Page 3 of 11 < 1 2 3 4 5 10 11 >
#2329602 - 07/10/11 10:38 AM Re: 26 inch rims questions [Re: Tonyman24]
216P71 Offline
Loc: Cle OH, Ypsi MI
^^i do, multiple sets actually, but at the time of that pic, my mechanic cranked it up for a second to take a quick peek at something.......
03 P71, Former Ohio Highway Patrol
#2329852 - 07/10/11 05:08 PM Re: 26 inch rims questions [Re: 216P71]
fordking Offline
Loc: Atlanta
X2... there is a forum with like 100 pages on kingofthestreetgarage.com. Search crown vic lifts in Google. This is the wrong site bruh. I feel ya on the 6s though. Got 4s on mines. To each is his own though. I'm thinking about copping another vic just for speed
06 PI Panther
#2331067 - 07/12/11 12:41 AM Re: 26 inch rims questions [Re: Tonyman24]
Lil_Nuke Offline
Loc: Memphis Tennessee
lol, wrong website to ask about BIG RIMS. Not to popular on this site. Here's a link for ya if you just wanna read other peoples ideas/suggestions on how they went about lifting etc...; http://www.kingofthestreet.com/forums/index.php?showtopic=58750
They do make "FULL LIFT KITS" for these cars too. If you're gonna do it, spend the money and do it right; You will have to lift "A LITTLE BIT" but it doesn't take that much for 26's. An INCH at the very most. If you go with a skinny tire like a 275/25/26 or a 255/30/26, you wont have to lift or cut barely at all; http://universalcarlifts.com/product_info.php?cPath=30_42&products_id=44 This particular kit comes with;
Lift Cups That installs under your factory Coil Springs (Get the 3" Cups. That's enough to clear & fit some 26's. They're big, but they're not THAT big. You can always cut the cups down to like 2", or 1.5 to get a nice clean stance, and not have that "OVER-LIFTED" look;
Front and Rear Heavy Duty Adjustable Control Arms for the front of the car to eliminate the negative camber (where the wheel tilts inwards towards the top) that is caused when lifting a car; Adjustable Arms will keep your tires from wearing excessively on the inside and will keep your alignment on straight.
Rear Adjustable Trailing Arms to keep the wheel centered in the wheel well and drive shaft angle correct;
Panhard Bar which keeps your Rear-End centered side to side;
New Ball Joints
Extended Heavy Duty Shocks
You also can search on eBay for one of their Front-End Rebuild Kits for Crown Vics/Grand Marquis/Town Cars;
http://motors.shop.ebay.com/Suspension-Steering-/33579/i.html?_dmpt=Motors_Car_Truck_Parts_Accessories&_fln=1&_mqf=0&_qfkw=1&_trksid=p4506.c0.m273&Make=Ford&Model=Crown%2520Victoria
^^^You can merge one of those particular kits with the Lift Kit and it comes with;
2 Upper Ball Joints
2 Lower Ball Joints
2 Sway Bar Links
2 Rear Sway Bar Links
2 Outer Tie Rod Ends
2 Inner Tie Rod Ends
1 PITMAN ARM
1 IDLER ARM
2 ADJUSTING SLEEVES
Some pics of 3" Lift Cups installed under Springs
Tha Car with those Cups;
He's on a 295/35/24 Tire though. He could sit it down a bit buy cutting the Cups down, and get an OVERALL BETTER STANCE, but come on people, it's not THAT bad...
#2331094 - 07/12/11 01:05 AM Re: 26 inch rims questions [Re: Tonyman24]
Lil_Nuke Offline
Now, as far as performance goes, the sky is the limit. just depends on how much money you have, You can get you a set of Ford Racing 3.73 or 4.10 Gears, and still have very nice acceleration;
K&N 57 Series Intake - 57-2544
Marauder 80mm MAF
Ford Racing 70mm Throttle Body
ADTR Ported & Polished Plenum
Steeda Underdrive Pulleys - 701-0001
Stainless Works L/T Headers - CRVICHDROR
Magnaflow Cat-Back (DON'T HAVE TO USE MUFFLERS OR TAILPIPES, IT'LL STILL FIT - 16788
Flowmaster Original 40's - 42443
BOC Blue Oval Chips Stage I or Stage II 10" TC
I mean the skys the limit buddy. I could go on & on...
#2331348 - 07/12/11 12:44 PM Re: 26 inch rims questions [Re: Tonyman24]
CVPI_GT Offline
How low is to low?
Loc: Richmond Va
That's not safe at all look at that lower ball joint and you want to drive around Richmond like that one good ride down broad street downtown and that's toast. You wont be able to so in shockoe bottom or the old part of hull or Midlothian were their doing all that road work.
Phillip, December 2012 POTM Winner http://tinyurl.com/px2ufby
1992 Ford Crown Victoria S,
Suspension Mods http://www.crownvic.net/ubbthreads/ubbthreads.php?ubb=showflat&Number=2603760#Post2603760
Wheels & Tires http://www.crownvic.net/ubbthreads/ubbth...mp;#Post2606379
#2331535 - 07/12/11 05:21 PM Re: 26 inch rims questions [Re: CVPI_GT]
larryo340 Offline
Loc: Long Island
Originally Posted By: BigNSlow
That does not look safe! The rear cup looks way too small for the spring. It should be wider to support the entire spring.
