#1065039 - 11/14/06 05:07 PM Ignition Coil Replacement
Game Over Offline
Loc: Frisco, Texas
My CV is at the dealership, they found that my ignition #'s 1 and 5 were bad. They offered to replace them for me for $636. I know I can find the ignition coils at Autozone for approx. $48/ each, does anyone know a better, less expensive place to get them, in case I want to get all 8.
The symptoms are, my car was stalling during driving and it appears to be jumping out of gear.
2002 Crown Vic LX
Flowmaster Original 40's with 3 1/2 inch tips
K&N Air Filter
Turbonator (Don't watse your money!)
Limo Tint
#1065040 - 11/14/06 05:19 PM Re: Ignition Coil Replacement
nyinterceptor Offline
Loc: Miami , FL
damnn , forget the stealership change them yourself , takes like 20 minutes , try ebay ! , maybe a good time to change plugs to
2001 CVPI ex NY highway patrol..Tork Tech Supercharged!! 9 lbs of boost. Front mount Air to Water Intercooler. Bought in 2004
T-LOK,Lightweight racing seats with custom-made brackets, Mark VIII alt, full mandrel bent exhaust with summit turbo Mufflers And OEM marauder tips,optima in trunk, air lifts, edelbrock IAS, Built Dirty Dog 4R70W with 9.5 3600rpm stall converter. scgII,AEM A/F, autometer boost in custom cupholder mount, Mail tune by Reinhart. 17x10.5 cobra Wheels with 315/35/17 Summis.
#1065041 - 11/14/06 06:31 PM Re: Ignition Coil Replacement
Game Over Offline
Loc: Frisco, Texas
Would you happen to know which cylinders are #1 & #5
2002 Crown Vic LX
K&N Air Filter
Limo Tint
#1065042 - 11/14/06 06:42 PM Re: Ignition Coil Replacement
cgarison Offline
Loc: Pennsyltucky
I just ordered eight off ebay for $100.00
2009 Mercury Grand Marquis
Dual Exhaust
P71 Zip Tube
HPP Sway Bar
http://cgarison.blogspot.com
#1065043 - 11/14/06 06:45 PM Re: Ignition Coil Replacement
Loc: Miami , FL
if i remember correctly it goes from the passanger side the front is #1 , i think it goes 1234 pass side .. 5678 driver. im not sure i will let you know later when i find my book
Edited by nyinterceptor (11/14/06 09:23 PM)
#1065044 - 11/14/06 06:55 PM Re: Ignition Coil Replacement
Joe Bernardo Offline
I am pretty sure the #5 cylinder is first one, closet to the radiator on the drivers side. Mine went out in #5 also. I got mine off ebay for $80.00. The only problem i had was the brass inserted threads in the manifold would spin out when i tired to remove some of my coils, so be careful of that.
1999 Crown Victoria Police Interceptor
BF Goodrich Traction TA's
everything else stock.
#1065045 - 11/14/06 06:55 PM Re: Ignition Coil Replacement
Vicrebel Offline
Loc: IL
Should be driver's side front=1, 5= two pistons back from that one on the same side.
Under Construction,, expect long delays!
1993 Crown Vic LX
#1065046 - 11/14/06 07:11 PM Re: Ignition Coil Replacement
JCG1 Offline
Loc: Chicago
That is correct.
See the old-school racer arrangement for pulling/checking/reading plugs (and keeping them in order) using a box/cardboard and a marker:
And if I were you I'd pay for the motorcraft cops. I wouldn't pay the dealership to install them, but I wouldn't buy the cheap cops. But that's just me.
Former Ford Projects: 1967 Mustang w/transplant 351W : 1984 302 T-Bird : 1987 5.0 T-Bird : 1989 5.0 Mustang : 1992 5.0 T-Bird : Current: 2000 CVPI
Renegade Racing 4.6 SOHC: Cobra Crank, Manley Rods, Coated Diamond Pistons 10.5:1 comp w/valve reliefs, PnP npi heads, PI intake, Comp Cams, 70mm TB, MM Airbox/80mmMAF/04 Zip, 190lph walbro, FRPP shortys, custom 2.25 duals, Xcal2, Jmod RoadmasterTranz, Dirtyd0g TC.
