#2606924 - 10/05/12 09:45 PM Headliner Removal in 99- 01 vic
ThunderTank Offline
Loc: Michigan
How hard is it to remove the headliner in a Crown Vic . I found a good replacement at the junkyard and i want to replace my bitten up one in my current car . The junker is a 99 crown vic and mines is a 01 . I wanted to know how hard it will be to take it out with as little damage as possible . All help would be appreacited
#2606930 - 10/05/12 09:58 PM Re: Headliner Removal in 99- 01 vic [Re: ThunderTank]
Bangster Online   content
I thought they were different CVPI and civilian car. I dropped mine to install a dropdown LCD, and there is no way without removing the windshield or back window I could see to get it out in one piece. I left in the seats and just dropped it to run the wiring and burn in mounting holes and add brackets on top without crushing it.
Maybe the only difference CVPI to civilian (other than the hole for the ticketing writing light) is that civilian it is glued in, and CVPI it is secured in a different manner (so can more easily wire/mount roof lights).
1974 Honda cb400
#2606932 - 10/05/12 10:02 PM Re: Headliner Removal in 99- 01 vic [Re: ThunderTank]
Not too bad. Its held up by all of the trim (a,b,c pillar trim, visors, dome light, etc...), and then I believe its also glued to the roof in these cars. So carefully pull it down. The headliner board is pretty tough, but still be careful with it. In most cars, and I'm sure these ones as well, the only opening big enough to get them thru is the passenger front door, either with the seat slid back/reclined all the way, or removed altogether. At the factory they are usually installed via the windshield opening before the glass is installed, but unless you want to remove your windshield, thats not an option.
Originally Posted By s33k3r
#2607098 - 10/06/12 08:45 AM Re: Headliner Removal in 99- 01 vic [Re: ThunderTank]
troubled Offline
Loc: AL
Most importantly are you talking about a P71 or a 73/74. P71 headliner is not glued in like the 73/74 are. I have never been successful removing a 73/74 liner without causing damage.
Absolutley disregard the person who suggested you have to remove the the windshield or back window.
You hame to remove and re-install the headliner from the back passenger side. It is not easy but is not really that difficult either. The biggest assist in getting it ut is to remove the front seats and the rear seat bottom cushion. Additionally tilt the steering wheel as low as it will go.
#2607099 - 10/06/12 08:55 AM Re: Headliner Removal in 99- 01 vic [Re: ThunderTank]
troubled Offline
Loc: AL
#2607135 - 10/06/12 10:59 AM Re: Headliner Removal in 99- 01 vic [Re: troubled]
stags Offline
Loc: md
I just replaced the fabric on the headliner in my 97 cvpi,recline the two front seats and the headliner will come out through the passenger door pretty easily.
2004 P71 146K
1997 P71 85K
#2607177 - 10/06/12 02:22 PM Re: Headliner Removal in 99- 01 vic [Re: ThunderTank]
Drac Offline
Cpt. Smug
Loc: Cali
One thing to also keep in mind is the taper of the headliner at the top of the B-pillars changed between 1999 and 2001. You will need to get the upper B-pillar trim out of the 2001 also and install it with the headliner, otherwise you wont be albe to physically install your 1999's upper b-pillar trim with the 2001 headliner, unless you trim that section of the headliner physically.
2004 Crown Victoria finished in Dark Pearl Blue Metallic (DX) Ported M122 powered DOHC conversion w/ supporting mods. Dyno queen -637 RWHP/640 RWTQ-
2006 Lincoln LS V8 Sport finished in Ebony with black interior. MPT tuned, K&N CAI, Lowered on Eibachs with Borla exhaust. Daily driver -271 RWHP/269 RWTQ-
GT500 supercharger in a panther
2009+ Window/Lock/Mirror Control Switches Retrofit
Moderator:  BigMerc96, Quasar
9 registered (Bangster, Fordiesel69, 1990CrownVic, LSE_Dave, mrjon1985, 1 invisible), 46 Guests and 79 Spiders online.
NM117 324
RF_Overlord 129
EZlivin11 126
Moby_Vic 126
BigMerc96 124
Chaplian 115
mdnos 97
Ezbok58a 94
a_d_a_m 92
Ponyguy 91
