#2312659 - 06/11/11 08:53 AM Cat efficiency below threshold BOTH banks??
fireandice9008 Offline
Loc: Southport, NC
I'm getting codes for catalyst efficiency below threshold on bank 1 and bank 2. Before the motor swap, I was just getting a code for bank 1, now i'm getting one for both. FYI the car and exhaust has 165k miles, the motor's around 49k.
I had to swap the passenger (bank 1 ?) upstream sensor with one from the '06 because the connector got cracked in the chaos. I've got the other 3 from the '06 and i'm going to try swapping them in first, according to Motorcraft they're the same part.
What's the possibility all 4 of my cats took a dump at once? If the O2s don't fix it what am I looking at, cats?? FYI, I don't have a custom tune yet to make everything work well together. I've got about a month to get this thing inspection ready, stupid emissions inspection mad
Edited by fireandice9008 (06/11/11 08:54 AM)
Edit Reason: mileage
2000 P71, Boiling Spring Lakes NC Car 5, former marked slicktop, never wrecked. **Now with factory cruise** K&N drop in, tucked bumper, 35% all around, Goodyear Eagle GTs. Motor replaced at 161k with an '06 with 47k.
2006 P71, Valdosta, Ga Car 0312. 47k miles, rear-ended and rolled over. You've probably shaved with it. Selling what's left, PM for requests.
#2312670 - 06/11/11 09:21 AM Re: Cat efficiency below threshold BOTH banks?? [Re: fireandice9008]
TheShadow Offline
Loc: SoCal High Desert
If your scanner can monitor the O2 sensor outputs, check that they all are switching. I had 1 slow downstream sensor (Bank 1) on one car that caused both 0420 & 0430.
#2312673 - 06/11/11 09:34 AM Re: Cat efficiency below threshold BOTH banks?? [Re: fireandice9008]
ford05 Offline
Loc: New Jersey
It can be the maf sensor, O2 sensors or the cats. I had this same problem on a 95 marquis. It gave me codes p0130 and p0131. After replacing 02 sensors, spark plugs, trying a new maf and trying a bounch of other stuff, car still had the codes and ran horrible. I then deceided to remove the catalyic converters passenger side and car ran extreamly new. Came to find out it was both cats on the passenger side that were clogged up to the max.
sunroof,ported & polished factory DBW TB and Plenum, 1" TB spacer, rear cat delet with 14" magnaflow mufflers and 3.5" rolled edge tips, custom gauges from Scott Hrbacek at www.customgaugefaces.com, LED interior bulbs, k&n drop in filter with air box mod, 06 p71 intake tube, 5% tints, 09 200amp alternator, Marauder 21" rear sway bar and moog links, bumper tuck, turn signal mod, glowshift rpm gauge, r1 concept smooth rotors with cmax ceramic pads,
coming mods:
2.5" exhaust waiting to be installed, steeda UD's and new clear headlights and side markers.
#2312674 - 06/11/11 09:34 AM Re: Cat efficiency below threshold BOTH banks?? [Re: BigNSlow]
Loc: Southport, NC
Originally Posted By: BigNSlow
Make sure you don't have any exhaust leaks. Are you still using MAF from 2000?
Yes, the entire top end is for the most part 2000. I'm under the impression i'll need a tune for the '06 MAF to work, when that happens i'm going to swap the entire air intake system for like an '04, or maybe the '06 if I can put in a port for the IAC.
#2312676 - 06/11/11 09:36 AM Re: Cat efficiency below threshold BOTH banks?? [Re: fireandice9008]
Loc: Southport, NC
Ford05, i'm thinking the pass. side cats may very well be clogged. I thought the driver's were okay, but they may have gone too. The old motor did burn oil like it was free.
I'm headed out now to swap the O2s since I have them on hand.
#2312708 - 06/11/11 11:21 AM Re: Cat efficiency below threshold BOTH banks?? [Re: fireandice9008]
1998 Grand Marquis LS. 57K mi. One Owner Grandma-mobile
2007 Grand Marquis GS. 55K mi.
Gone But Not Forgotten. '86 LS, '92 LS, '93 GS
#2312749 - 06/11/11 01:26 PM Re: Cat efficiency below threshold BOTH banks?? [Re: fireandice9008]
ford05 Offline
Loc: New Jersey
The 95 marquis I worked on had an oil leak a few months ago. Don't know for how long but when I bought the car, the seller did tell me that it had fail emission and they had to replace a few gaskets and spend a few 100 bucks. When replacing the sparkplugs, the passenger side ones were completly black while the driver side were very clean and looked new. I'm still guess that the marquis still has a leak(oil) and it just caused the cats on that side to clog up with gunk.
coming mods:
#2312773 - 06/11/11 02:25 PM Re: Cat efficiency below threshold BOTH banks?? [Re: fireandice9008]
Blackcvpi Offline
Cynical Jackass
Loc: The 626
Check out this thread.....
http://www.crownvic.net/ubbthreads/ubbth...072#Post2264072
and the video link below.
http://www.youtube.com/watch?v=5icTmYItwiE&feature=related
Before you replace your cats!!
