Page 2 of 3 < 1 2 3 >
#2297290 - 05/15/11 11:34 PM Re: ??? about Cat Converter's and exhaust pipe sizes [Re: lowmile97gm]
Quickvic30 Offline
Just watchin
Loc: Minneapolis, MN
OK so everyone is saying that removing the secondary cats you will loose TQ but then recomending high fow cats......ummm yeahhh laugh
#2297292 - 05/15/11 11:36 PM Re: ??? about Cat Converter's and exhaust pipe sizes [Re: DreadfullyDespized]
Danno1985 Offline
Loc: Milwaukee, WI via NY
Originally Posted By: DreadfullyDespized
Jumping on the bandwagon. From what I am gathering.. Removing the secondary cats is more so a con then a pro?... One of mine got hit by a bad road bump on the driver side and has a huge rattling sound when I am in park and idling. It is quite an annoyance. Though I was debating on chopping off the secondary cats and putting 2.25inch pipe through instead. But if the removal of the cat causes lack in torque and more engine work that alone makes me less likely to do it. Which then makes it more realistic to stick with just doing a high flow aftermarket cat-back exhaust setup. Would someone be able to correct me if I am wrong? Just trying to understand with better detail.
Obviously this is fiercely debated, but I don't think cutting the cats out alone will hurt your power, if anything the engine will be able to expel exhaust gasses faster... especially if your cats are clogged. From my understanding though, if you don't "tune out" the O2 sensors, they'll freak out and the car will go into a fail-safe fuel/air mix that may not be the optimum.
You will lose torque if you expand the exhaust beyond what the engine can flow though... think of a garden hose. Yeah, you could get a fire engine hose and hook it up to your regular faucet to wash your car but it's going to take a lot longer for the water to get out. A smaller diameter hose may not have as much capacity for flow, but it will move the water your faucet is capable of pumping quickly. You want the exhaust moving out of the engine as quickly as possible. That's delta pressure. Delta pressure = good.
2000 Crown Victoria LX. 160K. Duals, 3.73 trac-lok, currently rocking rally wheels with 215/65r16 Dunlop snows. Mobil 1 0W40 in the crankcase, Royal Purple 75W90 in the back. Still kicking'.
#2297329 - 05/16/11 12:28 AM Re: ??? about Cat Converter's and exhaust pipe sizes [Re: lowmile97gm]
DreadfullyDespized Offline
Loc: Hutchinson, MN 55350
How could one find out the delta pressure (rating?)... Obviously you want best flow. But you want minimal restriction (back pressure) to keep the engine performing it's best. My plan has been to go with 2.25 or 2.5 inch cat back 304 stainless. No muffler no nothing after the cats though still keeping the H pipe design or possibly turning it into an X pipe. So what I am wondering if only having the bends and the pre-cats on the exhaust system though still going all the way back factory length. Would it hurt the system to remove the mufflers and cats?
DD Security Inc.
Console modding/electronics repair/Airsoft
#2297347 - 05/16/11 01:20 AM Re: ??? about Cat Converter's and exhaust pipe sizes [Re: lowmile97gm]
Loc: Iwakuni, Japan.
Australia doesn't use cats on their cars to my knowledge they do just fine. The old school muscle cars didn't have cats, they didn't seem to have a problem, definitely with torque production.
A catalytic CONverter is nothing more than an exhaust restriction. What happens when you remove restrictions? You gain more power.
If this isn't true then why do so many people change out the single exhaust for duals?
1990 Mazda Miata
2000 Toyota Crown Estate Athlete V
1994 Autozam (Mazda) AZ-1 (Kei Car legend)
#2297394 - 05/16/11 07:00 AM Re: ??? about Cat Converter's and exhaust pipe sizes [Re: DreadfullyDespized]
cragantler1 Offline
Loc: Fla. Cracker in South Conway
Well there was a heatboil in the road from winter to summer quick changes and it first hit the skidplate then I turned before it hit the tranny and instead dented my driverside cat.
