#2308906 - 06/05/11 09:20 AM Not Grounded Properly?
Marqed_Man Offline
Loc: il
What things would happen if my car wasnt grounded correctly?
2004 LIncoln Town Car - Dark Charcoal Metalic. Motor has 82K miles. The rest of her has 290K miles. Past owner didnt take care of her. Im bringing her back to exceptional condition
#2308949 - 06/05/11 10:40 AM Re: Not Grounded Properly? [Re: Marqed_Man]
gord_bolton Offline
Loc: Saskatoon, Saskatchewan
Things would work poorly or not at all. A loose connection would cause things to work intermitantly or not at all. A high resistance connection might cause things to not work as intended or not at all.
In a word the system would be buggy.
Almost all automotive diagrams show electricity flowing from positive to negative. I am told that the actual electrons flow from negative to positive so a poor ground would inhibit or restrict both voltage (pressure) and amperage (rate of flow) to all devices downstream.
#2309044 - 06/05/11 01:51 PM Re: Not Grounded Properly? [Re: Marqed_Man]
cv4life Offline
Loc: atlanta
x2 and it can cause things to get hot
2001 Crown Vic LX non police: Full SMD LED Mod (Hood Trunk Interior): K&N full air intake kit: KICKER CVX 15 and Alpine PDX1000 alpine speakers all the way around: HID 6K kit:
#2309060 - 06/05/11 02:35 PM Re: Not Grounded Properly? [Re: Marqed_Man]
TheTank Offline
Loc: mississippi
Also if your worried about poor grounding in your primary wiring you could do the "Big 3" in 4 awg or larger.
The big three is batt negative to frame, engine to frame, and alternator output to positive battery terminal. It will also bring up your voltage a little bit.
If you google search the Big 3 youll find write ups and youtube videos with pics and how tos.
2000 P71
18" Fi BTL
AQ 2200D
Pioneer DEH 1200
#2309101 - 06/05/11 03:51 PM Re: Not Grounded Properly? [Re: TheTank]
Marqed_Man Offline
Loc: il
Well my wiper motor wasnt parking itself so I replaced it. Now the damn thing wont turn on OR it will act oddly. Also on occasion while the car running, the lights will NOT shut off! Also frequently, the lights in the radio dont go on. nono The AC was acting up too but not anymore. It was automatically changing from cold max AC to outside warm humid air.
What does that sound like to you folks?
PCM? Bad ground? Bad luck?
Also what length would I need for a new ground wire?
#2309176 - 06/05/11 06:07 PM Re: Not Grounded Properly? [Re: Marqed_Man]
gord_bolton Offline
You might try a different multi-function switch and see what happens. A little short inside the switch can cause all kinds of trouble. To my knowledge that is the only thing that brings wipers and lights circuits together.
#2309438 - 06/06/11 03:19 AM Re: Not Grounded Properly? [Re: gord_bolton]
Marqed_Man Offline
Loc: il
Are you referring to the stalk for the turn signals and wiper?
I dont know if its not grounded. I dont know if its just another bad motor. I dont know if its a bad stalk. Grrrrrrr.......
How difficult is it to replace the stalk?
#2309734 - 06/06/11 05:40 PM Re: Not Grounded Properly? [Re: Marqed_Man]
gord_bolton Offline
Phillips screwdriver and torx screwdriver or 7mm socket I think.
Vice grips to get the tilt lever out of the way.
And a little probe to push the release for the key cylinder. Disconnect battery, turn key to on, probe from hole under column and pull on key cylinder.
9 registered (Bangster, Fordiesel69, 1990CrownVic, LSE_Dave, mrjon1985, 1 invisible), 46 Guests and 79 Spiders online.
NM117 324
RF_Overlord 129
EZlivin11 126
Moby_Vic 126
BigMerc96 124
Chaplian 115
mdnos 97
Ezbok58a 94
a_d_a_m 92
Ponyguy 91
