuck/window chrome and wood dash delete/black reflective rear fascia/side marker mod/15% rear, 35% front tint/Marauder gauge cluster/1999 Lincoln Continental console and floor shift/Marauder gauge pod with "real" Autometer gauges/ Ford Focus driving lights with 5000K HID's wired to Marauder light switch for factory operation/repaired LCM/Marauder corner lights
#2388000 - 10/13/11 12:38 AM Re: Ford focus fog light install...with pics [Re: CrownVicBoyz]
03RedVicSport Offline
Loc: Central NY
Wow, has it really been THIS long? I got my lights and HID kits back the end of August, and I'm just now getting around to putting these in. I actually started two weeks ago, I made brackets from some 1/8" 6061-T6 sheet and scrap aluminum angle, measured and marked where the holes needed to be in the metal bumper channel on each side, and tried to drill them...
What in heck is that bumper channel made from? recylced armor plate? I could NOT drill a hole in tha thing to save my life.
After much struggle and burning up or breaking every small drill bit I had, I managed to get a 1/8" hole thru it on each side, but the jump to 3/16 just stopped DEAD.
I ended up GRINDING the holes thru with a conical abrasive bit in a dremel tool. It worked. What a nightmare...
Once I had holes, the rest went and will finish up pretty easy. I have the lights mounted and the HID bulbs installed to keep crud and water out ofg the light housings.
It'll need to wait for th eweekend for the electrical part of the job, and some pix...
"All This Has Happened Before And Will Again"
#2388004 - 10/13/11 12:50 AM Re: Ford focus fog light install...with pics [Re: CrownVicBoyz]
Black_Sunshine Offline
I'm looking at doing these in my Grand Marquis:
The overall design of the holes in the bumper is the same as a Crown Vic but there is the bar in the center. I'm going to ignore the fact that the bar is there. It's not like the HIDs are going to send a beam out from the halogen housing anyway. The outer most holes on my bumper look just a little bit wider than the holes on the Vic. Can someone measure the lens of a Focus fog light? I just need to know if it will fill the hole like it does on a Crown Vic.
75mm DBW TB
� hood ornament
� c-pillar emblems
� LS style body side moldings
CarDomain
Facebook
#2388010 - 10/13/11 01:09 AM Re: Ford focus fog light install...with pics [Re: Black_Sunshine]
Loc: Central NY
The shape of the end openings is a little different as well as being wider like you said. The Crown Vic's are more tri-angular while the Merc is more square-ish. I can't measure anything right now, but by just looking at it, I'm going to say you'll have a small gap at the rounded lower outboard edge of the opening, if you line up the top and inboard edge.
#2388014 - 10/13/11 01:16 AM Re: Ford focus fog light install...with pics [Re: CrownVicBoyz]
I'll get a close up of the hole tomorrow. There is a black piece of plastic behind the outer most holes on both sides. Is that there on the Crown Vics? If so it might be the same part. That would indicate that the Focus fogs would fit pretty well.
75mm DBW TB
� hood ornament
� c-pillar emblems
CarDomain
Facebook
#2388015 - 10/13/11 01:25 AM Re: Ford focus fog light install...with pics [Re: Black_Sunshine]
Loc: Central NY
That black plastic thign IS indeed there on Vic's as well... Retained by two little screws.
It isn't really shaped like the opening, it's bigger than the opening itself, and more square. It mounts the back face of the edges around the hole, if you followed that.
I think that plastic cover is a one-size-fits-all deal, it's shaped to work with both, and they use it on all of 'em.
#2388016 - 10/13/11 01:29 AM Re: Ford focus fog light install...with pics [Re: CrownVicBoyz]
Loc: Central NY
Looking at your Merc again, the verticle bar nearest that opening is slanted visibly also, while the edge of the Focus light and of the Vic opening is almost a 90-degree angle with the top edge.
Since these mount actually in behind the opening not thru it, it will work but likely with gaps in places.
That wouldn't stop me for a minute though... I'd still do it.
#2388029 - 10/13/11 02:28 AM Re: Ford focus fog light install...with pics [Re: Black_Sunshine]
Carter Offline
Loc: Michigan
I was thinking of doing the exact fog install on my MGM as well. Thought about cutting out that bar and fabricating/Fiberglassing in the cuts. Don't know how that would work.
Current Cars: 2015 Chevrolet Impala LTZ LZ2 V6, 2006 Mercury Grand Marquis LS Ultimate Edition
Former Cars: 2012 Chevrolet Impala LT, 2003 Mercury Grand Marquis GS
EATC Repair Video: https://www.youtube.com/watch?v=5IsDs-N1mvE
#2429013 - 12/27/11 01:12 PM Re: Ford focus fog light install...with pics [Re: CrownVicBoyz]
yoshi86 Offline
Loc: West Palm Beach
Anyone know where to get the back straps? I been looking all over and cant find anything.
01 crown vic lx p74 with 235k
#2429032 - 12/27/11 02:09 PM Re: Ford focus fog light install...with pics [Re: yoshi86]
Drac Offline
Cpt. Smug
Loc: Cali
Ace Hardware...
Lowes...
Home Depot...
some places may only carry a long piece, in which you will have to cut it down to length and trim it if necessary.
#2429709 - 12/28/11 11:40 PM Re: Ford focus fog light install...with pics [Re: CrownVicBoyz]
I got mine at home depot. I paid about $3 for a 4 foot piece.
#2430200 - 12/30/11 08:07 AM Re: Ford focus fog light install...with pics [Re: NGreen0807]
cragantler1 Offline
Originally Posted By: NGreen0807
I have the lights I'm ready to go. I'm just working on making a better bracket
You have a picture of the brackets ??
I just got my bulbs in yesterday but now it is too friggin cold.
Don't know if I feel like crawling around the garage with a torpedo heater blowing on me.
2004 P-73,113k+
Appearance:
#2438937 - 01/15/12 10:12 AM Re: Ford focus fog light install...with pics [Re: CrownVicBoyz]
Bulldog5_oh Offline
Interesting
0 registered (), 109 Guests and 11 Spiders online.
Traffic22 15
