#2256015 - 03/10/11 04:41 PM no reverse lights?
lor3nzo Offline
Loc: idaho
Before anything, i have checked all fuses, nothing appears blown, however i can't find a fuse for the reverse lights, i don't even know what fuses go to where because i don't have the owners manual.
Its a 2002 retired police car and still had all the wiring for the lights etc. I found a pulse box towards the front and disconnected it and took the "extra" wiring out, I guess i never had proper working reverse lights, they would just blink when i went into reverse. Since i took the wiring out it appears that it also took out my reverse lights.
I need someone who knows about this, I'm thinking something was crimped to the reverse lights, more than likely the pulse box(which in turns makes them blink) but i'm having problems finding this wire, do any of you have maybe a wire diagram? I can't see if the reverse switch has been disconnected or not because there is just no room to see by the tranny.
-=2002 Crown Victoria Police Interceptor=-
#2256101 - 03/10/11 06:25 PM Re: no reverse lights? [Re: lor3nzo]
GhostRider Offline
Go to www.helminc.com and order the owners manual portfolio. Fuse 16 is the reverse lights. My reverse lights crapped out once. It was a bad sensor
-Tim
#2256359 - 03/10/11 11:48 PM Re: no reverse lights? [Re: lor3nzo]
lor3nzo Offline
Loc: idaho
what sensor went bad, wouldn't that set the check engine light? I don't have any codes thrown. I will download a layout @ alldata.
#2256499 - 03/11/11 07:36 AM Re: no reverse lights? [Re: lor3nzo]
GhostRider Offline
Sorry, I was on my Droid when I last posted and didnt have access to data. They found it was the Neutral Safety Switch that went bad. I dont know why they call it a sensor.
F8AZ-7F293-AA is the part number and it runs around $40 or so.
Here are the techs notes on the invoice. Maybe that may help you. I dont know what the "DTR" is though that he speaks about.
Originally Posted By: Ford Technicians Notes
CUSTOMER STATES BACK-UP LIGHTS ARE INOP. SENSOR FAILED INTERNALLY. VERIFIED CONCERN. CHECKED OASIS NOTHING FOUND. CHECKED FOR POWER AT REVERSE LAMPS. NO POWER. FUSE GOOD. CHECKED FOR POWER TO REVERSE LAMPS FROM DTR. NO POWER FROM SENSOR. REPLACED SENSOR AND VERIFIED REPAIR.
-Tim
#2256889 - 03/11/11 05:39 PM Re: no reverse lights? [Re: lor3nzo]
TechnoWeenie Offline
Loc: The perimeter
DTRS
Digital Transmission Range Sensor.
15 min job.
#2256894 - 03/11/11 05:49 PM Re: no reverse lights? [Re: lor3nzo]
GhostRider Offline
So is the Neutral Safety Switch the same as the DTRS? When I looked it up by part number it came up as a sensor and as a neutral safety switch. On mine, they replaced the neutral safety switch.
-Tim
#2256901 - 03/11/11 06:06 PM Re: no reverse lights? [Re: lor3nzo]
lor3nzo Offline
Loc: idaho
i don't believe this is a sensor issue, it has to be a wiring issue, simply because as soon as i removed that pulse box they stopped working all together haha
#2257134 - 03/12/11 01:04 AM Re: no reverse lights? [Re: GhostRider]
Loc: The perimeter
NSS is a function of DTRS. It essentially says what gear the transmission is actually in.
#2257141 - 03/12/11 01:18 AM Re: no reverse lights? [Re: lor3nzo]
Loc: The perimeter
Correct.
Look in trunk near drivers side hinge, it feeds the reverse lamps. You'll probably find it cut.
2 registered (RF_Overlord, speedfreak), 136 Guests and 18 Spiders online.
Traffic22 15
