#2196747 - 12/10/10 07:29 AM Windows fogging up, heater core not at fault......
Fordiesel69 Offline
Loc: Erie, PA
I aquired a 98 town car to replaced my very rusty 91. The problem is neither car has a working a/c system to dehumidify the air. The 91 does not fog up at all, the 98 fogs up real bad but the heater core is not leaking. I not only pressure tested the system, but loose no coolant, and cannot smell any burnt celery like other cars that got a slow leak. Carpets are pretty dry except for the little snow I drag in which every car has....
Even with climate control on defrost, fll heat, and full fan, it is still a chore to keep windows clear.
So what is next?
-'99 Crown Vic Police Interceptor (SAP), 3.55 Trac-Loc(DK), Cloth Interior, Black Honeycomb Grill, Black PI Trunk Bezel, Silverstars, 174K
-'08 Crown Vic Police Interceptor (SAP), 3.27, Cloth Interior, Smokestone Metallic, 130K / 3427 Hrs
-'07 F-150 4x4 - Extended Cab, 3.55's, White w/ Grey interior, 124K
#2196748 - 12/10/10 07:35 AM Re: Windows fogging up, heater core not at fault...... [Re: Fordiesel69]
98VicP71 Offline
13.97@99MPH
Loc: ATL
well if the A/C is not working to remove the moisture from the air that is why.
rain-x makes anti fog stuff too you can put on the windshield. That might be worth a shot.
#2196769 - 12/10/10 08:21 AM Re: Windows fogging up, heater core not at fault...... [Re: BigNSlow]
AODE Offline
Loc: Ohio
try baking soda, they have the large ones with side vents for $2.50 at kroger, absorbs moisture and odor.
Or keep a window cracked
2000 CV
350 HP
450 Lbs Torque
#2196794 - 12/10/10 09:21 AM Re: Windows fogging up, heater core not at fault...... [Re: AODE]
enslow Offline
Loc: Vancouver
Your only option may be to fix the AC. When my AC quit on me a few years ago I had the same problem. It seems to be a design issue.
Testing the MAF
Digital Cluster Repair
Stalag's Coolant Write-up
'92 Grand Marquis, M75
#2196812 - 12/10/10 10:18 AM Re: Windows fogging up, heater core not at fault...... [Re: enslow]
larryo340 Offline
Loc: Long Island
add another vote to fix the a/c \:\)
MOD List for MGM
...Marquis sold frown
#2196826 - 12/10/10 11:03 AM Re: Windows fogging up, heater core not at fault...... [Re: larryo340]
Fordiesel69 Offline
Loc: Erie, PA
A/C is not the sole reason. My 91' has not had it functioning since 2006 when the compressor fried tight. It NEVER fogs up!!
This 98' has nice airflow and burning hot air, still fogs. A/C fix is not an option. Condensor is blown, compressor is locked, and drier is rotted out. Blend door shaft is broke and stuck on full heat. What can I say, its a green car, and you know what luck green is.......
#2196865 - 12/10/10 12:57 PM Re: Windows fogging up, heater core not at fault...... [Re: Fordiesel69]
73vwTodd Offline
Loc: Florida
Is anything else leaking in your car? Do you know if the windshield or anything has leaked?
Try pulling the carpet back on the passenger side and see if the carpet / jute is wet... it's possible that you have moisture in the car.
#2196929 - 12/10/10 02:59 PM Re: Windows fogging up, heater core not at fault...... [Re: 73vwTodd]
RiceBurnt6 Offline
Loc: SWMI
Those windows just need cleaned. I know it sounds funny, but try some windex and then some rain x to finish it off. If it don't work at least the windows will be clean lol. Help cure my fogged windows in the winter/ and summer when it rains .
Originally Posted By: RiceBurnt6
You're getting mad at the content of a thread of which you clicked on? Maybe you need to get a life? Yes?
#2196935 - 12/10/10 03:07 PM Re: Windows fogging up, heater core not at fault...... [Re: RiceBurnt6]
Fordiesel69 Offline
Loc: Erie, PA
I will do one last time. I had to do 3 times in a row due to the nicocoat from the preivous chain smokers. I used sprayway & then a rinse in warm water. They came clean but who knows.
#2197093 - 12/10/10 09:43 PM Re: Windows fogging up, heater core not at fault...... [Re: Fordiesel69]
AlbertaBeef Offline
Loc: Fort McMurray , Alberta
I'm going to go way out there and point out something very obvious. Is your fan set on fresh air or recirc? If it is on recirc, the windows will fog up for sure. I don't know if our cars have that setting, but I've seen it on most other cars. Easy fix if that is the issue.
2004 P71, 125 KM
Disabled dark car
Bumper Tuck, holes in roof and door.
#2197323 - 12/11/10 10:28 AM Re: Windows fogging up, heater core not at fault...... [Re: AlbertaBeef]
Steve99CVPI Offline
Pork Eating Infidel
Loc: Milwaukee, WI/Chicago, IL
My windows on my box and aero never fogged up, but both my 2000 and 03 windows fog up quick, but only if there is more than just me in the car. Although my defrosters in the 03 work great on all the windows except the back doors.
My SUPERMOTORS page
#2197328 - 12/11/10 10:33 AM Re: Windows fogging up, heater core not at fault...... [Re: AlbertaBeef]
Fordiesel69 Offline
Loc: Erie, PA
I did have the dash apart, and you know what, I left the plug out for both actuators as a result of blend door shaft being broke. I will check to see if thre recirc door is open or closed. The fan is loud compared to my other lincoln so I bet this is the problem.
#2197346 - 12/11/10 11:24 AM Re: Windows fogging up, heater core not at fault...... [Re: Fordiesel69]
D-Fenz Offline
Loc: Free America (WV)
I think a mix of vinegar and hot water might help with the previous smoker/dirty windows issue and help with the fogging.
2011 Black CVPI-Charlie Murphy II, 113K miles, Gray Interior, Fog Lights, Working Shotgun Release, 3.27 RAR.
2005 CVPI-Rick James-SOLD
2000 Exploder-SOLD
1998 CVPI-SOLD
1991 CVLX-SOLD
2000 Volvo XC V70 AWD-The Shaggin Wagon-My current project
#2211763 - 01/06/11 12:13 AM Re: Windows fogging up, heater core not at fault...... [Re: D-Fenz]
FrostyVic Offline
Loc: New Jersey
FordDiesel,Did you ever find out what the cause was of the windows fogging up?
#2211851 - 01/06/11 06:58 AM Re: Windows fogging up, heater core not at fault...... [Re: FrostyVic]
Fordiesel69 Offline
Loc: Erie, PA
By re-plugging in the recirc door actuator, now I can let outside air in. It does seem to help. With me in the car alone, it is acceptable, but with more than me, it still fogs up.
Moderator:  BigMerc96, Quasar
11 registered (Kickingwing519, charlieD, Clark, Hobo321, CrownBen, a_d_a_m), 110 Guests and 78 Spiders online.
NM117 334
Moby_Vic 146
EZlivin11 120
BigMerc96 120
Chaplian 118
RF_Overlord 115
Ezbok58a 112
a_d_a_m 100
mdnos 96
Ponyguy 93
