#2196099 - 12/08/10 10:14 PM Surging Idle With Heater On
BAKE19 Offline
Loc: Pennsylvannia
Ok, so up until now, my heater and AC have worked flawlessly. However, today I noticed that with the heater on (floor, mix, or defrost) with the car in park as well as in drive (sitting at a red light) the idle will surge up every 10 seconds or so. The surge is brief, and I hear a single tick along with it from under the hood. Also, the heater is, well, not heating the car up. Its blowing room temp air. I have no experience with working on heaters or AC in cars... Need some help before it gets really cold
Bake
2004 Crown Victoria Base 147,XXX Miles: 87 Octane Tune, "CAI", 80mm MAF, 67.5mm TB, 2" Dual Exhaust, Flowmaster Delta 40 Mufflers
#2196100 - 12/08/10 10:18 PM Re: Surging Idle With Heater On [Re: BAKE19]
MontanaMan Offline
Loc: Big Sky Country
I'd look for a vacuum leak. I had an old ford that would do that to me.
2008 CVPI, former State of Connecticut vehicle that was rode hard and put away wet for it's first two years of life,silver repainted black, factory CD/Cassette stereo 53,400 miles, new factory reman 4.6 installed at 38k miles, 3.27 axle w/FRPP trac-lok, FSS, upgraded to cruise control.
#2196108 - 12/08/10 10:37 PM Re: Surging Idle With Heater On [Re: MontanaMan]
ferg Offline
Loc: SE Michigan
Is your car getting up to, and staying at normal operating tempurature?
Jeremy
2006 P71 (current), white, Purchased 02/28/2011 w/73k miles. Bumper tuck, 5% tint all around, code alarm/remote start, cruise wheel, MGM carpet, rampage center console, flowmaster 40's dumped at the axle. 110k and counting....
2004 P71, TOTALED: 01/11/2011 w/60k miles. Bumper tuck turned into bumper wedgie!
1985 Mazda RX7 GSL (toy) LT1/T56 Swap in Progress.
2015 Town & Country Touring (family truckster)
2009 Charger Pursuit (4-925)
#2196117 - 12/08/10 10:53 PM Re: Surging Idle With Heater On [Re: ferg]
BAKE19 Offline
Loc: Pennsylvannia
Jeremy
Yes.
Bake
#2196198 - 12/09/10 05:12 AM Re: Surging Idle With Heater On [Re: BAKE19]
wolfallday973 Offline
Loc: paterson,nj
could be your alternator starting to crap out. turn on your radio, heat, headlights and use your turn signal. if the voltage bobs up and down a lot you're going to need an alternator one of these days.
1986 Crown Victoria LTD - R.I.P. 10/06/2010
1998 Grand Marquis GS Palm Beach - Cop Chip
2000 Grand Marquis LS - pretty much stock
2000 Chevy Malibu LS - P.O.S. Civic Burner
#2196284 - 12/09/10 10:39 AM Re: Surging Idle With Heater On [Re: wolfallday973]
coldfusion11 Offline
n00b pwn
Loc: Rochester Hills, MI
The click, is the AC condenser turning on and off. When it is cold, it will turn on and off and the RPM will raise a tich to compensate.
2002 CV P73
#2196303 - 12/09/10 11:14 AM Re: Surging Idle With Heater On [Re: coldfusion11]
124neta Offline
don't get riled, sugar!
Loc: Il
^^^thats what it sounds like. BAK19: are you positive that this is occurring at all heat settings, or just on defrost?
#2196305 - 12/09/10 11:16 AM Re: Surging Idle With Heater On [Re: 124neta]
n00b pwn
The compressor functions on ALL HVAC settings except OFF (obviously) and VENT.
Try to see if you can replicate the noise with the setting on hot and VENT.
2002 CV P73
#2196466 - 12/09/10 04:41 PM Re: Surging Idle With Heater On [Re: coldfusion11]
BAKE19 Offline
Loc: Pennsylvannia
Yes, it is occurring on floor, mix, and defrost. Seems to be rather random when it occurs. Ill try putting vent on with heat when I get in my car in a few to go to the firehouse. Ill post when I get there and let you guys know. I know over the summer when the AC compressor would come on and my window would be down (like when you first get in and turn the AC on and open the windows to let the heat out) you could hear a squeak along with the tick, and even with the windows up you could hear it as well. Idk if that's related, but the AC functioned fine. Thanks for all the input as always, fellas!
Bake
#2196487 - 12/09/10 05:15 PM Re: Surging Idle With Heater On [Re: BAKE19]
BAKE19 Offline
Loc: Pennsylvannia
Ok, so it did not surge while on vent... and the car was nice and toasty. PS... after posting initially saying that the interior was not warming up, I drove it to work and it did warm up the interior, even though the idle still surged every now and then at a stop light. Kinda annoying when you barely have your foot on the brake and the car goes foward a bit...
Bake
#2196849 - 12/10/10 12:01 PM Re: Surging Idle With Heater On [Re: BAKE19]
Big_Bad_Joe Offline
Loc: Rochester NY
bake
the comment on the alternator is spot on....
check it with a good multi-meter ... should be 14.5 volts (or more) and consistent... check it with lights on and even the defroster... if it surges and drops volts you have pinpointed it....
Underdrives from ADTR.net
Given to DG in Ohio
#2196895 - 12/10/10 02:16 PM Re: Surging Idle With Heater On [Re: Big_Bad_Joe]
n00b pwn
does it make any weird type of noises when it surges at idle?
I.E a FOGHORN noise?
2002 CV P73
#2196978 - 12/10/10 04:29 PM Re: Surging Idle With Heater On [Re: Big_Bad_Joe]
deltasixtango Offline
Loc: New England
 Originally Posted By: Big_Bad_Joe
bake
That was my first thought when I read the title.
Put the vehicle under more of a power load (high beams, heat, stereo, etc.) and see if the noise becomes more frequent or more intense. If it seems to be the alternator, get out the multimeter and test both it and the battery.
2012 Escape XLT SAP - primary wheels
2009 Taurus SEL AWD - the commuter and grocery getter
2006 Acura MDX - snow and auction-car-hauling machine
1944 Willys MB - fully operational movie star
#2197041 - 12/10/10 07:29 PM Re: Surging Idle With Heater On [Re: deltasixtango]
BAKE19 Offline
Loc: Pennsylvannia
Ill check the alternator. I havent had any dimming of the headlights or interior lights, even with everything on. It's worth a shot though. Thanks again guys!
Bake
#2199952 - 12/15/10 05:38 PM Re: Surging Idle With Heater On [Re: BAKE19]
BAKE19 Offline
Loc: Pennsylvannia
Well, it looks to be the alternator. The headlights and interior lights dim with everything on and then using the power windows. So, I have an alternator with a few thousand miles on the way... I guess its the cheap way to go. Ill see how long it lasts me.
Bake
2 registered (Tenevic_P71, Timber_Wolf), 48 Guests and 90 Spiders online.
a_d_a_m 228
BigMerc96 139
EZlivin11 105
Chaplian 99
dpk 97
Ezbok58a 97
RF_Overlord 94
JeffBoudah 87
Ponyguy 84
Moby_Vic 82