...and it those ghetto lifting cups up front must do wonders for the steering geometry and suspension travel nono
MOD List for MGM
...Marquis sold frown
#2332402 - 07/14/11 02:03 AM Re: 26 inch rims questions [Re: larryo340]
kingrhun Offline
Loc: Ft. Worth, Texas
Go on youtube and type in "crown vic on 26s"...read the comments on any video, LITERALLY ANY VIDEO in the search results and you will get a good and basic translation of what just about everyone is REALLY trying to say...not the site.
#2332412 - 07/14/11 03:07 AM Re: 26 inch rims questions [Re: Lil_Nuke]
ImpulseRocket89 Offline
Loc: Omaha, NE USA
Holy Massive Positive camber batman! That car would be a NIGHTMARE to take around a corner. Huge increase in unsprung mass. Huge increase in center of gravity. Huge decrease in outer tire contact patch.
I think I would rather run 10 miles on wet ice in my bare feet than drive that car in any kind of weather.
Edited by ImpulseRocket89 (07/14/11 03:08 AM)
#2332483 - 07/14/11 09:46 AM Re: 26 inch rims questions [Re: Tonyman24]
Black_Sunshine Offline
What's so scary about that? Obviously it goes over most obstacles.
75mm DBW TB
� hood ornament
� c-pillar emblems
� LS style body side moldings
CarDomain
Facebook
#2332486 - 07/14/11 10:01 AM Re: 26 inch rims questions [Re: Tonyman24]
sangeeth Offline
Loc: kingdom of Bahrain
I guess I just dont "Understand" the style nono
2001 P72: 5 Speed Swap; In Storage.
#2332610 - 07/14/11 01:41 PM Re: 26 inch rims questions [Re: Tonyman24]
martz0r Offline
Loc: Punta Gorda, FL
Might as well do a 4x4 swap and throw some mud tires on there if the car is going to sit that high.
'07 Durango HEMI Limited 4x4
#2332623 - 07/14/11 02:05 PM Re: 26 inch rims questions [Re: Tonyman24]
interceptor1985 Offline
Loc: OREGON
in those picture's the suspension is messed up ten ways from Sunday, I would not feel safe in that car, definitely did not modify that car properly. please read the BOK for proper modding techniques.
and
I really want to say how car's lifted like that make me feel, but this is a family forum believe it or not and there is children present.... ...Sorry but doing that to a car is just like my three yr old throwing a temper tantrum just for attention...Nothing of value is gained.
#2332690 - 07/14/11 04:09 PM Re: 26 inch rims questions [Re: Black_Sunshine]
Loc: Omaha, NE USA
You know, at first I was going wtf at that response. But, I then figured out the sarcasm behind it before I made a fool out of myself. At least I hope that is sarcasm laugh
#2333105 - 07/15/11 10:51 AM Re: 26 inch rims questions [Re: ImpulseRocket89]
guee Offline
Loc: Atlanta GA
rant I found out the hard way asking about big rims on this site is bad idea everyone hates em . if i could aford 30 inch spinners i would do it cause i like it .. to each his own.. i love the way that blacked out vic looks tbh its not modified for precision handling its modified for the flashy aspect wich is perfectly fine if you dont like it just keep it to yourself you dont have to try and look smart by bashing his taste in cars that just makes you look like a dick..
just felt like that needed to be said
2000 crown victoria LX 145xxx miles,PI intake manifold, 4 new speakers with new head unit and 15 inch sub-woofer.12000k HID kit , K&N filters, custom tint, drilled out air box, custom driving lights, and cherry bomb muffler, New upper and lower control arms.
#2333132 - 07/15/11 11:31 AM Re: 26 inch rims questions [Re: ImpulseRocket89]
Steveboos Offline
Loc: Charlotte, NC
Yeah not only is that car Hideous and an abomination to the Panther world, it doesn't looks safe to drive what-soever!! I wouldn't drive that thing if you paid me, I don't' feel like dying if i hit a pothole the wrong way.
But hey i value my car and my life more than others, so i guess you can count me out on the whole "rollin' on dubz" movement.
2007 Ford Crown Victoria SAP P71 Silver Birch/Dark Charcoal, 137,000 Miles, 1,600 Hours, NCSHP Vehicle #7367
40% Huper Optik Window Tint, DIY Headlight Relay Upgrade, Turn Signal Flash Mod, Trunk Light Mod with Cold Cathodes, Streamlight UltraStinger, Ultra Gauge, Pioneer Head unit, a GlobalSat BU-353, Cobra 29-LX, DVR-207 Dash Camera, and a RAM-VB-106-SW1 No-Drill Laptop Mount.
Proud member of the imaginary S.A.P. Group. You don't see us due to our street appearance.
Moderator:  a_d_a_m
11 registered (casey67, ChrisM_NY, DudeAbides, DaRedMoose, JaxRhapsody, larrys, 2 invisible), 86 Guests and 92 Spiders online.
Moby_Vic 182
a_d_a_m 153
BigMerc96 137
EZlivin11 106
Chaplian 104
White99MGM 98
charlieD 93
RF_Overlord 87
DudeAbides 81
SocalSam 76
