#2267925 - 03/29/11 10:53 AM What’s the best exhaust option for me?
TNK8 Offline
Loc: Los Angeles
Hello,
I am looking to put a new exhaust on my 2004 Interceptor and I am not sure what would be the best option to go with. I plan on using my car for Autocross and some Nav-rally events. Maybe the occasional leisure drive here and there. But mostly I want the highest performance I can get. I don’t really care so much as to what sound it makes. Likely all of these high end exhausts sound pretty good regardless. But I am interested in the best performance and reliability. Price is not an option here, I have a pretty good play budget for this car. So I want to put the “best” I can on her. Realizing best may be a relative term in regards to opinions.
I did like the Borla Catback system, though I have heard mixed reviews on this board about that setup.
Thank you for any help or advice you can give. I do appreciate it.
#2267935 - 03/29/11 11:05 AM Re: What’s the best exhaust option for me? [Re: TNK8]
gahorneck Offline
Loc: AL
Hi and welcome. I am also setting up my car for Autocross duty. The gains in exhaust systems are minimal, so I went with the lightest possible dual system I could find. The OEM system is heavy. I used the Walker duals, but they are not much good in the rust belts as they are lightweight steel, but in LA, no problem. I like the way thin wall exhaust tubing sounds on the 4.6 and used it on all my Mustangs. About 2 months after installing the Walker system, it started to take on a very nice growl. Put your money into the suspension and go with the light steel Walker replacement system. Oh... and its dirt cheap. Check my vid in sig.
2009 Grand Marquis - AFE CAI, ADTR ported manifold, HyperTech tune, 3L27 RAR, dual exhaust, Shelby GT 500 wheels, Goodyear Eagle F1's (255/285's), KYB CVPI shocks, Stillen Motorsports rotors, Hawk HPS pads, ADDCO sway bars, Metco control arms & watts. http://youtu.be/1N4bR_LqDiE
#2268031 - 03/29/11 01:10 PM Re: What’s the best exhaust option for me? [Re: TNK8]
98VicP71 Offline
13.97@99MPH
Loc: ATL
best exhaust would be the new Stainless works Long tube headers for the 03+ which I believe Stainless Works also makes a cat back setup as well now.
Or you could go with the Kooks setup.
doing long tubes will net you a gain. but for auto cross you would probably want a high stall converter and set of gears with a min of 3:73's if not 4:10's. Probably would not worry about swapping cams since you want low end TQ for auto cross.
Def will want ot get the addco sway bars front and rear, upgrade the rear control arms with the metco's or similar from ADTR.net.
That should be a good start.
Note: If you do a gear swap you will require a tune to adjust the speedo error.
However a tune is a good idea anyway as it will wake the car up.
#2268037 - 03/29/11 01:25 PM Re: What’s the best exhaust option for me? [Re: 98VicP71]
ImpulseRocket89 Offline
Loc: Omaha, NE USA
Living in LA, you might want to consider the fact that most longtube headers for these cars are not CARB legal. If you planned on using this car on the road at all it is something to consider. Even if you can pass the sniffer test, without that CARB exemption sticker you will be in a world of hurt if you get caught.
#2268042 - 03/29/11 01:32 PM Re: What’s the best exhaust option for me? [Re: TNK8]
gahorneck Offline
Loc: AL
Other than weight, living in CA is why I suggested the direct replacement system.
Edited by gahorneck (03/29/11 01:33 PM)
#2268054 - 03/29/11 01:46 PM Re: What’s the best exhaust option for me? [Re: gahorneck]
98VicP71 Offline
13.97@99MPH
Loc: ATL
good call did not notice the user was in Cali..
Moderator:  BigMerc96, Liquid
1 registered (1 invisible), 221 Guests and 12 Spiders online.
a_d_a_m 167
dpk 155
BigMerc96 128
Moby_Vic 114
WSTRLNG 85
reminc70 78
Ponyguy 75
RF_Overlord 65
Bellwestern80 58
SocalSam 48
Osu
Osu