14.46 @ 95.59 / 14.50 @ 95.91 tuned by Darrin at BC Automotive
Watch a 14.58 @ 94.13 Vid by DJChicago HERE
#1065047 - 11/14/06 07:20 PM Re: Ignition Coil Replacement
cdr-m@x Offline
Loc: North East PA
Look on e-bay, wait for the right deal. I got brand new Ford coils for $28 a piece.
2008 CVPI
265,000 miles. J-mod, Mo's 93 octane tune. Steeda Under drive Pulleys. Trick Flow Ported and polished Plenum. BBK 75mm TB. Metco control arms. Some kind of Flowmasters.
1998 CVPI
215,000 miles Refurbished at 87,400 miles, sleeping for now.
#1065048 - 11/14/06 07:53 PM Re: Ignition Coil Replacement
Steve83 Offline
Ford is the only mfr. who numbers cylinders sequentially within each bank. All others have an odd bank & an even bank. But ALL engines have cylinder #1 furthest from the bellhousing, regardless of anything else. Since most Ford V engines have the first rod on the crank going to the passenger side, that's where #1 is on most Ford Vs. But always look at the engine from the side to see which valve cover is further forward.
Many engines also have the cylinder numbers & firing order cast into the intake, but not so much on modern EFIs.
#1065049 - 11/14/06 09:18 PM Re: Ignition Coil Replacement
JCG1 Offline
Loc: Chicago
THAT IS NOT CORRECT (I didn't mean you, I meant someone above but I must have been sitting on the post too long)
#1 is on the PASSENGER SIDE (first)
#5 is on the DRIVER'S SIDE (first)
See the pic I posted
#1065050 - 11/14/06 11:17 PM Re: Ignition Coil Replacement
Vicrebel Offline
Loc: IL
Sorry just trying to be helpful, but upon further reading and such, I just realized that I was talking about a Chevy motor. Sorry for the confusion, but with me it happens alot LOl.
1993 Crown Vic LX
#1065051 - 11/14/06 11:19 PM Re: Ignition Coil Replacement
Captain J Offline
Loc: USA AOK!
Well I am selling Motorcraft COPs with the boots for 10.00 in the For Sale section.
2007 CVPI (Last one was a 2002).
Mods: Paint job and a detail.
R/T Charger with more mods then can be listed (Pro Charger SC, Heads, Cam, ect...)
http://au.youtube.com/watch?v=sWS-FoXbjVI&feature=related
http://au.youtube.com/watch?v=pKFKGrmsBDk
#2259797 - 03/15/11 11:27 PM Re: Ignition Coil Replacement [Re: Game Over]
xxalias75xx Offline
Loc: Illinois
2002 police interceptor crown vic and I need to replace my plugs/coil pack. How do you replace the coil pack - do I need to remove the fuel rail? Is there a vid out there that shows how to properly remove/replace the coil packs?
2002 Ford Crown Vic Police Interceptor
#2259850 - 03/16/11 12:57 AM Re: Ignition Coil Replacement [Re: xxalias75xx]
Big_Bad_Joe Offline
Loc: Rochester NY
no you do not remove the fuel rail
disconnect battery
unplug connector from harness and undo single small bolt.. (iirc its an 8mm?) but its small.. small socket is all you need.. undo it ....
pull the boot and coil out
vacuum the plug well with a shop vac.. you can use one with the right tube attachment or fashion one yourself.. just make sure it sucks hard... (Ok free post on that one)
then use a long socket to remove the plug.. have a telescoping magnet handy if help fetch sockets that might not come back lol or duct tape holding the socket on works
install new plugs... i always use a piece of vaccuum hose to reach down in and turn it by hand making sure not to strip threads... on a 2002 gap should be .054.. check them they are often not right when shipped
put dielectric grease around base of boot, press new boot on plug... make sure spring "clicks" in place... bolt coil on, snap connector on wiring harness... repeat 7 more times
crack beer beer1
Edited by Big_Bad_Joe (03/16/11 12:58 AM)
Underdrives from ADTR.net
Given to DG in Ohio
7 registered (lmrogp, JaxRhapsody, dpk, GMT400, rrusty112, Htowns), 45 Guests and 10 Spiders online.
Ezbok58a 159
a_d_a_m 152
charlieD 148
BigMerc96 132
dpk 120
Ponyguy 116
White99MGM 104
reminc70 77
SocalSam 73
Moby_Vic 68
