#2283274 - 04/22/11 11:30 AM Fuel filler neck removal How?
96crownvic Offline
Loc: wisconsin
Filler neck is rusted out under the rubber cup at the fender.
I need some help as to how to remove the filler neck after all fasteners are removed. I don't think I can pull the neck out of the opening for the fuel door because the vent tube looks as though it won't fit through. Do I push the filler tube into the tank and then maneauver it around and pull it out the wheel well. I hope I don't have to drop the tank.It's on a '96
Thanks.
#2283329 - 04/22/11 12:27 PM Re: Fuel filler neck removal How? [Re: 96crownvic]
larryo340 Offline
Loc: Long Island
Good news
....you don't have to drop the tank joy
1996 Crown Victoria fuel filler neck R+R.pdf (1096 downloads)
MOD List for MGM
...Marquis sold frown
#2283331 - 04/22/11 12:27 PM Re: Fuel filler neck removal How? [Re: 96crownvic]
TheShadow Offline
Loc: SoCal High Desert
(It won't)
(Yes)
(Nope)
It's on a '96
Thanks.
Just make sure the tube is really, really clean and smooth just outside the tank before you slide it in the little it needs. There's a rubber seal mounted on the tank that you don't want to gouge up, unless you plan on replacing it (a worthy investment, considering the age). And twisting helps a lot to get the flange oriented.
#2283652 - 04/22/11 10:13 PM Re: Fuel filler neck removal How? [Re: 96crownvic]
96crownvic Offline
Loc: wisconsin
Thanks for the link larryo340. TheShadow too, that is what started what I found. My seal I think is leaking also and I was getting ready to replace it.
More worried now about the crap I might get in the tank shoving the neck in it and just finding a replacement neck.
#2406427 - 11/13/11 10:47 AM Re: Fuel filler neck removal How? [Re: 96crownvic]
nadont Offline
Loc: Iowa
is this the same for my 99 cvpi, im trying to replace mine and it wont come out.
-99 P71 8 yr. retired Black Hawk County IA warrant vehicle
-03 Marauder K&N CAI, flowmaster mufflers, tint 25%
-99 P71 Portland Police Investigations car then 10 years in a barn
#2406458 - 11/13/11 11:48 AM Re: Fuel filler neck removal How? [Re: nadont]
rtg143 Offline
Loc: Oregon,U.S.A.
It should be the same, but if it doesn't come out, you can loosen the fuel tank straps to get more clearance.
RTG
#3316369 - 08/11/16 05:39 PM Re: Fuel filler neck removal How? [Re: 96crownvic]
lesgarten Offline
Loc: Florida
I found this thread because I need to replace the Fuel Pump and I need to get some gas out.
So I am trying to get the neck out to siphon out some fuel.
But...
The PDF mentioned above says to drain the tank first!
If I could drain the tank I wouldn't be screwing around with the filler neck!
Any suggestions? I am having an issue removing the filler neck.
<<Les Garten>> 1998 CrownVic LX
1 registered (SpecialK), 263 Guests and 13 Spiders online.
a_d_a_m 164
dpk 153
BigMerc96 130
Moby_Vic 112
WSTRLNG 88
reminc70 79
Ponyguy 78
RF_Overlord 68
Bellwestern80 57
SocalSam 47
