#2445570 - 01/26/12 06:36 PM Timing Chain Replacement cost
MattBlake Offline
Loc: Northridge, Ca
I just took my car to the shop due to the timing chain making noise, they haven't fully diagnosed it, if its just the tensioner or the whole chain and gears. but are working on it. they quoted me about 1400 for the job. Is this reasonable? is it uncommon for it to get worn out at 172,000?
^^RIP^^ The 2003 p71 that isnt clean for more than 4 hours
**Made it to 480,000 miles transmission died- 2005 ex-taxi P71***
Current- 2007 Ex-LAPD Crown Vic
#2445620 - 01/26/12 08:07 PM Re: Timing Chain Replacement cost [Re: MattBlake]
NCHeel Offline
Loc: Charlotte NC
'03 are notorious for the guides and tensioners wearing out. Chain and sprockets should be good and $1400 is way too much.
#2445628 - 01/26/12 08:17 PM Re: Timing Chain Replacement cost [Re: NCHeel]
cdr-m@x Offline
Loc: North East PA
Note to self......avoid '03's, will be getting another at the auction this year. Alot of '08's at the auction.
2008 CVPI
271,000 miles. J-mod, Mo's 93 octane tune. Steeda Under drive Pulleys. Trick Flow Ported and polished Plenum. BBK 75mm TB. Metco control arms. Some kind of Flowmasters.
1998 CVPI
215,000 miles Refurbished at 87,400 miles, sleeping for now.
#2445636 - 01/26/12 08:31 PM Re: Timing Chain Replacement cost [Re: MattBlake]
124neta Offline
don't get riled, sugar!
Loc: Il
^^^ 03's arent the only years that are known for this issue.
170k+ is not uncommon. here is my guides/tensioners at 125k:
1400$ seems steep. May be worth looking into to do on your own. Not as bad as some may lead you to believe. Ive never done anything like it before and it took me 3 hours.
Parts ran me about 250 parts and gaskets motorcraft. I would say a good price would be around the 750-800 range. anything over 1000 seems crazy to me.
#2445640 - 01/26/12 08:41 PM Re: Timing Chain Replacement cost [Re: MattBlake]
Starliner Offline
Loc: NorthEast
I replaced mine at 170k and they were only about 2/3's worn out. Took me a lot longer than three hours, but I was out of practice.
The noise I was chasing turned out to be the bearing on the air conditioning clutch rolleyes The 03's have a bad reputation for this issue.
cool BLACK 2003 LX: A 2.73 rear single exhaust car until I can find the other side. Dark Charcoal leather. 29mm front bar and the 21mm rear bar. Rear axles have been replaced twice.
cool2 WHITE 1998 LX: Bought it @38k, retired at 203k. 2.73 rear, junkyard duals, bilsteins, 29.5mm front bar, 21mm rear bar, chain guides @170k,
#2445653 - 01/26/12 09:04 PM Re: Timing Chain Replacement cost [Re: MattBlake]
kdr358 Offline
Loc: CA
I paid 225 at the dealer for timing chain tensioners, tensioning arms and the stationary guides and timing cover gaskets.. I used the BOK and it took me about 4 hours total the stealership quoted me 1,200.00. the chains and cam gears are ok and almost never go bad.. if the shop is telling you the chains are bad find a new shop, The chains last as long as the motor and are rarely and issue.
#2445660 - 01/26/12 09:31 PM Re: Timing Chain Replacement cost [Re: MattBlake]
Chicago2VP71 Offline
Two Valvin It
Loc: Northwest Suburbs, IL
Does anyone know what the last build date was for this supposed issue? I think someone posted this info in another thread but I can't seem to find it.
2008 Smokestone Metallic P71 - 54,xxx - Magnaflows - 20% Tints - K&N Filter - 3.55 TrakLok
1991 White Lincoln TC - 253,000 - RIP
2004 Dark Pearl Blue SAP P71 - 75,100 - RIP
2004 Dark Blue P71 - 104,000 - RIP
#2445662 - 01/26/12 09:34 PM Re: Timing Chain Replacement cost [Re: MattBlake]
RollinX151 Offline
vvvvvvvvvvvv
Edited by RollinX151 (01/26/12 09:36 PM)
2003 Ford Crown Victoria LX Sport - SOLD
2020 Jeep Grand Cherokee Limited X - Family Car
2021 Tesla Model 3 Performance - Daily
2011 Ford Crown Victoria P71 - SOLD
#2445666 - 01/26/12 09:36 PM Re: Timing Chain Replacement cost [Re: MattBlake]
RollinX151 Offline
Do you still get the timing belt issue even if it was already done and the valve covers have the X with three dots? (X...)
Does your have these marking on both valve covers?
#2445971 - 01/27/12 01:00 PM Re: Timing Chain Replacement cost [Re: MattBlake]
martz0r Offline
Loc: Punta Gorda, FL
Do not ignore it, you will be getting a new engine. Their quote is very expensive. The parts can be had for less than 1/4 of that cost and it will take you a day, or a weekend if you go really slow.
'07 Durango HEMI Limited 4x4
#2445972 - 01/27/12 01:11 PM Re: Timing Chain Replacement cost [Re: MattBlake]
No_Name Offline
Loc: New Jersey-South Jersey
Martz,
Is that a rod knock or the bad timing chain guide noise?
Panther Less and It Suck's!
#2445978 - 01/27/12 01:23 PM Re: Timing Chain Replacement cost [Re: kdr358]
Michigansquadcar Offline
Loc: Southeast michigan
If the guides start to wear like some of the pictures above I could very easily see a shop recommend or even insisting on replacing the chains. They are the ones who have to stand behind the work once the car goes out the door. How pissed would you be if you paid a shop $800 on new guides/tensioners and the car blew a chain a month afterwards and blew the engine? Not to happy I would guess.
#2446064 - 01/27/12 03:33 PM Re: Timing Chain Replacement cost [Re: MattBlake]
If the chains start grinding away on the Steel tensioner pistons they should be replaced and one normally replaces the timing gears along with the chains.
Frankly if it gets that bad most engines end up failing due to a plugged up oil pump pickup screen and/or particles blocking up oil passages causing spun bearings and damaged cam bearings etc..
2004 Crown Vic LX SOLD!!
#2446341 - 01/27/12 10:05 PM Re: Timing Chain Replacement cost [Re: MattBlake]
Dreamer Offline
Loc: austin,tx
My car just rolled 160k, is this something that I should be looking to replace soon or do I just wait until I HAVE to change them out. Why are the guides/tensioners wearing out like this in the first place.
03 P71 stock
02 Mustang GT far from stock
#2446377 - 01/27/12 10:56 PM Re: Timing Chain Replacement cost [Re: MattBlake]
dubch87 Offline
Loc: NC
Civilian tensioner arms at 110k miles:
Fixed a known issue for peace of mind.
I'm by no means a mechanic and survived doing the work myself. New arms, guides and tensioners. Weren't worn enough to warrant replacing chains and gears.
2000 Crown Victoria LX, .194 million miles
Mods go here.
