#2147625 - 09/25/10 09:06 PM 2003 4.6 Crown Vic won't start
knightride Offline
Loc: USA
I have a 03 Crown Vic that cranks over but will not start, it has fuel pressure, I checked the coils and the all were in range but when I put a spark tester on no spark. Can anyone help please?
#2147652 - 09/25/10 09:54 PM Re: 2003 4.6 Crown Vic won't start [Re: knightride]
03RedVicSport Offline
Loc: Central NY
When trying to start, when you turn the key and the lights on the dash come on but before turning all the way to 'crank', does the CHECK ENGINE light illuminate? It should do so.
Generally I believe that if that check engine light does NOT light up as described just before you engage the starter, there is a problem and it will not fire.
Off the top of my head, only one possibility comes to mind based on previous issues I've had with other cars... The crank position sensor.
If that is not working or the electrical connection is crudded up, the car will be a no start as described. My first check would be to unplug it, clean the connections and plug it back in.
My Mark VIII has done this to me a time or two.
"All This Has Happened Before And Will Again"
#2148130 - 09/26/10 07:10 PM Re: 2003 4.6 Crown Vic won't start [Re: knightride]
Da Governator
As '03 said above, does the check engine lamp illuminate when first turning the ignition from OFF to RUN?
And if so, while cranking the engine is there any activity with the check engine lamp?
Also, disconnect one of the ignition coils. Turn the ignition to RUN. There should be B+/12v on the pin which connects to the RED/LIGHT GREEN wire. This applies to EVERY coil.
Check ignition and PCM fuses + relays. Charts available on my webpage near bottom
Make sure the sensor on the top/LH front timing cover (CMP) and the sensor low by the A/C compressor (CKP) are firmly connected.
RIP 2vmodular
#2148158 - 09/26/10 08:00 PM Re: 2003 4.6 Crown Vic won't start [Re: knightride]
dbruno123 Offline
Loc: louisiana
is ur vehicle an p71 or civlian modle with pats -if it has pats it will cut out ignition and flash red lap on instrument cluster or dash and means past is disabling vehicle-if p71 i woould check ignition fuses and relays -could cause no start
Read sig rules.
1 registered (Interim), 20 Guests and 75 Spiders online.
a_d_a_m 222
BigMerc96 141
EZlivin11 104
Chaplian 99
RF_Overlord 97
dpk 94
Ezbok58a 87
SocalSam 86
Ponyguy 85
charlieD 85