Holy Sheet. you guys must have some massive frostheaves there hairraise
2004 Arizona Beige P-73, gone but never forgotten
2004 P-73,113k+
Performance & Handling:
P-71 H-pipe with Flowmaster 50s/Rear Meow delete/ADTR P&P plenum/70mm TB/Marauder swaybars/MZT/BOC tune/J-Mod/ 2006 P-71 rear coils/Gatorback belt/2005 17" Mustang GT Premium rims with Pirellis/ FRPP 3.55's / FRPP Trak-Lok
best time, pre-gear change: 15.4 @ 91.6mph
Appearance:
Honeycomb color matched grille/lower grille mesh mod/S-55 tail/reverse lights mod/bumper tuck/window chrome and wood dash delete/black reflective rear fascia/side marker mod/15% rear, 35% front tint/Marauder gauge cluster/1999 Lincoln Continental console and floor shift/Marauder gauge pod with "real" Autometer gauges/ Ford Focus driving lights with 5000K HID's wired to Marauder light switch for factory operation/repaired LCM/Marauder corner lights
#2297395 - 05/16/11 07:02 AM Re: ??? about Cat Converter's and exhaust pipe sizes [Re: Bondfreak13]
cragantler1 Offline
^^^^^^^ bow beer1
2004 P-73,113k+
Appearance:
#2297433 - 05/16/11 09:17 AM Re: ??? about Cat Converter's and exhaust pipe sizes [Re: lowmile97gm]
P71CVMAN Offline
Loc: wIScONSiN
All I know is I ran 14.9s with stock exhaust & then with hollowed out rear cats & glasspacks dump'd I have gotten a best of 14.7s. I picked up 2 tenths on the little exhaust mods I made. I definatly didn't lose any power hollowig those rear cats out.
Exhaust/dragstrip videos
#2297456 - 05/16/11 09:41 AM Re: ??? about Cat Converter's and exhaust pipe sizes [Re: lowmile97gm]
98VicP71 Offline
13.97@99MPH
Loc: ATL
yes you will gain a little power as long as you keep back pressure you wont loose low end TQ.
think of a motor as an air pump. The more efficient you can pull air in and expell air the more power you make.
#2297488 - 05/16/11 10:53 AM Re: ??? about Cat Converter's and exhaust pipe sizes [Re: Bondfreak13]
Mr. 427
THIS. grin
1964 Ford Galaxie 500 R-Code
1972 Ford Galaxie 500
2008 Ford CVPI
#2297511 - 05/16/11 11:37 AM Re: ??? about Cat Converter's and exhaust pipe sizes [Re: lowmile97gm]
flyboy Offline
Ret US Army Medic
Loc: Chillicothe, Mo
Not to rain on anyone's parade but I know New Jersey frowns on removing cats. Any of you from the "Garden State" ever watch how they inspect vehicles in their inspection stations? I lived there from 1969 to 2003. A mirror on a pole was put under the car & the exhaust system was examined closely, the gas cap was removed to check the size of the tank inlet & older vehicles were put on a special line that picked up the front wheels & shook the car to check the front end.
#2297567 - 05/16/11 12:50 PM Re: ??? about Cat Converter's and exhaust pipe sizes [Re: lowmile97gm]
In Massachusetts, it's not unusual for an inspector to crawl under the front and rear of the car to check for cats if your exhaust is too loud.
Originally Posted By: etcv97
#2297680 - 05/16/11 05:49 PM Re: ??? about Cat Converter's and exhaust pipe sizes [Re: lowmile97gm]
P71CVMAN Offline
Loc: wIScONSiN
In select counties they just plug the car in here and check for codes.
#2297713 - 05/16/11 06:36 PM Re: ??? about Cat Converter's and exhaust pipe sizes [Re: lowmile97gm]
HA here in newfoundland when having an inspection there is no emissions checks.
#2297937 - 05/16/11 11:50 PM Re: ??? about Cat Converter's and exhaust pipe sizes [Re: BillyBishop]
CrownVic97 Offline
Loc: Brockton, MA
This made me laugh...hysterically
2003 Mercury Marauder 300A: 170k miles.
Bolt ons, TR-3650, 4.56s.
#2298005 - 05/17/11 02:09 AM Re: ??? about Cat Converter's and exhaust pipe sizes [Re: lowmile97gm]
Ogre Offline
Loc: Bellefontaine, Oh
here in ohio, when i had an off-road pipe on my 98 GT i had 3 different cops compliment me on how my car sounded over the time I owned it.
3 registered (Scuba_Steve, CarMon, alumarine), 108 Guests and 9 Spiders online.
