#2336283 - 07/20/11 12:59 PM Thinking out loud-5.4L 3V engine?
Robert_Allen Offline
Loc: Tuna, Texas
This is probably too pie in the sky to be practical, but what would it take to put a 3V engine in a Panther, assuming you locked out the cam phasers to disable the VVT system? The reason I ask is because I was reading a debat in another thread where the 5.4 makes more torque, due to its bigger displacement, but not necesarily more horsepower. Which sounds to me like the 2V head is the limiting factor. So a freer breathing head would make more horsepower, and the 5.4's added displacement can still keep intake velocity up at lower RPMs, which is where torque is made. I haven't heard od a DOHC 5.4 being installed in a CV, probably because its too wide, but would a 3V 5.4 fit? What kind of electronics would it take to get it to work in a Panther?
1978 Grand Marquis
1996 Ford Thunderbird
2001 Jaguar S-Type
#2336293 - 07/20/11 01:20 PM Re: Thinking out loud-5.4L 3V engine? [Re: Robert_Allen]
interceptor1985 Offline
Loc: OREGON
Read this over, has all the info needed, use your stock 4.6 mounts.
http://www.mylrs.com/blogs/lrs/archive/2009/01/12/Ford-Racing-4.6L-3-Valve-Fox-Body-Swap-Part-1.aspx
Then adjust for the extra size of the 5.4 (which might not fit under your hood when done)
Edited by interceptor1985 (07/20/11 01:21 PM)
#2336307 - 07/20/11 01:38 PM Re: Thinking out loud-5.4L 3V engine? [Re: Robert_Allen]
The main problem right now with the 5.4 options is that there are only one intake designed to fit under the hood og the crown vic and it's the hps intake.
All other intake will be truck intake that will be sticking out of the hood.
There are other ways to improove the hp rating than trying to fit 3v heads with an intake on a 5.4.
Cams and ported heads will net you excelents gains on a 5.4.
#2337446 - 07/21/11 09:55 PM Re: Thinking out loud-5.4L 3V engine? [Re: Robert_Allen]
Loc: Ventura County, CA.
the 5.4 just needs air. Ask 2004_p71, all he did was make the motor breathe and the it woke up.
#2337460 - 07/21/11 10:22 PM Re: Thinking out loud-5.4L 3V engine? [Re: Robert_Allen]
CameronVic Offline
Coolest guy on CVN
Loc: In the beams!
The difficulty with 5.4s making HP is because they have the same bore as a 4.6, but a longer stroke. 5.4s were made (in my opinion) to have 4V heads on them (or TFS heads, now go finish your build bondfreak!) or some sort of power adder. They are more torquey because of their long stroke.
1999 P71, Chevy 6.0, on3 7065 turbos, 4L80e, 3.73s, E85, etc. 9.86@142
2004 P71, DD, tons of chipped paint, bone stock sans JMOD
#2337663 - 07/22/11 06:30 AM Re: Thinking out loud-5.4L 3V engine? [Re: Bondfreak13]
hell yeah a simple 70 mm tb plus an accufab plenum got me .7 sec faster
#2337772 - 07/22/11 11:17 AM Re: Thinking out loud-5.4L 3V engine? [Re: Robert_Allen]
Binding_Posts Offline
Loc: Loo-UH-Ville Ken-Tuc-E
From what I understand, you would benefit much more from a 4 valve vs. a 3 valve. The heads / intake are the limiting factor, and if you decide to run boost you will probably not make as much HP.
I blame Binding_Posts for introducing us all to Kentucky Gentleman. - a_d_a_m
#2337958 - 07/22/11 03:35 PM Re: Thinking out loud-5.4L 3V engine? [Re: Binding_Posts]
Loc: Tuna, Texas
How much work will it take to fit a 4V 5.4 under a stock Panther hood. From what I've read, some of the changes to the Panther suspension in '03 were to fit the quad cam 4.6 in the Marauder. The 5.4 is even wider still. That is the main reason I was wondering about the feasability of the SOHC 3v. 90% of the 4V's airflow in a narrower package.
But yeah, if it fits, a quad cam 5.4 would be awesome. Time to hit the boneyards and start collecting parts laugh
1978 Grand Marquis
2001 Jaguar S-Type
#2337977 - 07/22/11 04:32 PM Re: Thinking out loud-5.4L 3V engine? [Re: Robert_Allen]
The 5.4 FAQ talks about the a 5.4 DOHC swap. But as of now it's guesstamates and math, until some one does it.
And Cameron, it takes money. Right now things are tight and I don't want to rush anything. It's taken me 8 years so far to get to where i am now. I don't want to mess it up.
#2338061 - 07/22/11 07:27 PM Re: Thinking out loud-5.4L 3V engine? [Re: Bondfreak13]
Gotts2BMe Offline
1995 Lincoln Town Car - 5.4 swap, no cats, true dual magnaflow, trac loc, 4 link, ported intake, SCT tuning
2000 F150 5.4 - Long Tube headers, Gotts intake, magnaflow exhaust, UDP's, efans, ported intake, 75mm TB, SCT tuning, 33" Firestone M/T's
#2341387 - 07/27/11 01:03 PM Re: Thinking out loud-5.4L 3V engine? [Re: Gotts2BMe]
prodigalson Offline
Loc: Cleveland, OH USA
The 5.4 3v is almost as wide as the 4v. And maxing out the cam phasers pretty much defeats the whole purpose of the 3v setup. Yes it will breathe more than a 2v but you're taking away all the adjustability of the performance, so whats the point?
And I've already outlined the major trouble points of the 4v swap, as I believe it to be, in numerous other threads. I'm just taking the Bondfreak approach - do it once, do it right.
Permanently banned.
#2341479 - 07/27/11 02:48 PM Re: Thinking out loud-5.4L 3V engine? [Re: prodigalson]
x2
Do it right the first time.
I'm more or less the guinea pig regarding mods on a 5.4 NA lol.
Wait till i'm done so you can learn from my good and bad experience lol
#2341508 - 07/27/11 03:34 PM Re: Thinking out loud-5.4L 3V engine? [Re: Robert_Allen]
GSDNH Offline
If you get a 3V computer, you can run the VVT and shut up these nay-sayers.
IIRC, the 3V 4.6 intake manifolds have the throttle body at the front of the motor.....
So you wouldn't have to use the HPS intake. Who knows what other intake options are out there?
#2341537 - 07/27/11 04:09 PM Re: Thinking out loud-5.4L 3V engine? [Re: Robert_Allen]
anything can be done in this world.
the way i see it is that there are too many cons to justify the 5,4 3 v swap yet.
lack of option for the intake is just a big turn off if you want to upgrade performance wise down the road
#2341937 - 07/28/11 03:22 AM Re: Thinking out loud-5.4L 3V engine? [Re: Robert_Allen]
GSDNH Offline
But I just mentioned that 3V uses a different intake, of which several high-performance models exist.
Switching to 3V will give you MORE intake options besides the one HPS for the 2V.
Moderator:  BigMerc96, KayTar, Liquid
6 registered (GrandMarq9807, RF_Overlord, CrownBen, hlbly, ford05, 1 invisible), 178 Guests and 11 Spiders online.
a_d_a_m 188
Ezbok58a 170
charlieD 146
BigMerc96 138
Ponyguy 112
dpk 111
White99MGM 100
SocalSam 85
Moby_Vic 85
Chaplian 72
