#2279401 - 04/15/11 10:41 PM How to program a replacement PATS key
interceptor1985 Offline
Loc: OREGON
Original thread on ford-trucks.com<--clicky
These instructions will save you a lot of money. The dealer wants at least $50 just to do this simple procedure.....
To start off, I'll explain a bit about what a PATS key is, what it does, and why this might concern you.
PATS is an acronym that stands for Passive Anti-Theft System (Ford also calls this SecuriLock). It is also called a transponder key. It is a security feature found on most (if not all) new Ford products, and what it does is disable your vehicle's starter unless your specially programmed key is used to start the vehicle. There is a computer chip inside of the key, and without that you will NOT be able to start the vehicle -- even if you have a regular (non-PATS) key with the correct cuts, it will not work.
For convenience, I'm also including a list of other vehicles that these instructions apply:
Ford Contour ‘98–up
F-150 ‘98-up
Ford Crown Victoria ’97-up
Ford Escort 99-up
Ford Excursion ‘00-up
Ford Expedition ‘98–up
Ford Explorer ’98-up
Ford Focus ‘00-up
Ford Mustang ’96-up
Ford Ranger ’98-up
Ford Taurus ’96-up
Ford Windstar ’98-up
Lincoln Continental ’98-up
Lincoln LS ’00-up
Lincoln Mark VIII ’98-up
Lincoln Navigator ’98-up
Lincoln Town Car ’98-up
Mercury Grand Marquis ’97-up
Mercury Mountaineer ’98-up
Mercury Mystique ’98-up
Mercury Sable ’96-up
NOTE: These instructions may apply to more or less vehicles than those listed above. I cannot confirm that these procedures work for every year and model listed. See your dealer if to confirm this.
On-Board Programming Method "B"
for Ford keys (1996 -early 1998 Ford, Lincoln, Mercury)
If you want to initiate a new master key....
1. Insert new key into ignition cylinder and turn it to the ON (RUN) position. The security light on the dash will flash for fifteen minutes.
2. When the security light stops flashing, you have FIVE minutes to start the next step. Turn the ignition cylinder OFF and then back to the ON (RUN) position. The security light on the dash will flash for fifteen more minutes.
3. When the security light stops flashing, you have FIVE minutes to start the next step. Turn the ignition cylinder to OFF and then back ON (RUN) position. The dash will flash for fifteen more minutes.
4. After the security light stops flashing the third time, the new key has been programmed into the vehicles computer and will operate the car. It has replaced ALL the previous electronic key codes and is the ONLY key programmed into the vehicles computer.
If you want to add a key....
1. Insert an existing key into the ignition cylinder.
2. Turn the ignition cylinder to ON (RUN) and back to OFF.
3. Remove the existing key and, within 15 seconds, insert the new key and turn it to ON (RUN).
4. The security light will light up for two seconds to indicate success in programming the key into the vehicle.
5. Don't attempt to start the vehicle with any key for at least 1 minute.
On-Board Programming Method "C"
for Ford keys (Later 1998-newer Ford, Lincoln, Mercury)
1. This requires that the vehicle be connected to special dealer equipment. There are two ten minute delays involved while this device erases all existing key programming and sets up the vehicle computer to accept new key codes. Two new keys should be ready because the system requires a minimum of two keys in the program. After the first two keys are programmed, additional keys can be entered individually by following the instructions for adding duplicate keys (below).
**You must have two original keys to perform this procedure. If you only have one key, you WILL have to take it to the dealer to get it programmed**
1. Insert and existing (working) key into the ignition cylinder.
2. Turn the ignition cylinder ON (RUN) and back to OFF. Ignition should stay on for at least ONE SECOND.
3. Remove the existing key and, within TEN seconds, insert a second working key and turn it to ON (RUN) and the back OFF. Ignition must be in ON for at least ONE second, but no more than TEN seconds. Remove the key.
4. Insert the new key before TWENTY seconds have elapsed and turn it to ON (RUN). Leave it the ON position for at least ONE second and turn back to OFF.
5. The security light will light up for THREE seconds to indicate that the new key has been successfully programmed.
6. To program additional keys, repeat steps 1 through 5
As a precautionary measure for all of the above procedures, you should wait at least one minute after you have performed this until you start your vehicle.
found this while trying to find information on how to get the 2000 explorer's PATS system working with the new engine.
#2279442 - 04/15/11 11:29 PM Re: How to program a replacement PATS key [Re: interceptor1985]
Should not be a issue unless you are using a different PCM than the orignal...
1998 Grand Marquis LS. 76K mi.
2007 Grand Marquis GS. 77K mi.
#2279489 - 04/16/11 01:09 AM Re: How to program a replacement PATS key [Re: interceptor1985]
Loc: OREGON
Problem is EVERYTHING is different, I'm trying to use the complete OBD-V system in my 85 instead of OBD-IV
#2279582 - 04/16/11 10:52 AM Re: How to program a replacement PATS key [Re: interceptor1985]
He he, well you'll have to either have the PATS feature turned off(some tuners can do this), OR use a CVPI PCM that does not have active PATS(the '99 ARA3 is considered the best, I have one in my '98 MGM)... The other option would be to install all the PATS components, but you'd still need someone to program keys(that won't fit a '85 lock cylinder)... Some locksmiths can program keys, I had one made by a local for my Marauder that only had one key, key and programming was $50...
#2280014 - 04/17/11 04:41 AM Re: How to program a replacement PATS key [Re: interceptor1985]
Loc: OREGON
i somehow doubt a 4.6 pcm would run a 2000 5.0w, I really just placed this here because there is tons of other cars here with PATS that it might help...lol
#2280137 - 04/17/11 11:30 AM Re: How to program a replacement PATS key [Re: interceptor1985]
Ahh the PCM is stupid, doesn't really know what engine it's running, the 4.6 & 5.0 are close enough in size to each other, it'd work... You'd just have to be sure the injector size and MAF meter matched the PCM...Of course you'd have to use the crank trigger and coil packs but those are already on a 2K 5.0...
When I was having PCM problems with my '93 Lightning due to failed capacitors, I ran it on a PCM from a '91 F350 with a 460, shifted the transmission correctly and ran good(though not as strong as the correct one)... Those are both speed densety so I didn't have to worry about the MAF...
Moderator:  BigMerc96, Quasar
6 registered (Tenevic_P71, H3LlIoN, albertaglen, 3 invisible), 87 Guests and 88 Spiders online.
a_d_a_m 217
BigMerc96 145
EZlivin11 105
Chaplian 103
RF_Overlord 99
Moby_Vic 98
dpk 93
charlieD 90
Ponyguy 86
White99MGM 83
