#2595644 - 09/12/12 07:47 PM Anti-Theft Light Blinking?
Stinkin Offline
Loc: NJ, USA
ok, since i got my LTC, the Anti-Theft light blinks and dings very angrily when I turn the car off and my Driver door is open. does not ding but blinks when other doors are open.
I don't have the newer PATS key, and when I push the Panic button on my remotes it honks and flashes as it should, so nobody messed with the Anti-theft system, I think?
my car is a 1997 Lincoln Town Car, Executive series.
now is this normal? if it is please pardon my ignorance.
2000 Honda Accord: Living on a Prayer, 120K miles, no timing belt change no trans flush, TICK-TOCK....
1997 Lincoln Town Car: found in the junkyard, rescued, patched up runs good.
when your wife lets you buy a car from the junkyard, you know she loves you!
#2595689 - 09/12/12 08:56 PM Re: Anti-Theft Light Blinking? [Re: Stinkin]
it is normal. It should blink for 15 or so seconds after you lock the doors. It will also blink when you open the doors. After you lock the doors, and it finishes its blinking, then the alarm is armed. If you leave the window open, lock the doors, wait for it to finish blinking, then open the door from the interior handle, it should set off the alarm.
1997 Town Car Cartier ~91k miles, 70mm TB, Ported Plenum, Gutted Airbox, Mechanical Fan Delete, Contour E-fan Retrofit, Dual exhaust with Magnaflows, MSD Ignition, KYB Gas-A-Justs, Marauder/HPP rear sway bar, Blinker Mod, Caddy 4-note horn retrofit.. Smashed 1/13/13....Repairs to come..
#2595701 - 09/12/12 09:05 PM Re: Anti-Theft Light Blinking? [Re: Stinkin]
Stinkin Offline
Loc: NJ, USA
Thanks Big Merc, BTW your Lincoln is absolutley gorgous...
#2595742 - 09/12/12 10:37 PM Re: Anti-Theft Light Blinking? [Re: Stinkin]
olopezm Offline
Loc: Irapuato, Mexico
It dings even without a key in the cylinder?
That's not normal and may indicate a broken tab inside the cylinder which can be easily removed; or in other cases, like mine, if you have some other electrical gremlins it might indicate a problem with the connections to the LCM. As a quick story, my Town Car would ding almost every time I opened the driver door even without a key in the cylinder, the windows would remain permanently energized, the automatic headlights would work erratically and the clock on top of the dash never worked. It all turned out to be a bad clock shorting the LCM and causing all those problems.
If it's dinging only when the key is in the cylinder, then ignore my comment and be happy!
Oscar.
1997 Pontiac Grand Prix GT
2000 Ford Windstar SE
#2595783 - 09/13/12 12:46 AM Re: Anti-Theft Light Blinking? [Re: Stinkin]
Stinkin Offline
Loc: NJ, USA
Yes it dings without key in cylinder but windows stop working after I open the door and my auto lights work perfect they even turn off when I leave them on the on position, my clock works perfect.
The key fits snugly in cylinder as well. any ideas?
#2595795 - 09/13/12 02:13 AM Re: Anti-Theft Light Blinking? [Re: Stinkin]
Raven238 Offline
Loc: Boston, MA
Sounds like the key sense. If you were to take the cover off and take the ignition out. You'll see a tiny black piece on the bottom where the ignition goes into. Should have a small wire coming from it. If the tap is bent downward, it'll keep a closed loop. If its not seated properly, same thing. Easy fix either way if that's the problem.
03 CVPI 183XXX miles young! Former Connecticut State detective cruiser.
K&N cold air, LED Interior, Marauder Cluster Swap, Pioneer 2DIN w/ Sony Xplodes! Sniper Tuned! Side Blinker Mod, Headlamp Upgrade pictorial , Cop Tires! Cop Brakes! Knock Sensors & Catalytic Converters so it runs good on regular gas!
#2595797 - 09/13/12 02:18 AM Re: Anti-Theft Light Blinking? [Re: Stinkin]
Raven238 Offline
Loc: Boston, MA
#2596257 - 09/14/12 12:19 AM Re: Anti-Theft Light Blinking? [Re: Stinkin]
Stinkin Offline
Loc: NJ, USA
Thanks for all of your help. as long as it doesn't hurt my LCM then it can ding till the cows come home.
Moderator:  2vmodular, dRock96Marquis, sanco
31 registered (04RauderDTR, beamer, 73vwTodd, 03baconCV, 7 invisible), 85 Guests and 72 Spiders online.
KayTar 599
CNGInterceptor 385
sm41 358
BlackVic_P71 280
BigMerc96 272
Ezbok58a 272
Black_Sunshine 260
Moby_Vic 239
ajdereicup 231
Superhobo 230
