#2407789 - 11/15/11 06:39 PM 2nd Heater Core FAILURE!!!!!!!!!!!!!
Fordiesel69 Offline
Loc: Erie, PA
I am the one that made the heat core guide, so it was posted here at 10/08'
I can't remember the miles but it probably did not exceed 30k.
It let loose, and is leaking coolant out the evap drain and into the interior. I replaced the hoses to make sure.
What would cause this repeat type of failure? I used new green coolant, and also a genuine new ford core. I also was OCD about the whole job so nothing is rubbing or causing a puncture.
Could my 400 watt power inverter be feeding some kind of electrolysis into the cooling system? Any ideas? nono
-'99 Crown Vic Police Interceptor (SAP), 3.55 Trac-Loc(DK), Cloth Interior, Black Honeycomb Grill, Black PI Trunk Bezel, Silverstars, 174K
-'08 Crown Vic Police Interceptor (SAP), 3.27, Cloth Interior, Smokestone Metallic, 130K / 3427 Hrs
-'07 F-150 4x4 - Extended Cab, 3.55's, White w/ Grey interior, 124K
#2407797 - 11/15/11 07:01 PM Re: 2nd Heater Core FAILURE!!!!!!!!!!!!! [Re: Fordiesel69]
Ponyguy Offline
Loc: Oswego, IL
Is it possible that you might have accidentally scratched or otherwise nicked the core when you replaced it?
I feel sorry for you, having to do that job over again... I replaced the heater core on my '84 Mustang, and it was a lot of damn work; but since it's a convertible, at least I could stand up so I had more room to work.
Good luck!
Sig removed. Read the rules.
My transportation sources:
1972 Green Schwinn Speedster, 1984 Red Mustang V-6, 2004 Gold Ash GMQ LS Ultimate Edition, 2004 Black Ranger XLT Flareside.
#2407820 - 11/15/11 07:24 PM Re: 2nd Heater Core FAILURE!!!!!!!!!!!!! [Re: Ponyguy]
Fordiesel69 Offline
Loc: Erie, PA
That is what I made sure not to do.
I even put fresh new foam in place of the flattened rotted old foam so it could not rub the plastic box.
#2408008 - 11/16/11 12:12 AM Re: 2nd Heater Core FAILURE!!!!!!!!!!!!! [Re: Fordiesel69]
Gaither Offline
Loc: Chattanooga, TN
Now, that is BAD luck!! Was it OEM or another brand?
Gaither
'04 GM GS
'02 CV LX HPP
#2408015 - 11/16/11 12:43 AM Re: 2nd Heater Core FAILURE!!!!!!!!!!!!! [Re: Fordiesel69]
JSanders Offline
Loc: California
A careful inspection should yield the answer to the reason for fail.....post back when you can make a determination.
#2409478 - 11/18/11 07:20 PM Re: 2nd Heater Core FAILURE!!!!!!!!!!!!! [Re: JSanders]
Fordiesel69 Offline
Loc: Erie, PA
Car will be going into hibernation soon so I may not get to it right away.
#2411777 - 11/22/11 09:43 PM Re: 2nd Heater Core FAILURE!!!!!!!!!!!!! [Re: Fordiesel69]
enslow Offline
Loc: Vancouver
With the car running, place the positive end of a voltmeter probe into the coolant and the negative end on the negative battery terminal. If you've got more than 0.3V you have your problem. If the voltage is in excess of 0.3V, you have electrolysis eating away at the aluminum of your heater core.
Testing the MAF
Digital Cluster Repair
Stalag's Coolant Write-up
'92 Grand Marquis, M75
#2411835 - 11/22/11 11:06 PM Re: 2nd Heater Core FAILURE!!!!!!!!!!!!! [Re: enslow]
JSanders Offline
Loc: California
Help me understand where the voltage difference would be coming from?