99 CVPI, 01 PI Engine Swap, 04+ CVPI Air Box and MAF, BOC DYNO TUNE, Steeda UD pulleys, ADTR ported plenum, Aviator TB, SW Cat-Back, Heinous control arms, Addco Sway bars, KYB shocks, Powerslot rotors, Raybestos police pads, Headlight relay by BH1976, Factory cruise added, Pony R Parts Cabin Air Filter
08 F250 Super Duty Lariat Crew Cab 6.4 Powerstroke Turbo Diesel, Daystar leveling kit with Bilstien Shocks
#2312788 - 06/11/11 03:11 PM Re: Cat efficiency below threshold BOTH banks?? [Re: fireandice9008]
Loc: Southport, NC
That's interesting reading/watching. I'm still not sure i'm sold on the idea of dumping lacquer thinner in my tank, but if it comes down to it I may. Custom cats are in the works, but not close enough for inspection.
I swapped the remaining 3 O2s and cleared it out. So far it's got 27 miles on it since then and -knock on wood- no CEL. It used to pop it in 4-6 miles. The front ones had a nice coat of some kind of white stuff on them, and the original rear one had rust inside the holes. We'll see if it holds, if it does it's getting inspected tuesday before it changes it's mind.
#2312808 - 06/11/11 04:13 PM Re: Cat efficiency below threshold BOTH banks?? [Re: fireandice9008]
Blackcvpi Offline
Cynical Jackass
Loc: The 626
I know of one person who has done it and saw results......and the car was OK. 1 gallon in 1/2 a tank of gas is not much......but just enough to do the job.
#2312833 - 06/11/11 05:28 PM Re: Cat efficiency below threshold BOTH banks?? [Re: fireandice9008]
ford05 Offline
Loc: New Jersey
i wanted to do this but wasnt sure about it. I did remove the cats a dumbed in a big bucket of water with detergent and that didnt help. It was just completely clogged up.
coming mods:
#2312856 - 06/11/11 07:02 PM Re: Cat efficiency below threshold BOTH banks?? [Re: fireandice9008]
Blackcvpi Offline
Cynical Jackass
Loc: The 626
Its one of those things that you try when you got nothing to lose. If it worst your stoked.....if not then your at the same place you started at.
#2312865 - 06/11/11 07:23 PM Re: Cat efficiency below threshold BOTH banks?? [Re: fireandice9008]
Loc: Southport, NC
Well...it's back on. It blessed me with its amber glow right at the 40 mile mark. I went back to Advance and read them again just to be sure, it's the same 2 codes as before. I can fork out the money for new cats, so I'm going to jump in with both feet and try the lacquer thinner.
Just for fun I stopped by the firehouse and busted out the thermal imager to see what they were running. The following temps are inside the heat shield, with the motor running.
D/S Front: 366
D/S Rear: 382
P/S Front: 390
P/S Rear: 393
The pipe running between the two cats was right at 500 degrees on each side.
#2312878 - 06/11/11 07:58 PM Re: Cat efficiency below threshold BOTH banks?? [Re: fireandice9008]
Loc: Southport, NC
I'm still not convinced...I think i'll try like a half gallon first and run it out in one run the same day. Anyone else tried the lacquer thinner trick?
#2312903 - 06/11/11 08:32 PM Re: Cat efficiency below threshold BOTH banks?? [Re: fireandice9008]
Blackcvpi Offline
Cynical Jackass
Loc: The 626
In the link to to the tread about this method.....at least one person has done it with there CV. The member who turned us on to this claims to have done it in 3 vehicles with great results.
Here's the link again...
28 registered (03baconCV, aadcvic, AaronIROCZ, BigMerc96, 6 invisible), 66 Guests and 66 Spiders online.
KayTar 555
CNGInterceptor 399
sm41 363
Moby_Vic 288
Ezbok58a 274
BlackVic_P71 272
BigMerc96 272
Superhobo 258
ajdereicup 235
Black_Sunshine 217
