#2370168 - 09/12/11 05:50 PM Water Pump Replacement. Help?
SKimber Offline
Loc: Hawthorne, CA
I need to replace my water pump and unfortunately I have no experience with cars. I've been told replacing the water pump is not that hard on the 2005 CV.
May anyone with experience help me out? :] I'd love to learn and save some $ instead of paying the garage $175 for an aftermarket water pump (parts + labor)
Edited by SKimber (09/12/11 05:50 PM)
You're not free until you are freed
#2370188 - 09/12/11 06:35 PM Re: Water Pump Replacement. Help? [Re: SKimber]
REAL4WD Offline
Loc: Glendale, CA
never changed a water pump.
i have changed my intake manifold on my vic. done almost all servicing on it too.
I just finished removing my old fuel filter setup on my truck and replaced it with an aftermarket setup.
I helped my buddy with an 01 Ranger 4x4 drop his automatic transmission and put in a manual transmission.
I would be willing to help change a water pump
04 Crown Victoria LX Sport
95 AM General Hummer
#2370191 - 09/12/11 06:43 PM Re: Water Pump Replacement. Help? [Re: SKimber]
GSDNH Offline
Once you drain the coolant & remove the pulley, it's only 4 bolts to remove it. Sometimes the pump can be a bit stubborn to come out of the block, but being in California I'm sure yours won't be as bad as they get over here.
Make sure your new pump comes with a new O-ring, if it doesn't, get one. I apply vaseline to the new O-ring after installing the O-ring on the pump. This will help make sure you don't roll the O-ring over upon installation. Just tighten the bolts slowly and evenly until the water pump is seated. IIRC the torque spec is 20 lb/ft, might want to double-check that.
Then re-install the pulley and re-fill with coolant.
At least that's how I did mine. If anyone has anything to add, please feel free.
#2370458 - 09/13/11 03:18 AM Re: Water Pump Replacement. Help? [Re: SKimber]
SKimber Offline
Loc: Hawthorne, CA
^thanks GSDNH for the instructions!
Thanks MJ for the offer!
If there are any more to add/change to GSDNH's post please do! I would love to do this correctly.
Any suggestions on water pumps?
#2370461 - 09/13/11 03:24 AM Re: Water Pump Replacement. Help? [Re: SKimber]
REAL4WD Offline
Loc: Glendale, CA
i have read that EMP Stewart or the Cobra waterpumps are the way to go. some claim 12 degrees cooler temp
i have also read that a new belt and tensioner is a good idea at this time.
i keep my old tensioner in the trunk if it still is ok because then if it breaks on me i can fix it on the road and keep on truckin banana
Edited by FireFightin_MJ (09/13/11 03:26 AM)
#2370462 - 09/13/11 03:24 AM Re: Water Pump Replacement. Help? [Re: SKimber]
GSDNH Offline
Are you looking for a high-performance water pump, or just a good replacement water pump?
#2370465 - 09/13/11 03:28 AM Re: Water Pump Replacement. Help? [Re: SKimber]
SKimber Offline
Loc: Hawthorne, CA
I know that the '04 Cobra is the exact same as the 03+ CV water pump.
EMP Stewart idk..
@GSDNH
options are nice :] Throw me everything and anything laugh
#2370468 - 09/13/11 03:33 AM Re: Water Pump Replacement. Help? [Re: SKimber]
GSDNH Offline
My motor is older than yours, but I know there were short, and long water pumps. Might want to make sure you get the proper application.
Gotta swap the corresponding pulley BTW there are two different pulleys as well.
#2370471 - 09/13/11 03:45 AM Re: Water Pump Replacement. Help? [Re: SKimber]
SKimber Offline
Loc: Hawthorne, CA
The 2005 uses a 65mm short. :]
#2370474 - 09/13/11 03:47 AM Re: Water Pump Replacement. Help? [Re: SKimber]
GSDNH Offline
Sweet.
Is it done yet?
Haha J/K wink
#2370476 - 09/13/11 03:49 AM Re: Water Pump Replacement. Help? [Re: SKimber]
http://idmsvcs.com/2vmod/waterpump/index.html
There's a great writeup here that should explain absolutely everything, including what parts to use.
Originally Posted By: etcv97
#2370661 - 09/13/11 02:20 PM Re: Water Pump Replacement. Help? [Re: SKimber]
SKimber Offline
Loc: Hawthorne, CA
^ thanks for the link!
Is there any suggestions on brand?
#2370663 - 09/13/11 02:21 PM Re: Water Pump Replacement. Help? [Re: SKimber]
GSDNH Offline
People here seem to like the Stewart/EMP pump.
I run an Evans, but IMHO that is overkill for your engine.
#2370667 - 09/13/11 02:28 PM Re: Water Pump Replacement. Help? [Re: SKimber]
SKimber Offline
Loc: Hawthorne, CA
What is overkill may I ask?
#2370670 - 09/13/11 02:34 PM Re: Water Pump Replacement. Help? [Re: SKimber]
Blackcvpi Offline
Cynical Jackass
Loc: Somewhere in the CRC
I went with a remanufactured shrouded impeller water pump from A1 cardon. I have used parts from them before with no issues.
O'reilly auto parts stocks them.
The high performance ones will be over kill because you have a stock engine. Its not really needed unless you plan to do heavy mods in the future. I figure if the stock style was good enough for police duty.......its good enough for me.
2003 Crown Victoria ( AKA Car Craft Crown Vic ) ff, Trick Flow 38CC top end kit, Circle D multi disk 3500-3700 stall converter, Full SW exhaust, MM Airbox and MAF, ADTR zip tube, 78mm BBK Plenum and TB, Transgo Stage 2 shift kit, 3.73 with track lok, Naake coilover suspension, Henious control arms, Metco watts link, ARP watts link stud, Addco sway bars, Powerslot rotors with Hawk HPS pads, BH1976 headlight relay harness, Procar sportsman pro race seat's, 17" steel rims widened to 9.0 with Nitto 555's in 285/40/17 tire for the rear, Tuned by Racers Edge Tuning in Downey CA,....more mods coming soon.
1997 Mercury Grand Marquis HPP.....Stock
2010 Chevrolet Silverado LT 4x4 , K&N cold air intake, Flowmaster dual exhaust, G2 diff cover, Range AFM delete
Moderator:  a_d_a_m
NM117 334
Moby_Vic 146
BigMerc96 120
EZlivin11 120
Chaplian 118
RF_Overlord 115
Ezbok58a 112
a_d_a_m 100
mdnos 96
Ponyguy 93