The conductive coolant would be well grounded already, as it is touching the engine block and that is well grounded..potentially, the coolant would be the pre-existing ground path on the heater core as well...
#2412292 - 11/23/11 06:35 PM Re: 2nd Heater Core FAILURE!!!!!!!!!!!!! [Re: Fordiesel69]
99_03PantherS Offline
Loc: NW side Chicago
electrolysis is what killed my heater cores in my 1994...good luck man
Jason G.
'81 Mark VI 2 door
'88 Towncar Cartier
#2412462 - 11/23/11 10:17 PM Re: 2nd Heater Core FAILURE!!!!!!!!!!!!! [Re: Fordiesel69]
PB92 Offline
Loc: Communist CT
How do you prevent this?
US MARINES Kilo 3/3
Modified factory CAI. Big 4 upgrade, 0 gauge highstrand. High Power Cobra 29 Old school highly tricked out, w/300 watt box. 200 amp alt w/overdrive pulley. New body mounts. Moroso air/oil separator. Rebuilt 8.8 axle. ARA3 PCM. High power CB'er for 35 years.
#2412755 - 11/24/11 04:19 PM Re: 2nd Heater Core FAILURE!!!!!!!!!!!!! [Re: PB92]
stevena Offline
Loc: Sonoma/Coco counties
Run a ground lead from the heater core to a chassis point.
2000 BMW 740iL 127k
2002 CVPI (RIP)
2001 CVPI (RIP)
Want back-up sensors on your Vic??
Click Here!
#2416868 - 12/01/11 09:32 PM Re: 2nd Heater Core FAILURE!!!!!!!!!!!!! [Re: 99_03PantherS]
Fordiesel69 Offline
Loc: Erie, PA
So how did you fix your 94? What was causing your electrolysis?
#2417158 - 12/02/11 09:25 AM Re: 2nd Heater Core FAILURE!!!!!!!!!!!!! [Re: Fordiesel69]
stalag Offline
Loc: Columbus, OH
Fordiesel69,
What coolant did you use. Did you know of the coolant info I outline in the thread referenced in my sig? That could be part of your problem right there. Peak/Prestone are not good coolants and I would never use them.
#2417756 - 12/03/11 03:59 PM Re: 2nd Heater Core FAILURE!!!!!!!!!!!!! [Re: stalag]
Fordiesel69 Offline
Loc: Erie, PA
It was Texaco regular green, changed out when I did the first core. I am thinking I may want to go with G-05 after this to help out on the corrosion.
#2417845 - 12/03/11 06:35 PM Re: 2nd Heater Core FAILURE!!!!!!!!!!!!! [Re: Fordiesel69]
Fordiesel69 Offline
Loc: Erie, PA
Took some readings today on various vehicles: + lead in coolant bottle, black on - battery terminal. Meter set to auto range DC volts.
96' Town Car (151k Unknown Green Coolant - Looks good)
Cold
-0.187 Off
-0.283 Running
Warm
-0.250 Off
-0.252 Running
91' Town Car (81k Miles - New coolant)
Warm Only
-0.092 Off
-0.111 Running
91' Town Car (116k Miles - Coolant changed at 94k Green)
Cold
-0.159 Off
-0.204 Running
02' Dodge Caravan 3.3L V6 (21k Miles - Factory Green from 02)
Cold
+0.373 Off
+0.351 Running
Not sure why the 4.6L engine all read - voltages when the 3.3L engine read + voltages. Anyways are any of these bad??????
Edited by Fordiesel69 (12/03/11 06:36 PM)
11 registered (casey67, ChrisM_NY, DudeAbides, DaRedMoose, JaxRhapsody, larrys, 2 invisible), 86 Guests and 92 Spiders online.
Moby_Vic 182
a_d_a_m 153
BigMerc96 137
EZlivin11 106
Chaplian 104
White99MGM 98
charlieD 93
RF_Overlord 87
DudeAbides 81
SocalSam 76
