#2431998 - 01/03/12 02:18 AM Rear main seal leak?
6Paul11 Offline
Loc: Northern CA
What's involved when replacing the rear main seal on these cars?
2003 CVPI
BBK 70mm Tbody, ADTR ported plenum, Flowmaster dual exhaust, steeda UD pulley's, Heinous Rear Control Arms, Viper 160XVL SST Remote starter.
Enkei LS-5 18x8 wheels Black
I mostly come out at night...mostly.
#2432010 - 01/03/12 03:11 AM Re: Rear main seal leak? [Re: 6Paul11]
brianalex Offline
Loc: So Cal.
I haven't done it on one of these but the 2003 Ford Service CD says to remove the transmission and flexplate then the oil slinger and the seal.
SECTION 303-01A: Engine 4.6L (2V) 2003 Crown Victoria/Grand Marquis/Marauder Workshop Manual
IN-VEHICLE REPAIR
Crankshaft Rear Seal with Retainer Plate
Special Tool(s) Installer, Crankshaft Rear Seal
303-518 (T95P-6701-DH)
Remover, Crankshaft Rear Seal
303-519 (T95P-6701-EH)
303-516 (T95P-6701-BH)
Remover, Crankshaft Rear Oil Slinger
303-514 (T95P-6701-AH)
Installer, Crankshaft Rear Oil Slinger
303-517 (T95P-6701-CH)
Slide Hammer
100-001 (T50T-100-A)
Material Item Specification
Metal Surface Cleaner
F4AZ-19A536-RA or equivalent WSE-M5B392-A
Silicone Gasket and Sealant
F7AZ-19554-EA or equivalent WSE-M4G323-A4
SAE 5W-20 Premium Synthetic Blend Motor Oil
XO-5W20-QSP or equivalent WSS-M2C153-H
Removal
Remove the flexplate. For additional information, refer to Flexplate in this section.
Use the special tools to remove the rear oil seal slinger.
Use the special tools to remove the rear main seal.
If the oil dye leak test reveals a leak behind the retainer, remove the eight bolts and the crankcase rear oil seal retainer.
Installation
CAUTION: Do not use metal scrapers, wire brushes, power abrasive discs or other abrasive means to clean the sealing surfaces. These tools cause scratches and gouges which make leak paths. Use a plastic scraping tool to remove all traces of old sealant.
NOTE: Clean sealing surfaces with metal surface cleaner. Allow to dry until there is no sign of wetness, or four minutes, whichever is longer, failure to follow this procedure can cause future oil leakage.
Clean and inspect the mating surface.
NOTE: If the rear crankshaft seal retaining plate is not secured within four minutes, the sealant must be removed and the sealing area cleaned with metal surface cleaner. Allow to dry until there is no sign of wetness, or four minutes, whichever is longer. Failure to follow this procedure can cause future oil leakage.
NOTE: The sealant must be applied on the groove along the retainer plate.
Apply sealant around the rear oil seal retainer sealing surface.
Install the rear oil seal retainer and loosely install the eight bolts.
Tighten the rear oil seal retainer bolts in the sequence shown and install the two oil pan bolts.
NOTE: Lubricate the inner lip of the rear crankshaft seal with engine oil.
Use the special tools to install the rear main seal.
Use the special tools to install the rear main seal slinger.
Install the flexplate. For additional information, refer to Flexplate in this section.
2001 MGM LS 25K geezer miles.(Now 50K Geezer miles)ABS,Digi-dash,auto climate,dual power leather,auto-dim/compass mirror,"Drifting Barge" Pkg. etc. Almost Mint
#2432079 - 01/03/12 10:53 AM Re: Rear main seal leak? [Re: 6Paul11]
RWDForever Offline
Loc: Olympics here were a bust
I did mine when my transmission died. My mom-in-laws '97 TC with 110K has a damp oilpan so I know her rear seal is going bad.
I got the whole Rotunda rear main install seal kit off Ebay and it works perfect. But I have read you can buy rear seals that come with a plastic ring to press the seal in. My seal was just a seal in a box with no ring.
There is a steel carrier that bolts to the rear of the block that the seal presses into. Problem is the installed seal isn't flush with the carrier, it is pressed in just below the flat surface of the carrier.
Ford Manual says there is an oil slinger but I didn't have one so I only put the one main seal back on.
1995 GM/LS -- 317K miles, engine rebuild. MODS:1998 transmission, 1996 PCM, plastic intake, 1996 engine/trans wiring harness spliced in. Dash switch for A/C compressor, 2000 steering box, leather seats recovered with NOS cloth, new OEM carpet, Dash switch operates hot water valve.
1992 Taurus LX -- 91k miles, added transmission cooler. Rear heavy duty springs.
#2432212 - 01/03/12 05:02 PM Re: Rear main seal leak? [Re: 6Paul11]
6Paul11 Offline
Loc: Northern CA
Wow, I didn't realize I'd need all those tools. I think I'll leave it to my mechanic. I'll have to wait till my tax rtrn or save. I had this done around when I bought my car. 100k est. miles later fail? It's dripping pretty good on our driveway. Sigh.
2003 CVPI
#2432268 - 01/03/12 07:25 PM Re: Rear main seal leak? [Re: 6Paul11]
Try one of the High Mileage oils, stopped the rear seal leak in my '93...
1998 Grand Marquis LS. 76K mi.
2007 Grand Marquis GS. 77K mi.
4 registered (2007CrownVic, doozii13, Moby_Vic, 1 invisible), 107 Guests and 92 Spiders online.
a_d_a_m 229
BigMerc96 144
Ezbok58a 104
dpk 100
EZlivin11 97
RF_Overlord 96
Chaplian 92
Ponyguy 88
JeffBoudah 87
SocalSam 80
