#2187096 - 11/23/10 02:55 PM Running water noise when start car?
johnfellows Offline
Loc: minnesota
Ever since I replaced my intake manifold, every time I start my car in the morning it makes a running water noise for about a minute that sounds like its coming from the dashboard almost. It gets louder when I accelerate but usually goes away within a minute or two. I haven't been too worried since my car no longer overheats, but what could this be?
1998 crown vic
#2187189 - 11/23/10 04:42 PM Re: Running water noise when start car? [Re: johnfellows]
Mazlem Offline
Loc: Central NY
You're likely low on coolant and/or have some air in the lines. Check the radiator and reservoir. If the radiator is low, pour in slowly and wait for all the bubbles to surface.
2004 Crown Vic Sport - In the midnight gray club!
#2187206 - 11/23/10 05:04 PM Re: Running water noise when start car? [Re: Mazlem]
johnfellows Offline
Loc: minnesota
Thanks I actually figured it out. Apparently the intake manifold I used is a cheaper version that lets coolant go through the heater core quicker then it should which is causing the noise.
1998 crown vic
#2188637 - 11/26/10 03:22 AM Re: Running water noise when start car? [Re: johnfellows]
1 Adam 12 Offline
Loc: Glendale, AZ
I was going to say Heater Core as well...my fathers 95 Dodge RAM had this same issue and you always knew it had to be the heater core.
~Chris~
MY ARTICLES
1 registered (intakeleak), 245 Guests and 6 Spiders online.
BigMerc96 142
a_d_a_m 139
dpk 129
Ponyguy 91
Moby_Vic 81
charlieD 79
RF_Overlord 70
SocalSam 65
Bellwestern80 53
EZlivin11 52
